First Impressions Review of Wood River Butt Chisels
Review by tallinstaller posted 12-31-2012 02:13 AM 9183 views 0 times favorited 11 comments Add to Favorites Watch
First Impressions Review of Wood River Butt Chisels  First Impressions Review of Wood River Butt Chisels  First Impressions Review of Wood River Butt Chisels  Click the pictures to enlarge them
My lovely Wife bought these for me for Christmas this year. I’ve been eyeing them for a while, mostly due to the beautiful Bubinga handles that fit so wonderfully in the palm and the on-sale price of $29.99. This is just a short review based on the initial set up and a few paring and chopping exercises. The set is four chisels in 1 inch, ¾ inch, ½ inch and ¼ inch. Overall fit and finish is quite good for an economy set of chisels. It took quite a bit less work to flatten the backs of these than my Irwin/Marples blue handled set.
The box is nice although the latch is on a little crooked making it difficult to latch.
First look:
As always with Wood River tools, all the metal parts are covered with a grease to protect from rust. The first thing I did was to remove the protective (protects sharp edge and any unsuspecting fingers) plastic tip covers and wipe the chisels down with mineral spirits to get rid of all the cosmoline. Next I looked them over for overall fit and finish and initial sharpness. The Bubinga handles are quite beautiful and comfortable and appear to be finished with lacquer but not as heavily as my Veritas tools. Since most of my tools are from Wood River or Veritas they will fit in quite nicely (I have a thing for uniformity). The backs are nicely polished and the top and side bevels and lands are a nice satin finish. The primary bevel (there is no secondary) was coarsely ground and rough at the cutting edge. The one-inch chisel tip was about a thirty-second out of square. Not a big deal but it did require regrinding before honing.. All the others were dead on square. With the coarse grind out of the box I didn’t even try using them before setting them up.
Initial setup:
This is after five or six strokes on a freshly flattened 800 grit King waterstone. You’ll notice that the stone connected all the way across the tip and back of each face. Those are the dull spots. This is really quite encouraging as a slight hollow in the center is a rather desirable thing in my experience. For all you flat back advocates, just look at Japanese chisels…. If it had come all the way to the edges I might not have done anything further besides polishing up to 8000.
After a bit more work on the 800, then 4000 and finally 8000 grit stones I was happy with the flatness of the overall faces and the polish on the leading half inch or so.
I took them out to the shop and hollow ground all the bevels at roughly 25 degrees then worked up a wire edge on the 800 grit then a tertiary bevel a couple of degrees higher on the 8000. I then flipped it over and polished the wire off on the 8000. Now we’re sharp enough to shave with!
At this point it was time to see how they worked. I threw a bit of pine in the vice and took some end-grain pairing cuts with the 1 inch. I was a bit disappointed when the edge fractured after just a couple of cuts and started to scratch the work piece. I figured that I must have overheated the edge while I was regrinding the edge square. I took it back to the 800 grit and ground it back a ways and rehoned and now it’s performing quite nicely. I went on to do some end grain pairing in soft maple and then used the ¾ inch to chop a ¾ inch deep mortise in the same soft maple. The edge holds up fairly well although not as well as my Marples chisels. Overall I’m quite pleased with the comfort of the handles and the aesthetics and quality of the chisels. The smooth transition from the handle to the ferrell to the blade is very pleasing to the eye and smooth to the touch. I was also pleasantly surprised by the initial flatness of the backs.
After setting them up and using them for a bit I’m not really sure where they fall in my every day woodworking. They’re really too short to be good pairing chisels and the use I thought I’d make of them most was for chopping waste between dovetails but as you can see in the next photo the lands are wide enough to drive a car on. This will make them impossible to use between tails. I could grind down the side bevels to bring the lands to a knife edge, as I’ve done on a couple of my Marples’, but it would be an enormous amount of steel to remove and I don’t want to compromise them for heavy chopping. Besides, as I said, I‘ve already modified a ¼ and a 1/8th inch for that purpose and I don’t really make pins bigger than that. I suppose they will be good for removing waste between pins. They are quite short and the center of gravity is not too high as on my Marples’ so they are well balanced when chopping. You can really choke up on the blade and not be top heavy which makes it easy to get right in your marking gauge line and see both the tip and the top where your mallet is hitting at the same time.
The wide lands: Wood River on the right and unmodified Marples on the left. Both are 1 inch.
Another issue I found is also related to the size of the lands. I use an Eclipse style honing guide and it’s designed for bevel edge chisels and does a really good job with all my other chisels. But with the blades being so short and the flats being so wide on the sides of these, the jig will not hold them securely. I learned to sharpen freehand a couple of years ago but found that I get a sharper tool if I use the jig. I did freehand these today but will have to modify my honing jig so I can use it with them.
As I’m writing this I think I just discovered something else nice about these chisels. I’ve been carrying the one inch in my front pocket for the last hour and forgot it was there. Try doing that with a full size chisel!
In the end, I’d recommend these to anyone wanting a nice set of butt chisels at a ridiculously low price. Very little work to get them ready for use, beautiful to look at and very comfortable to hold and work with. Should be good for pairing or chopping shallow mortises and waste between joinery. Also could become a constant companion for your apron plane.
Now stop playing around on the Internet and get out there and make some shavings!
-- Jason
View tallinstaller's profile
43 posts in 3183 days
11 comments so far
View Dusty56's profile
11819 posts in 3624 days
#1 posted 12-31-2012 04:54 PM
Well written and photographed review. Thanks for the extra efforts : )
I really like my set as well. Mine weren’t covered with cosmoline when purchased though, just a light oil was on them.
I haven’t tried to mortice with them yet. I thought that was a totally different chisel design.
View crashn's profile
528 posts in 2401 days
#2 posted 12-31-2012 06:02 PM
I have the same set and like them as well. It only took me a light pass on my WorkSharp to flatten the backs and then some light work on the bevel to have them super sharp. The price was right for me (on sale at the time) and I do not regret getting them.
Great review and nice pics to go along also!
Happy new year,
-- Crashn - the only thing I make more of than sawdust is mistakes
#3 posted 12-31-2012 06:48 PM
What DO you use yours for?
-- Jason
View NormG's profile
5900 posts in 2940 days
#4 posted 01-01-2013 02:17 AM
Sounds like a solid purchase and they will be useful
-- Norman - I never never make a mistake, I just change the design.
View TechRedneck's profile
768 posts in 2793 days
#5 posted 01-01-2013 04:36 AM
Nice review there, and reflects my view as well. I picked up a set of these on impulse several months ago. They sharpened up rather quickly.
My go to chisels are still my Ashley Isles, however these chisels fit nicely in the hand and are great for general clean up, light paring, and other quick jobs. To me they are nice little beaters (not pounders). I use them where I would not use my finer chisels however they are not used often with a hammer, only then with a light touch.
I would not have them as a first set or my only set. They are too short, but are a nice addition to the collection and are actually used my me.
-- Mike.... West Virginia. "Man is a tool using animal. Without tools he is nothing, with tools he is all.". T Carlyle
View Chris Wright's profile
Chris Wright
540 posts in 3417 days
#6 posted 01-02-2013 02:07 AM
I’ve been impressed with a lot of the new Woodriver tools I’ve had the pleasure of using. For an “economy” brand, all their hand tools have performed exceptionally. Thank you for the review.
-- "At its best, life is completely unpredictable." - Christopher Walken
View ksufosy's profile
3 posts in 2041 days
#7 posted 01-02-2013 10:43 PM
I just sharpened mine yesterday and was very pleased. Great Black Friday deal.
View murch's profile
1380 posts in 2560 days
#8 posted 01-03-2013 09:25 AM
A lot of effort went into this review. Thanks for taking the time.
-- A family man has photos in his wallet where his money used to be.
View lumberjoe's profile
2894 posts in 2184 days
#9 posted 01-03-2013 07:54 PM
I have the full set of the larger woodriver chisels. I like them a lot. I was thinking about getting these for pounders. They are always 29.99 in my local store.
View Thomas Hanson's profile
Thomas Hanson
46 posts in 1888 days
#10 posted 02-28-2013 01:49 AM
I bought the set for the price. I then ground the edges to fit in a dovetail cut. They are worth what I paid for them but I intend to give them to my nephew and but a set of Pheil’s for $129.00 at Woodcraft. I’m hoping they stay sharp a little longer and the edge doesn’t chip like these do, in pine even.
-- Okie from Council Hill
View dbray45's profile
3315 posts in 2713 days
#11 posted 02-18-2015 04:05 PM
I just bought a set -
I have to say that these surprised me. In doing my initial sharpening (pretty much a given), these have pretty hard steel. Off the top, I would say about RC65 – using diamond plates, it took about 1/2 hour to clean up the edge on each chisel. They seem to be holding their edge as well.
-- David in Damascus, MD
