Central Machinery 12'' Direct Drive Bench Top Disk Sander
Review by AJswoodshop posted 12-25-2012 10:00 PM 7100 views 0 times favorited 9 comments Add to Favorites Watch
Central Machinery 12'' Direct Drive Bench Top Disk Sander No-picture-s No-picture-s Click the pictures to enlarge them
This bench top Disk sander comes in handy! Before I was using either my mouse sander, or a sanding drum in my drill press. But when I came across this Bench top disk sander at HF, It was the perfect tool for me.
Positives,
-Cast Iron table
-Dust port which works well
-Tilting Table,
-1 1/2’’ HP motor
-Easy to change sanding disk
-Includes three sanding disk
Negatives,
-A little vibration
-Not the best miter gauge
It’s a great disk sander that I would highly recommend.
View AJswoodshop's profile
AJswoodshop
1057 posts in 2449 days
9 comments so far
View Jim Jakosh's profile
Jim Jakosh
21514 posts in 3278 days
#1 posted 12-25-2012 10:10 PM
That looks to be mighty handy. it looks like you have used it already, too!
What you can do is make a wooden miter gauge with a screw pivot hole for the head and another hole for a dowel when you get it adjusted right on square. Then you put the dowel in and it is fixed on 90 degrees
AJswoodshop
#2 posted 12-25-2012 10:35 PM
Your right, I should make a miter gauge. And Yes, I have used it several times!
View RVroman's profile
RVroman
163 posts in 2197 days
#3 posted 12-25-2012 10:51 PM
If it is a standard miter gauge slot you can use a better one from one of your other machines. My solution was to bit the bullet for an Incra miter gauge, and justify it by the fact I use it on the table saw, band saw, router table, and disc sander.
-- Robert --- making toothpicks one 3x3x12 blank at a time!
View sedcokid's profile
sedcokid
2735 posts in 3771 days
#4 posted 12-25-2012 11:18 PM
Nice to have some of the little things that make our wood working a little easier. You will enjoy this a lot! Hope you have a safe and healthy New Year!!
Thanks for sharing
-- Chuck Emery, Michigan,
View Joe Lyddon's profile
Joe Lyddon
10298 posts in 4225 days
#5 posted 12-25-2012 11:46 PM
Very good… those are very handy…
View William's profile
William
9950 posts in 3015 days
#6 posted 12-26-2012 02:18 AM
I have this same sander. I use a miter gauge on it from an old 50s era Craftsman. It is better than the one that came with the sander. I always keep old miter gauges because they often fit things such as this sander.
View Dangerreuss's profile
Dangerreuss
9 posts in 2753 days
#7 posted 03-19-2014 02:58 PM
I bought this same unit at HF. For my unit, the disc was flat so when sanding only a small portion of the disc would contact and everything would chatter. I took off the sandpaper pad, turned on the unit and ground it flat with my 4” angle grinder. This worked surprisingly well. However, it caused the unit to be out of balance. Next i had to remove the disc and drill holes to balance the unit. After all the headache, it actually works really well. But probably worth the money to buy a good name or hope to get lucky out of the box.
View Grandpa's profile
Grandpa
3261 posts in 2848 days
#8 posted 03-19-2014 03:06 PM
I have a Grizzly like this one. Got it cheap and I use it often. I like it. It had a cheap miter gauge also. The bar is thinner so another gauge off one of my table saws will not work. So far I haven’t modified anything. You will enjoy this tool.
View Scooter McClain's profile
Scooter McClain
174 posts in 2094 days
#9 posted 03-30-2014 03:28 AM
I bought one of these about a year ago and I love mine. I’m weary of Central Machinery power tools, but this has been reliable. Your pros and cons are spot on.
-- I make sawdust. I think thats a fair assessment of my finished products!
