| Review by Brad_Nailor | posted 191 days ago | 2000 views | 3 times favorited | 12 comments | ![]() |
- Whiteside Router Bits
- Brand: Whiteside | Category: Router Accessories
I have recently been doing a lot of pattern routing on my router table. I had started out tracing pieces and cutting them out on the band saw then sanding them on my drum sander, with less than acceptable results (too many inconsistencies in the curves). So, I moved over to making a pattern and cutting close to the line with the band saw then finishing the cut with a pattern bit on the router table. First time I tried this I used a basic, two cutter, top mounted bearing pattern bit and immediately I was getting tear out when routing against the rotation. I reluctantly switched to climb cutting, and within a minute the piece was grabbed out of my hand and thrown violently against the wall. So after some searching, and much review reading (this bit, and other similarly configured pattern bits were given high marks for clean, safe, tear out free pattern routing) I decided to try this bit. It’s a solid carbide, two flute up cut spiral with dual top mounted bearings. It.s expensive ($84.00 at Woodcraft) but the first thing I noticed when taking it out of the protective plastic sleeve is it’s very heavy and solid feeling, and the bearings are really high quality. I chucked it up in my table router (Bosch 2 1/2 HP variable speed) and got my pattern all ready to go. This bit cuts like a dream! I had my pin in for control and did all the routing against the bit rotation and it cut like a hot knife through soft butter. Smooth, controllable, and zero splitting, or tear out. I couldn’t be more pleased with it’s performance. Granted i was cutting a relatively soft materiel (Walnut) but I think it would perform equally well in any materiel.
Overall I give this bit high marks in all categories..quality, sharpness, performance..maybe a little tick for the price..but it is solid carbide, and very high quality. I have many Whiteside bits and have always been happy with them, but this bit is one of the nicest router bits I have ever purchased.
12 comments so far
home | projects | blog
12171 posts in 1538 days
#1 posted 191 days ago
can’t wait to get one
still looking for the money however
live4ever
980 posts in 1207 days
#2 posted 191 days ago
Thanks for the review. I have a couple spirals, but haven’t made an investment in a spiral flush trim bit yet. Been meaning to, but not sure whether to get an upcut or downcut (use both in table and freehand with templates on either side). The up/down combo flushtrim bits would solve that issue, but they are also like $150.
CanadianWoodChuck
363 posts in 2111 days
#3 posted 191 days ago
Cheers, thanks for sharing your opinion on that bit. I have been considering one for some time now. This has just pushed me over the top. Thanks
NiteWalker
1588 posts in 774 days
#4 posted 191 days ago
For future reference, get your whitesides from holbren or hartville tool.
They put woodcraft to shame on pricing…
For example, the bit you bought is $68.26 at holbren.
Brad_Nailor
2450 posts in 2154 days
#5 posted 191 days ago
Thanks Nite Walker..I saw essentially the same bit on MLCS.com for $49.00…but i needed it now! But I will check out those resources ..thanks!
Live4ever..that would be a compression bit..cuts up and down at the same time..and ya your right. I considered one as well for the same reason..flexibility..but it was close to $150.00..OUCH!
David/Bruce..get it! I was amazed at how smooth and controlled it cut..you wont be disappointed.
HorizontalMike
5593 posts in 1111 days
#6 posted 191 days ago
I like this bit. Actually I am finding that this is the most used bit in my collection. Or should I say I have a few extras as I go through them, most often in my horizontal mortiser. Nice write-up!
dnick
587 posts in 579 days
#7 posted 191 days ago
Nice review. That’s out of my budget range in this depression. Someday.
-- dnick, North Hollywood, Ca.
Roger Clark aka Rex
6328 posts in 1632 days
#8 posted 191 days ago
As mentioned on another thread, look into carbide end mills, they are very tough and DO work well on wood.
These bit are make in the USA and are available down to 1/32” and 1/16” dia.
There are 2 types (+ others), the Ultra series and the Niagara series which has 4 flutes.
Make sure you click on “Specification for this product family” to see all the sizes.
I have used the 1/32 and 1/16 and they are superb.
http://www.amazon.com/dp/B009TYGN1I/ref=biss_dp_sa2
http://www.amazon.com/dp/B00A0P9GVO/ref=biss_dp_sa2
-- Roger-R, Republic of Texas. "Always look on the Bright Side of Life" - An eyeball to eyeball confrontation with a blind person is as complete waste of Time.
BenI
259 posts in 375 days
#9 posted 191 days ago
Thanks for this review. I’ve been looking at flush trim bits and can’t really make a decision.
So regardless of the grain and the direction you were routing, you had no tear out?
-- Ben from IL
Ken90712
12859 posts in 1386 days
#10 posted 191 days ago
nice review, thx
Brad_Nailor
#11 posted 190 days ago
Ben
The grain was mostly parallel, but I was routing across grain at the end. Again, it was a lot of walnut, but that bit cut so smooth and perfect…no tear out at the edges, or splitting along the long grain. I was very impressed by its performance. The next peel i make will be mostly maple..we’ll see how it handles that!
BenI
#12 posted 190 days ago
Ah okay, thanks for the reply. I’ll definitely think about getting this bit.
-- Ben from IL
