Craftsman 11' magnetic scroll saw
Review by ralbuck posted 172 days ago 1963 views 0 times favorited 17 comments Add to Favorites Watch
Craftsman 11' magnetic scroll saw Craftsman 11' magnetic scroll saw Craftsman 11' magnetic scroll saw Click the pictures to enlarge them
This saw is a 1952 Craftsman magnetic scroll saw. It does not have a motor. It is an electromagnet that pulls and releases a spring steel plate that has the blade hook attached. It Has an upper spring steel arm holding the upper blade hook. It uses 5” pin end blades.
The capacity is limited to about 1/2 inch or less. The saw has been modified and is now a 20”. It started life as an 11 inch saw.
The modification was made when the saw was probably already 15+ years old.
I can highly recommend this saw for a beginner to learn on. Availabilty might be an issue though.
If I could go get a new one like it at a reasonable price; I would for my grand children to learn on.
I have run my fingers against a fine tooth blade in it , running, many times and not been cut. Blade movemnt is only about 1/8th inch and skin moves that much.
On the star scale of 5 it would get at least a 4+1/2.
I think the review may be due for it!
Yes; it still works, I used it yesterday!
-- just rjR
View ralbuck's profile
ralbuck
129 posts in 440 days
17 comments so far
View NormG's profile
NormG
2586 posts in 1177 days
#1 posted 172 days ago
What a great saw and it is still working
-- Norman
View jap's profile
jap
1039 posts in 228 days
#2 posted 171 days ago
that’s pretty cool
-- Joel -- http://diversitywoodworks.wordpress.com
View lab7654's profile
lab7654
185 posts in 420 days
#3 posted 171 days ago
Very cool, and a good tool to teach safety and technique on.
-- Tristin King -- When in doubt, sand it.
View Planeman40's profile
Planeman40
221 posts in 934 days
#4 posted 171 days ago
I have one of these Craftsman scroll saws and everything you say I will back up! I bought the saw new in the early to mid 1950s to build model airplanes with and later on I used it to make all of the wing ribs on a full size homebuilt biplane. It still works just fine, but now I have a fancy motor-powered scroll saw so it just sits under a bench. I may give it to my grandson when he gets to be about eight. As you said, its perfect for a kid to get started on. Its a shame someone doesn’t make these again as they are so simple and work so well.
Planeman
View JJohnston's profile
JJohnston
1394 posts in 1465 days
#5 posted 171 days ago
How do these work? Is there a mechanism to turn the magnet on and off really fast, or is there a manual switch, or..?
-- My broker promised me he would treat my money as if it were his own. Trouble is, he did.
View oldretiredjim's profile
oldretiredjim
105 posts in 559 days
#6 posted 171 days ago
I’ll remember this one. Thanks.
ralbuck
#7 posted 171 days ago
Well here is the explanation as I know it!
Alternating current (common household 119 Volt) The term is for the direction changes — 60 cycle is common. It drops—reverses direction of current flow 60 times per second..
When the current drops/changes/GOES OFF- 60 times a second the magnet quits pulling! The spring steel in the upper arm and blade hook pull the blade up! When the current starts/changes direction—the magnet pulls the bottom spring steel plate down—BLADE along with it!
-- just rjR
View Dusty56's profile (online now)
Dusty56
10585 posts in 1861 days
#8 posted 171 days ago
and we talk about modern marvels ! LOL …I never heard of this until now …thanks for sharing with us : )
-- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did.
View DeLayne Peck's profile
DeLayne Peck
163 posts in 375 days
#9 posted 170 days ago
Did a lot of scrolling on one of those back in the day. I remember it as noisy. Wonder where it went?
-- DJ Peck, Lincoln Nebraska. I don't have a Shop. I think of it as a Tool Chase. Where the hell did I put that?
ralbuck
#10 posted 169 days ago
Added a “DOLLAR TREE” booklitght that just clamps on today! Needed that 55+ years ago!
Flexible tube to the head and a very small led light—-worth the “high price”.
-- just rjR
View Ted78's profile
Ted78
106 posts in 173 days
#11 posted 168 days ago
Ha, saw one of these on craigslist a while back and for the life of me could’‘t figure out how it worked with that u shaped arm thing, Thanks for enlightening me.
-- Ted
View crank49's profile
crank49
2291 posts in 1144 days
#12 posted 168 days ago
I think your explanation of the 60 Hz AC is correct except for one little detail you omitted. There is a diode in the circuit to convert the AC to DC. Electro magnets don’t work very well on AC power. Since the Diode only allows the current to flow in one direction, you wind up with pulsating DC which pulls the saw blade down 30 times a second.
This type of magnetic drive is used in industry all the time. Usually for vibration generation. Tatoo needles are driven by this process, as are hand held electric engravers.
-- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason.
JJohnston
#13 posted 168 days ago
Based on my experience with engravers, the saw must have a real short stroke and not much power.
crank49
#14 posted 167 days ago
Well it’s relative. Look at the size of the little magnet in a hand held engraver and then look at the big coil on the saw. Many times larger. I was just pointing out it’s the same principle. No rotating motor. Just an electro magnet pulling a tool and a spring pushing back.
And yes it would be a short stroke. I think someone earlier said it was only 1/8”. I’m not sure as I haven’t used one myself. That was what made it safe for kids to learn on.
runswithscissors
610 posts in 199 days
#15 posted 167 days ago
Dremel used to make a handheld version which they called the “motosaw.” Shaped like an old time coping saw. It was the first power tool I ever owned, and I used it on all sorts of projects. They are very safe, though if a tool won’t let you hurt yourself, I wonder how effective they are at teaching safety habits. They do teach patience, because, oh my, how slowly they cut. If you try to adjust more stroke into them to speed things up, they get out of phase and let you know it with very loud unpleasant noises. I’m assuming they don’t make this anymore; at least I didn’t see it on their website.
