PC Mini Dovetail Template #4215 - Nice Idea, Poor Design, Not as Advertised
Review by JustJoe posted 183 days ago 1537 views 1 time favorited 4 comments Add to Favorites Watch
PC Mini Dovetail Template #4215 - Nice Idea, Poor Design, Not as Advertised PC Mini Dovetail Template #4215 - Nice Idea, Poor Design, Not as Advertised PC Mini Dovetail Template #4215 - Nice Idea, Poor Design, Not as Advertised Click the pictures to enlarge them
I needed to make some small half-blind dovetailed drawers with 1/2” fronts and 1/4” sides and my Leigh jig wasn’t up to the task so I looked around and ordered the Porter Cable 4216. Most of you are familiar with the 4200 series PC jigs so I won’t discuss the jig itself, just the miniature template (#4215) – I just ordered the 4216 kit because I had to have the jig itself before I could use the mini dovetail template.
My first discovery upon opening the box and reading the instructions is that although it does do miniature dovetails – it doesn’t do them down to the advertised specs. Every website I search said that this jig would do miniature through and half-blind dovetails in wood 1/4 to 1-1/8” thick. That is not quite true. According to the manual it does through dovetails in stock down to 1/4” thick, but half-blind only down to 1/2”. Since I like my drawers to have sides thinner than fronts, that was a bit of a problem for me. But I decided since it was already here in the house I’d give it a try and maybe I could find a workaround.
Assembly was fairly quick and easy but setup soon showed a couple of more problems – The built-in biit depth-gauge was a little screw on the left with enough spring in it as to be worthless. Initial depth was supposed to be 3/8” so I ended up using a ruler and just setting it by hand to 3/8” + the 1/4” for the thickness of the template. The second issue I had was with the alignment – the jig itself looks like rough painted pot metal but is surprisingly slick – the top piece had to be overtightened to keep the wood from moving, and the left-alignment bracket was hard to position square to the wood.
But the final straw was the actual resulting dovetail. I started with 1/2” front and sides, made a test, adjusted the bit, made another test, adjusted the bit, made another test and so on until about 20 board feet later I had the closest I could get to a correct joint. To tighten the joint you heighten the bit. Starting with a 3/8” depth on a 1/2” piece of wood only leaves 1/8” to play with. But by the time I got done dropping the bit down far enough to get a semi-tight joint that 1/8” was down to under 1/16”. Just for grins I tried with 1/2” front and 3/8” sides – I just managed to get something that resembled a dovetail joint, but the sliver of remaining wood was about .000000000000000001” thick. So while the manual says 1/2” is the minimum, I suspect that 9/16 or 5/8” is probably closer to the truth – certainly not the 1/4” advertised.
The 4216 came with other templates for doing larger joints, but my Leigh handles those quite nicely so I doubt I’ll be getting much use out of the PC. I’m also now in the market for a miniature dovetail jig that is capable of handling 1/2” fronts with 1/4” or 3/8” sides so if you know of one out there that is available please let me know.
thanks
Joe
View JustJoe's profile (online now)
JustJoe
166 posts in 209 days
4 comments so far
View Howie's profile
Howie
2449 posts in 1093 days
#1 posted 182 days ago
I can share your frustrations with the PC dovetail jig(s). I had a 4212 that I “fiddled” with three times and was never satisfied with the results(these were like an hour at a time not just a few minutes) I finally gave up and bought an Incra for my router table(LS-25)
The instructions for the Incra lists the smallest dovetail at 1/4” thru and 3/8” blind material thickness if this will help. I’ve found it is hard to beat the Incra for accuracy and their video makes the learning curve fairly simple.
-- Don't rollerskate in a buffalo herd
JustJoe
#2 posted 182 days ago
Thanks I’ll look into the Incra.
View Cato's profile
Cato
642 posts in 1483 days
#3 posted 182 days ago
I have the 4212 and it works well for me on thru dovetails. I can get them so tight I have to use a rubber hammer to knock them apart. I use scrap to set up same thickness as project pieces and that has worked well for me.
I have thought about getting the smaller jig set a few times but just haven’t had the need.
Howie, the easiest way I found to work the 4212on dovetails was to use two routers rather than switching bits back and forth.
Once I did that it was like night and day. No frustration and very minor adjustments to get tight fitting joints.
View BrentNichols's profile
BrentNichols
36 posts in 1118 days
#4 posted 180 days ago
The new 16” PC omni jig works very well for minature dovetails. This is probably were they corrected the issue, but not sure if you can justify the cost… Goodluck
-- BN in Indiana
