Review of my Porter Cable 15" Drill Press
Review by thewoodworker01 posted 11-10-2012 07:34 PM 27708 views 2 times favorited 19 comments Add to Favorites Watch
Review of my Porter Cable 15" Drill Press Review of my Porter Cable 15" Drill Press Review of my Porter Cable 15" Drill Press Click the pictures to enlarge them
Last year I bough the Porter Cable Drill Press at Lowe’s. I searched around for other drill presses but this one surpassed them all. For the price you can’t beat it!!! A couple features that I really like about this drill press is the 1 HP motor, 12 different speeds ranging from 300 to 3100, floor type, a full 4 inches of spindle travel, and made out of metal. Most other drill presses are made out of cheap plastic, but this one has a metal pulley cover! Unpacking this beast wasn’t hard, but I highly recommend you need two people to lift up the head of the drill press on the column. Instructions were clear. This drill press has a lot of milling grease on it. Probably to keep the metal from rusting. The box had soaked up some of the grease, but that was ok. I still have to adjust my lasers so they align properly, but I don’t use them that often. Mainly because I just drop the chuck and the drill bit down to the wood and line it up from there. This drill press is very well made. I am very pleased, I would definatly buy another in a heartbeat, but I highly doubt I will ever need to do that. This makes a great first drill press. This is my first drill press and probably my last!! I wish I could rate this drill press a 6 out of 5 stars!!!!
I have a video of this drill press on Youtube https://www.youtube.com/watch?v=PyjnpXESQbk&feature=plcp
-- Most people say "Measure Twice, Cut Once." I say, "Cut Twice, Measure Once".
View thewoodworker01's profile
thewoodworker01
93 posts in 2174 days
19 comments so far
View BerBer5985's profile
BerBer5985
445 posts in 2449 days
#1 posted 11-10-2012 08:40 PM
Awesome review. I’ve been in the market for a stand up drill press because I find the benchtop model I have lacks power and is usually under a bench not hookup and it doesn’t get used when it should because of it. Maybe have to throw that one on the christmas list this year. thanks for the review!
-- Greg, Owner, Quality Carpet One, www.qualitycarpetonecrofton.com
View NiteWalker's profile
NiteWalker
2737 posts in 2605 days
#2 posted 11-10-2012 08:53 PM
You did good, that’s a great press and probably the best value on a floor press at the moment.
However, I don’t think it’s 1HP at 8 amps; more like 1/2 HP. Is there a rating on the motor itself?
View harrywho's profile
harrywho
120 posts in 3261 days
#3 posted 11-10-2012 10:44 PM
Nice review. I’m glad you like it-I’m picking mine up at Lowe’s tomarrow!
-- Harry, Indiana
View felkadelic's profile
felkadelic
218 posts in 2569 days
#4 posted 11-10-2012 10:46 PM
I have one also that I generally like (the vertical table movement isn’t quite as smooth as I’d like). Upgrading the table made a huge difference in the usability of the machine.
runswithscissors
2768 posts in 2054 days
#5 posted 11-11-2012 06:53 AM
I’ve had my PC drill press for a couple of years now. I replaced the geared chuck with a Grizzly keyless chuck. Saves a lot of hassle, looking for the chuck, etc. I think you can actually get a keyless tighter than a geared one. But I have a lot of runout. I realize some of this may be due to the chuck, but I suspect the drill press is also at fault.
View ellen35's profile
ellen35
2738 posts in 3461 days
#6 posted 11-11-2012 11:32 AM
i also bought one a couple of years ago… it is a workhorse and I’ve never had a problem with it.
View shelly_b's profile
shelly_b
850 posts in 2146 days
#7 posted 11-11-2012 08:28 PM
I have had mine for a few months and love it! I havent found anything it cant handle. I can use a 1in forstner in hard wood and you would think i was using an 1/8 in bit. I couldnt beleive how much easier it was after only using hand drills!
View Dusty56's profile
Dusty56
11819 posts in 3717 days
#8 posted 11-12-2012 02:56 AM
Your video link doesn’t work.
View WoodIfIcould's profile
WoodIfIcould
23 posts in 2093 days
#9 posted 11-12-2012 05:31 AM
I have had this drill press for about 6 months…it replaced my vintage bench top model. It has performed nicely to date. I did make a table for it – as the table it comes with is pretty small and geared more for metal work IMO.
I recommend it as well. I’ll try and post the table in projects as the clamping system I ended up using has worked out very well (owners of this unit know that the table has no ‘through’ holes in it).
-- Tim, IL
View vernonator's profile
vernonator
75 posts in 2680 days
#10 posted 11-13-2012 02:53 PM
I have this press as well – for about 18 mos now and it is rock solid. No run out to speak of, only complaint is the tiny table but a Woodpecker table fixed that up quickly. Good item for a good price – can’t go wrong
View Jason™'s profile
Jason™
87 posts in 2156 days
#11 posted 11-14-2012 09:21 AM
How ironic I recently purchased this same unit online and brought it home on the 12th and am loving this unit already. The only issue I am having is the lid rattles due to possibly being slightly bent or some reason. Possibly adding some silicone or something to the under part of the lid might help with the sheet metal rattle sound.
Has anyone changed the Vbelts over to the more talked about Link belts that are supposedly better?
View troyd1976's profile
troyd1976
8 posts in 2110 days
#12 posted 12-16-2012 11:23 PM
Did lowes stop carrying this saw? ive noticed my local no longer has it nor the PC band saw.
View newbirdhunter's profile
newbirdhunter
25 posts in 1925 days
#13 posted 04-29-2013 12:54 PM
Thanks for the review. Your YouTube video was also very helpful.
View 303Woodwork's profile
303Woodwork
25 posts in 2542 days
#14 posted 07-20-2013 09:42 AM
Nice review and very helpful video.
There’s a lot of potential candidate presses to chose from and drill press reviews like this are a great help.
Thanks!
-- Gotta love woodworking!
View TheFridge's profile
TheFridge
9608 posts in 1515 days
#15 posted 02-10-2015 03:31 AM
Drill press still doing good? Thinking about getting one.
