My first planer... cheap, easy to use, and portable
Review by SST posted 150 days ago 728 views 1 time favorited 14 comments Add to Favorites
View SST's profile
SST
241 posts in 646 days
My first planer... cheap, easy to use, and portable My first planer... cheap, easy to use, and portable No-picture-s Click the pictures to enlarge them
Well, for anyone who expects an in-depth review that has it’s foundation in a thorough understanding of wood planers, you’re going to be disappointed.
This is my first planer and I’ve only actually been near an operating one once before, so all you’re going to get is a novice’s impression of a machine that’s probably meant for a novice. Maybe that makes me the perfect guy for the job, after all.
This model sells locally for $239.00 and (of course) lists much higher. I did a brief blog about this a couple of days ago and mentioned that the reason I couldn’t resist getting this was the price ($186 with free shipping from Amazon.com)...that and my experience watching one in use with Lumberjock “Woodgizmo” who was kind enough to plane some stuff for me for a recent project. I think his was also a Delta. I really wasn’t planning on getting one just now, but you know how it goes when you find a price that’s too good to pass up…you make up a reason to give your spouse that makes it seem almost un-patriotic not to buy it.
So I did it.
It’s definitely user friendly in that you can have it up & running in about 5 minutes. All I had to do was install the elevation crank, the cutterhead cover, and level the in/outfeed table extensions. Like I said, all done in 5 minutes.
Since space is an issue for me, I just clamped it to my B & D workmate with a couple of C-clamps. Moving it around is only mildly inconvenient and probably wouldn’t even be that if I was 20 years younger. The carrying handle is padded which is good foe carrying, but not for it’s other use as a stock transfer bar…oh, well, you can’t have everything. (oh, wait, yes you can…I have a Shopsmith…sorry, just couldn’t resist)
In use, I adjusted the crank 1/2 turn per each pass and the planing went great. I’ve shown a piece of pallet wood and how another looks after planing. Looks like mahogany. I thought it was prudent to remove all the nails before planing it, although if I hadn’t I could probably have included the blade changing procedure in this review.
In use, everything went as I’d expected. The up/down adjustment works well and the thickness scale was dead-on. Each 1 full turn supposedly gives 5/64” adjustment. That, also, seemed accurate. As to snipe, there appears to be a little, but it doesn’t seem excessive, and since this was my first try with the machine, It might just be my inexperience.
I give this 5 stars, not because it’s the best around, or because it has a ton of features, but rather, I believe it does it’s intended job as a portable low cost planer very well, and it has a 2 year warranty as well. -SST
-- Accuracy is not in your power tool, it's in you
14 comments so far
View GaryK's profile
GaryK
8411 posts in 439 days
posted 150 days ago
Nice review. Thanks
teenagewoodworker
1951 posts in 219 days
posted 150 days ago
thanks for the review. its been between this and the grizzly for awhile but i think that now i might be leaning a little bit more toward the delta. thanks for the review.
View WoodJack49's profile
WoodJack49
189 posts in 214 days
posted 150 days ago
I was thinking that this was the same as the Delta planer that I’ve had for a year or so now and have been very happy with it as well. But, mine is the two-speed, 13” model, the 22-580. It leaves a very good surface at the finish speed (90 CPI). I would use the 20” planer at school to do the grunt work and then bring the wood home to do the final couple of passes.
By adjusting the in-feed and out-feed tables up slightly to support the wood better or using my hand to support longer pieces, I can usually eliminate the snipe.
-- Jack - Mission Viejo, Calif
8579 posts in 273 days
posted 150 days ago
Hi SST,
Nice review and I agree it is a good planer.
Thanks for the post.
View dlcarver's profile
dlcarver
228 posts in 181 days
posted 150 days ago
Do you wear that bow tie and tux when you operate it? That’s ok, I like to come home and dig right in without changing too. Nice review also! Looks like a good one.
Dave
-- Dave Leitem,Butler,Pa.,http://dlcarver.etsy.com
View tooldad's profile
tooldad
72 posts in 166 days
posted 150 days ago
I had one in a school shop I previously worked in. Not too bad, I think it was $300 when I ordered it. However I would spend a little more and go with the Dewalt 735. (I think that is the number) It is the one with the 4 posts, so a cutterhead lock is not needed, has repeat thickness setting, 2 speed feed control and easy to change indexed 3 cutterhead blade system. I have changed blades at least 6 times in the 3 years I have had the machine, it can be done in about 10 minutes. The entire top lifts off and you look down from the top since the motor is behind the cutterhead. This is the only planer I have changed blades on and not cut my finger in the process. Beware to anyone changing planer blades, they are as sharp as a surgeon’s knife and you will be bleeding before you even know you are cut. At least it doesn’t hurt that way. Finally the planer has a chip ejection fan/blower. That thing can inflate my dust collector and it has to travel through 6 feet of 4” flex hose, 6 feet of 6” pipe, and finally through about 12 feet of 8” pipe to get there.
Dewalt and Delta have merged and even the tool rep for my school who can sell me either and was first a delta rep says the dewalt is the way to go and that machine would stand up even in the school shop environment.
I have sent at least 4 complete kitchen rebuilds through my planer, and dozens of other personal projects. Lumber from Pine and cedar to maple, oak, ash, and cherry.
The only drawbacks are the cost at nearly $500, and the weight, it is about 75lbs. Not really too portable. I do remember reading in one of the magazines it rec’d top tool, but not top value for the same 2 reasons I just listed.
Just my 2 cents. Tooldad
View ChicoWoodnut's profile
ChicoWoodnut
596 posts in 266 days
posted 150 days ago
nice review. Can you tell us where you get those pallets?
I have a cheap Delta planer too. It works fine. I have i sitting in a tool well with 24” of infeed and outfeed. that keeps the snipe down.
View Ad Marketing Guy - Bill's profile
314 posts in 249 days
posted 149 days ago
Great Informative Review! Impressive Results with Pallet Wood -
-- Bill - - Ad-Marketing Guy, Ramsey NJ
View SST's profile
SST
posted 149 days ago
I’m thinking of building a longer infeed / outfeed extension to use when I clamp this to my bench. I do think that’s the way to go. As to pallets, I got a bunch at a local landfill where they are stacked up. They sell the good ones for a buck each and the ones with broken parts are given away or trashed. I usually take the ones with broken parts because there’s a lot of good pieces, and, of course, because I’m cheap.
You can also watch larger business that get stuff on pallets. They often toss them. -SST
ChicoWoodnut
posted 149 days ago
The infeed/outfeed is what does the trick . Check out my bench. It holds a planer, mortiser and it also servs as a massive router table. Click on the thumbnails to see bigger pictures.
View USCJeff's profile
USCJeff
793 posts in 519 days
posted 148 days ago
Nice review, I have had the same model for a year or so. Like you, it’s my first so I can’t give a comparitive analysis. However, I’m very happy with it. The depth adjustments are fluid and blade changes are straight forward. Snipe is an issue, but my understanding is that almost all benchtops don’t have the locking mechanism that reduces snipe. Dust collection is not accounted for so much either but I typically angle the rolling flip top cart (see my projects) towards a floor sweep/dsut collector.
-- Jeff, South Carolina
View Tim Dorcas's profile
Tim Dorcas
46 posts in 309 days
posted 144 days ago
I have to say that I had this planer and did not like it. It had horrible snipe no matter what I did. I finally sold it and got a Dewalt 734 and have never looked back.
-- www.responsetolight.com - A Woodworking & Renovation Blog
View Bigbuck's profile
Bigbuck
820 posts in 114 days
posted 107 days ago
While there is at tendancy for this planer to leave snipe on the first and last few inches of a board it can be reduced and even eliminated (virtually) by lifting the board slightly as it goes in and out of the machine. Taking light passes also helps. While this planer doesn’t have many of the features of more expensive planers it will get the job done if you are on a budget. If I could have afforded it at the time I probably would have went with the Rigid planer. The Dewalt is just to expensive for me given the amount of work I do.
-- Glenn, New Mexico
View steveosshop's profile
steveosshop
178 posts in 77 days
posted 70 days ago
I have this planner and use it a lot. I really like the fact that the blades are easy to change and are self indexing so you do not have to worry about squaring all the cutterheads to perfection after each blade change. There is snipe, but I tend to leave the boards a little long and then cut them down to final size and noone ever knows the difference.
-- Steve-o
Bookmark And Share This Page
