finally found something to carve out the bowl of a spoon
Review by Joey posted 596 days ago 819 views 0 times favorited 7 comments Add to Favorites Watch
finally found something to carve out the bowl of a spoon finally found something to carve out the bowl of a spoon No-picture-s Click the pictures to enlarge them
Ever since I started making spoons and spatulas back at christmas, I have been looking for a tool that makes carving the bowl of a spoon easier. I started out using a dremel. The problem with the dremel’s is that you can’t find carving heads big enough. All of the power grinders I had found were $300+. But Woodcraft has a new tool made by Wecheer. It is simply to use, and has more than enough power using carving bits with 1/4” shanks.
The first time i used it, I cut the amount of time to make a spoon from about hour to just over 45 minutes.
The motor is a 1/4 horse power. It has a power switch located on the motor that will of course turn the unit on and off, but also reverse the dirction of the spin. The Motor can be mounted to the wall, a cabinet, or clamped to a work bench. The shaft is 42” long. The hande piece has 3 different size collets, 1/4”, 1/8”, and 3/32. It also has a carver attachment that is sold seperatly that I haven’t gotten yet.
It is controlled with a foot petal. The more pressure you apply to the petal, the faster it goes. All the way up to 20,000 rpm
So far I have made 10 spoons with it, and can find nothing wrong with the usefulness of it, or the operation. A very comfortable and straight forward design. And the price can’t beat, it was half the price of the next cheapest one I found and had more hp to boot.
-- Joey, Magee, Ms http://woodnwaresms.com
View Joey's profile
Joey
259 posts in 709 days
7 comments so far
View GaryK's profile
GaryK
9521 posts in 882 days
posted 596 days ago
Great review. Thanks
View DAN 's profile (online now)
DAN
6439 posts in 876 days
posted 596 days ago
glad you posted this review.
I’ve been considering this tool and a good positive report, was what I have been waiting for.
14920 posts in 745 days
posted 596 days ago
Interesting tool Joey. Thanks for the review.
View cajunpen's profile
cajunpen
5968 posts in 959 days
posted 595 days ago
Good review, looks like a Dremel on steroids.
View dlcarver's profile
dlcarver
260 posts in 624 days
posted 595 days ago
I have been using Foredom for 30 years. It is the same thing, very little goes wrong with it. It works hard for me every day, as a matter of fact I have 2 of them, they can be reversed with a switch…. for left handed carvers. Also has variable speed footswitch.
Dave
-- Dave Leitem,Butler,Pa.,http://dlcarver.etsy.com
View motthunter's profile
motthunter
2079 posts in 693 days
posted 593 days ago
looks like a handy unit. thanks for the review
-- making sawdust....
View jerryw's profile
jerryw
100 posts in 809 days
posted 592 days ago
Joey,
I solved the problem of carving out a spoon by not carving but by sanding. I made 3 or 4 narrow ( 3/4”) drum sanders with a diameter of 4” or larger if you are making large spoons or smaller for small spoons. The drums are cut from plywood, lightly chamfer the edges, cut a v shaped piece out of the edge, wrap a 3/4” wide strip of sanding belt 50 or 60 grit around the outside and hold it in place with the v shaaped piece and a drywall screw. I have mine mounted on an arbor shaft driven with a 1/3 hp electric motor. Sand across the grain of the wood. The 50 grit will remove the wood real fast. You have to keep the wood moving back and forward to shape the bowl of the spoon. Another drum with 100 or 120 grit will smooth it up. You do the spoon in about a minute or two at the most.
-- jerryw-wva.
