Not recommended for shellac
Review by Purrmaster posted 10-11-2012 08:08 AM 4506 views 0 times favorited 31 comments Add to Favorites Watch
Not recommended for shellac No-picture-s No-picture-s Click the pictures to enlarge them
I got this stuff after I saw that the finishing test counter at Rockler had a bottle of this. I was using shellac for the first time so I got this denatured alcohol instead of the “regular” denatured alcohol. I was hoping it might have a bit less toxicity.
After sticking my shellac flakes in (2 oz of shellac) and measuring out 6 ounces of alcohol I let the jar sit overnight. And basically nothing happened. So I shake and stir and it makes no difference. I even put the jar in some hot water. Nothing. I end up with a gloopy mass of shellac at the bottom of the jar.
After about 2 weeks the shellac finally dissolved fully. I figured I screwed something up. So for my next batch (same amounts of shellac and alcohol) I ground up the shellac flakes in the blender to a fine powder. I measured out the alcohol and let it sit.
It’s been 3-4 days now and the shellac is not dissolving any faster than the last batch. I have a gloopy mass that I can’t use.
For comparison, on my third batch of shellac I got Klean Strip’s regular SLX denatured alcohol. In about a day the shellac is fully dissolved. I didn’t even grind up the flakes.
Bottom line: This “Green” stuff doesn’t work well for shellac. I would have given it just one star but the shellac does eventually dissolve. The Green stuff smells just as bad as it’s SLX counterpart so I doubt it’s any less toxic.
View Purrmaster's profile
Purrmaster
915 posts in 2266 days
31 comments so far
View JJohnston's profile
JJohnston
1622 posts in 3464 days
#1 posted 10-11-2012 12:09 PM
Do they say what’s in it? Frankly, I can’t imagine the need for a “green” DNA – after all, ethanol is a totally natural product. It’s just yeast poop.
-- "A man may conduct himself well in both adversity and good fortune, but if you want to test his character, give him power." - Abraham Lincoln
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2542 days
#2 posted 10-11-2012 01:36 PM
Thanks for the warning. Also avoid the “green” mineral spirits. It’s a milky white emulsion and is useless except for cleaning brushes.
13635 posts in 3514 days
#3 posted 10-11-2012 01:45 PM
the first time i tried water based contact cement
i couldn’t get it to stick worth a dam
give me good old lacquer based
pretty soon they will have
‘new and improved formula’
eco-friendly for all finishes
WATER !
View Puffin's profile
Puffin
22 posts in 2820 days
#4 posted 10-11-2012 02:03 PM
Sorry for your troubles and thanks for the heads up. Well at least one silver lining is you helped some of us from having a similar experience.
View joewilliams's profile
joewilliams
88 posts in 2297 days
#5 posted 10-11-2012 02:19 PM
thanks for the warning!
-- Joe - - - something witty should go here - - -
View ChrisForthofer's profile
ChrisForthofer
150 posts in 3240 days
#6 posted 10-11-2012 03:49 PM
Green alcohol? That’s a new one on me… While I have no problems with “green” products, I generally steer clear of them. If it works as well or better than its non-green counterpart, great, but usually they fall short like this one did. Thanks for the review.
Chris.
-- -Director of slipshod craftsmanship and attention deficit woodworking
View crank49's profile
crank49
4032 posts in 3144 days
#7 posted 10-11-2012 04:02 PM
They probably made it “GREEN” by dilluting it with 50% water, then jack the price up 50% because it’s “GREEN”.
Sad thing is that this marketing scam works and creates millions of dollars in sales for basicly inferior products.
BinghamtonEd
#8 posted 10-11-2012 04:05 PM
The green MS is an emulsion and I surmise that it does contain some amount of water. I tried making a wiping poly by mixing it with oil-based poly and wiped on a coat, and 5 days later it was still tacky. Brought the container back to HD and got my money back.
View denovich's profile
denovich
30 posts in 2996 days
#9 posted 10-11-2012 04:45 PM
The Kleen Strip Green is almost entirely Ethanol (ethyl alcohol, the kind you drink)... Check out the MSDS: http://www.wmbarr.com/ProductFiles/KSG%20Denatured%20Alcohol.pdf
The regular Kleen Strip DNA is about 50% Ethanol, 50% Methanol (the kind that makes you blind)...
http://www.wmbarr.com/ProductFiles/1625%206%20KS%20Denatured%20Alcohol%209%2012%2012.pdf
Everything I’ve read about Shellac is that Ethanol is the preferred solvent. Shellac might dissolve faster in it, but too much methanol causes issues when it dries. I exclusively use the Kleen Strip Green as it’s the only 95% Ethanol DNA that’s easy to obtain, and I certainly prefer not being exposed to methanol.
Purrmaster
#10 posted 10-11-2012 06:15 PM
Now that is interesting. So the tradeoff for it dissolving slowly is that the shellac may go on better? That does change my perspective a bit.
What kind of problems does too much methanol cause? I’ll be doing a sort of “head to head” between the two alcohols once everything dries. It may not be a fair test though because I mixed a 2 pound cut with the regular denatured and a 3 pound cut with the Green stuff.
Thanks for the information.
View WoodworkGuy's profile
WoodworkGuy
60 posts in 2967 days
#11 posted 10-11-2012 09:51 PM
Glad to know. Definitely won’t buy this stuff for shellac. Will have to see how it works for other things. Thanks for the review!
-- Making sawdust and memories through woodworking.
Purrmaster
#12 posted 10-12-2012 12:52 AM
Please do note denovich’s post. He has a counter argument that the “green” stuff is better when it gets to the shellac actually drying. If so, that would largely negate my review. Can anyone else comment on this? I don’t want to knock a product incorrectly because I don’t have enough facts.
View GarageWoodworks's profile
GarageWoodworks
532 posts in 2329 days
#13 posted 10-12-2012 12:53 AM
denovich nailed it. The green is >90% ethanol and the regular is 50% ethanol 50% methanol. Apparently shellac is more soluble in methanol than ethanol.
In order to salvage your green ethanol, buy a container of methanol from the BORG and cut your green ethanol in half to make a solution of roughly 50:50 ethanol/methanol. That way you won’t waste it.
-- Subscribe on YouTube: http://www.youtube.com/user/GarageWoodworks?feature=guide
Purrmaster
#14 posted 10-12-2012 10:57 AM
But does a higher methanol content lead to the shellac having drying problems?
GarageWoodworks
#15 posted 10-12-2012 11:17 AM
No. The higher the methanol content the faster the drying time should be the only difference you see.
showing 1 through 15 of 31 comments
