Great Investment for a Small Shop
Review by Chris Moellering posted 10-06-2012 08:26 PM 5395 views 1 time favorited 11 comments Add to Favorites Watch
Great Investment for a Small Shop Great Investment for a Small Shop Great Investment for a Small Shop Click the pictures to enlarge them
This is my first table saw. I picked it up at my local Lowes a about 2 months ago now. My impressions after a few projects with it—
Assembly & Set-Up
Putting it together out of the box was a fairly straightforward affair. The saw came set square and true according to my checks. That being said, I’m not a micrometer-wielding woodworker. But it’s been fine for what I’ve done thus far.
Operation
It cuts well. The supplied blade seems pretty decent. I have noticed (as I read somewhere on LJ) that the handle for the fence can hit a piece of stock if you have the stock sticking past it when adjusting for a cut. Not a huge deal, just a minor annoyance.
The supplied miter gauge seems good, though I haven’t used it since I made my sled.
The expanding table allowed me to make a simple drop-in section for my router so I could benefit from the fence.
The stand is solid. Ripping full-size sheets of plywood with one person is a bit much for it, but that would be the case with any portable saw I would think.
Overall, I’m thrilled to have a table saw and this one meets my needs for a fair price. It is easy to set up and take down in my garage shop. (Which is a must for me.)
I am sure there are fancier and better saws out there, but for a weekend woodworker like me, I’d recommend it to others without hesitation.
Edit (26 Dec 2012) I may be onto a fix for the lack of a zero-clearance insert. See here.
-- Grace & peace, Chris+
View Chris Moellering's profile
Chris Moellering
227 posts in 2848 days
11 comments so far
View Milo's profile
Milo
869 posts in 3519 days
#1 posted 10-07-2012 01:44 AM
Can it accept a dado blade?
-- Beer, Beer, Thank God for Beer. It's my way of keeping my mind fresh and clear...
Chris Moellering
#2 posted 10-07-2012 10:35 AM
Up to 1/2” according to the Porter-Cable website. I haven’t tried one yet.
View Milo's profile
Milo
#3 posted 10-07-2012 12:54 PM
Bummer. :( I’d want a 3/4”
View dustyal's profile
dustyal
1299 posts in 3675 days
#4 posted 10-07-2012 03:42 PM
I use a Ridgid bench top table saw. It does fine. And as you say, good for weekenders. The short comings I have is the infeed and outfeed—that space from front edge to blade is shorter than floor saw… and same as the back of blade to back of table. I just don’t have room to make suitable tables to stretch out support for longer cuts.
And, mine will not accept 3/4 dado. Plenty of horsepower… so it must be other engineering constrains.
Oh, thin clearance plate. I haven’t figured out to make a zero clearance plate. Let me know if someone figures that out for these thinner steel plates.
Hopefully your fence will set to square when moved. Mine won’t. I have to play with it to make sure it clamps square.
-- Al H. - small shop, small projects...
Chris Moellering
#5 posted 10-09-2012 05:32 PM
Fence seems good so far. I concurr on the nonstandard insert.
View B0000stwagen's profile
B0000stwagen
7 posts in 2503 days
#6 posted 12-05-2012 07:42 PM
I have this saw… I love it except for the non-standard insert. Love the portability. I like the idea of using a router insert for the expanding table… will be using that.
I’ve used a dado set with it, and you can leave the standard insert in place for up to 1/4”. Dadoes larger than that required me to remove the insert altogether which presents an obvious safety hazard. Plenty of horsepower for the 1/2” dadoes it accommodates.
The other issue with the insert is that it isn’t very rigid. I built frame and panel doors, some with long stiles with a 1/4” groove. As you get to the end of the material, it was hard to get a consistent depth of groove because the insert has quite a bit of flex to it. Not enough downward pressure = too shallow, too much pressure, you can make it too deep.
-- JP
View Miehas's profile
Miehas
2 posts in 2085 days
#7 posted 03-28-2013 07:56 PM
I have not ordered one for my saw yet, but I did see this when looking for a ZCI for my dado set.
http://servicenet.portercable.com/Parts/Detail/298572
5140097-90 DADO THROAT PLATE $23.11
Chris Moellering
#8 posted 03-28-2013 08:11 PM
Interesting, I made my own from scrap plywood.
Miehas
#9 posted 04-08-2013 04:11 PM
I purchased it to see how well it would work.
It is indeed an insert designed to work with a stacked dado, but it is defiantly not a ZCI.
I ended up using it for my 3/8” dados but for anythin smaller I made my own ZCI.
View Bradpaulp's profile
Bradpaulp
7 posts in 1731 days
#10 posted 03-18-2014 07:59 AM
I just picked this saw up and very happy with it minus the weird insert plate. Anyone ever make a zci for this? Be very happy to see results and how you did it.
View CharlesC's profile
CharlesC
2 posts in 1275 days
#11 posted 06-16-2015 07:55 PM
That drop in router table is brilliant! I’m going to do the same on mine. I can make a jig to slip over the normal fence so I can get a split fence and zero clearance for the router bits.
I got this saw off of craigslist for $125 a few weeks ago and have really been enjoying it so far.
My only problems have been:
1. There was a warning sticker on the clearance plate that stuck up just enough that the stock would get stuck on it.
2. There is a little part on the left of the blade that has an indentation in the table top and a silver sticker on it. This made it unlevel with rest of table and had just enough of a lip to catch the stock. A little painters tape over it fixed it.
3. The anti kickback pawls kept binding and made it hard to push stock through. I feel much safer with them off than on.
