| Review by DAN | posted 601 days ago | 3231 views | 0 times favorited | 22 comments | ![]() |
- Shopsmith Joint Matic - Horizonal Router
- Brand: Shopsmith | Category: Router Accessories
First I must say that the photos are not mine. I surfed the net and found them.
This review is for a discontinued tool. Can’t buy it new anymore, but if you find one, grab it. It is a rare tool.
Shopsmith originally sold for $999. There is currently one for sale on craigslist.org in Dallas for $600
I bought mine on eBay a few years ago. It came with a Porter Cable router base that fits my 690.
Even came with the optional Shopsmith stand.
I got one heck of a bargain. Paid twice as much for the shipping as I did for the tool and still spent less then $100.
It is a handy tool. Does a good job for cutting mortices and have used it for a variety of other configurations and special cuts.
Below is an excerpt from a web description. http://shopsmith-tool-hunter.blogspot.com/
Shopsmith Joint Matic – Horizonal Router
This tool was originally sold by the Strong Company and after Shopsmith purchased the rights to make it they took it into their R&D department and added dust collection and removed one lead-screw and the synchronizing bicycle chain. After a few years this tool was retired. There is one important thing that you need to keep an eye out for if you are shopping for the Shopsmith version of this tool. You’ll want to make sure that the plastic platen that moves the router up and down isn’t cracked where the knob that adjusts the backlash out of the lead-thread, threads into the platen. If you are buying one online ask the seller to tighten the knob gently and snap a photo of this detail from above. It it’s cracked, take a pass.
Mine works fine and the dust collection is the best I ever seen for a router.
22 comments so far
GaryK
home | projects | blog
9536 posts in 885 days
posted 601 days ago
Thanks for the review. I’ve never seen one before.
motthunter
2079 posts in 696 days
posted 600 days ago
i imagine it works well, but how safe is it to use?
-- making sawdust....
teenagewoodworker
2482 posts in 665 days
posted 600 days ago
thanks for the review. there is another horizontal router table that is now manufactured. if i can find the link i’ll post it.
teenagewoodworker
posted 600 days ago
oh here it is http://www.eaglelakewoodworking.com/index.htm?mlcs.htm
Dick, & Barb Cain
7041 posts in 1196 days
posted 600 days ago
Nice find Dan.
MLCS sells the same one as Eagle.
Someday I’ll show you a picture of the horizontal router I made.
This is the one MLCS sells.
3710 posts in 876 days
posted 600 days ago
Hi Dan;
I recall considering one of these I guess close to twenty years ago, (complete guess). I never did buy it, and now I kind of regret it.
25803 posts in 1297 days
posted 600 days ago
Never seen one. thanks for the review.
DAN
6454 posts in 880 days
posted 600 days ago
safety is always a concern.
it has an exposed router bit.
all I can say is I’m very careful and have never been hurt using it.
I always follow these rules:
never use power tools when you are tired or sleepy
never use power tools under the influence of alchohol or other things like drugs … legal or otherwise
If it doesn’t look safe or feel right … there is always another way.
tenontim
1319 posts in 641 days
posted 600 days ago
This is a horizontal mortiser I made, based on a plan by Yeung Chan. I modified the depth adjustment mechanism to use a bolt, instead of clamping to the work bench. I’ve used this for years and it works very well. The only thing different about it’s use is, you feed the work with the rotation of the bit, instead of against it. Other wise you get a lot of splintering. I made the sliding table a little tight, to prevent it from sucking the work into the bit.
-- Tim -- http://tmuli.com
motthunter
posted 600 days ago
looks like something easy to make and use. I may have to take a crack at it.
DAN
posted 600 days ago
I also found a Shopsmith miter gage that fits the Joint Matic. ... Ebay ,, where else. I’ve also made jigs and special fixtures for different projects.
dlcarver
260 posts in 627 days
posted 600 days ago
My uncle use to have a shopsmith way back when (in the 1950’s and ‘60”s. He could change it into a table saw, a lathe, router, and I think it even jointed and planed smaller pieces. I remember, it was a fabulous machine, but every time you wanted to do something, you had to tear down that set-up to go to the other one…...then if you had to come back to that set-up…....whewww….what a waste of time etc.
Nice post Dan
Dave
-- Dave Leitem,Butler,Pa.,http://dlcarver.etsy.com
pinkiewerewolf
46 posts in 622 days
posted 599 days ago
Shopsmith makes an OverArm Pin Router. (ignore the Pin part for now because it does so many more functions)
http://www.shopsmith.com/ownersite/catalog/rm_overarmpinrouter.htm
The beauty of the OPR is that it functions in the horizontal configuration also.
-- John, Nor-Cal, shopsmith.net/forums
Woodshopfreak
390 posts in 639 days
posted 598 days ago
Cool. Is this like the multi router that David marks uses? I don’t get why the horizontal-ness of it helps to do things, what is the main reason of haveing it mounted horizontaly?
-- Tyler, Illinois
pinkiewerewolf
posted 597 days ago
WSF, I think joinery (like dovetails) is a great function for the horizontal routing systems. You can see the work, it isn’t underneath your work piece.
BTW, I received my Overhead Pin Router from Shopsmith yeasterday morning.
When I get the opportunity, I’ll experiment with it in the horizontal mode.
reible
21 posts in 658 days
posted 170 days ago
Hi,
Just happened to be looking at some reviews tonight and spotted this one. The second and third photo just happens to be one that I took of my Joint-Matic. A little surprised to see them here!
It was one of those machines I wanted but couldn’t afford back then. Thought I’d never get one but then came e-bay. Horizontal routers are a good addition to a shop in my opinion and this happens to be one of best. If you happen to get a bevel miter gauge with it you can do dovetail corner picture frames. Of course it does all the other stuff that you want from a horizontal machine too.
I have posted quite a few photos over at the shopsmith site if you would like to see more.
BTW it does have a guard that covers the bit as someone seemed a bit worried about that. And as was mentioned the dust collection is great! It is normally a stand alone tool but I have adapted mine to sit like a SPT on end of the shopsmith or I can clamp it in my B&D workmate.
Hey it has only been 427 days since someone last added a post…
-- Knight of the Shopsmith
DAN
posted 170 days ago
Hey Knight ! I remember surfing the internet looking for photos, must have found your webssite.
It is a fun tool to use … I’ve built a few jigs for it and when my mortising machine broke, I used it allot. It cuts very repeatable joints. Worked very good for small pieces too. I have a Porter Cable 690 always attached to it. Sits right next to the band saw. Bought mine on ebay. I got a steal.
Ron43334
3 posts in 113 days
posted 113 days ago
Dan,
I just acquired a Joint-Matic at an auction in Shelby, Oh for $60. It appears to have been unused or only used once or twice. A bevel miter gauge was included and a home-made jig came with it. I don’t know hat the jig is for, maybe it’s described in the manual. I have ordered a manual from ShopSmith. I also have a Rockler router table and a Jet Mortising machine. Is the Joint-Matic a good substitute for the Jet mortising machine? The reason I ask is that I am considering selling the mortising machine so to free up funds for another purchase. Also, since you seem to be very knowledgeable regarding the Joint-Matic perhaps you could log on to the ShopSmith website and share your expertise with the SS forum members.
Sincerely,
Ron
DAN
posted 113 days ago
Hey Ron
Keep the mortising machine too. The joint-matic will do all sorts of things, but I use my mortising machine also. You got a real bargain for 60 bucks. They sell for much more then that on ebay.
Regards
DAN
welcome tolumberjocks
Ron43334
3 posts in 113 days
posted 113 days ago
Dan,
Do you have the bevel miter gauge for you joint-matic? The reason I ask is I know a fellow who has one, but does not have the joint-matic. He wants a joint-matic, but since he doesn’t have one I could ask him if he would sell the gauge if you are interested.
Ron
PS – Sorry to hear about Pratt Whitney. Have you found a new job?
16982 posts in 474 days
posted 113 days ago
Looks like a cool tool. It looks like it does much of what my Multi router does at a whole lot less money.
DAN
posted 113 days ago
I’d still like a multi router …. >grin<
