| Review by YooperCasey | posted 671 days ago | 1013 views | 0 times favorited | 11 comments | ![]() |
- Black & Decker JS600 Type 1 Jig Saw
- Brand: Black & Decker | Category: Jig Saws
This is a tool I wish I never would have purchased. I would have prefered to get by using a coping saw and dealing with a blister or thirty. This tool generates such a level of frustration that it is amazing that the same engineers who design Dewalt, Porter Cable, and Delta could allow such a monstrosity to leave the lab.
This particular unit has a quick blade release, variable speed, variable orbital action and an adjustable base.
The quick blade release does release the blade quickly and hold it solidly. I have yet to have a blade pop out. Unfortunately the entire saw has to be held at a 30 degree angle to the cutting line in order to get a straight cut. Remove your finger and stop the cut for a second and the blade resets itself to some other magic angle. The vertical cut is also at an angle, probably about 5-15 degrees. In thicker materials it is almost comical if it wasn’t so frustrating. I can only attribute this to a loose blade, or possibly a misadjustment in the blade carrier. Unfortunately the unit is thread locked to such a point that no adjustment is possible.
The variable speed is also quite interesting. I installed a new shower surround yesterday and used this little gem to trim a panel to size. We wanted a nice, slow, smooth speed to reduce gumming on the surround. The variable speed would work on the first three inches or so, then it would randomly move up or down, before finally settling on maximum speed about four inches later. So for the remaing 50 or so inches the blade was moving at full speed gumming up the cut. We ended up using my japanese pull saw to finish all the panels, it was faster, smoother and required less cleanup.
The variable orbital action does what it says. Lots of orbital action for splintered, fast cuts. No orbital for slow, splintered cuts. And right in the middle for sort of fast splintered cuts.
I haven’t tried the adjustable base yet but I can imagine some new sort of frustration will result.
This tool is of such poor construction that it fails at even the most basic task it has been designed for.
I can’t state how crappy I believe this tool to be. I plan on using it for some fiberglass cutting before fishing season which destroys any jig saw in short order. Though I’m sure even then it will frustrate.
-- Casey, Engineer, Escanaba, MI
11 comments so far
rikkor
home | projects | blog
11338 posts in 766 days
posted 671 days ago
Doesn’t look heavy enough to use as a boat anchor, although it has a nice place to tie the rope.
14157 posts in 1052 days
posted 671 days ago
thanks for the review!!
mrtrim
1700 posts in 772 days
posted 671 days ago
hope you keep buying those black and decker tools , im really enjoying your reviews ! lol great job
Woodturner
3 posts in 671 days
posted 671 days ago
If you bought it at a reputable store, they should take it back, at least for store credit
YooperCasey
58 posts in 724 days
posted 671 days ago
Unfortunately I don’t think any reputable stores sell B&D :)
WoodWright
20 posts in 968 days
posted 668 days ago
Black & Decker OWNS Delta, Porter Cable, DeWalt, etc., but these are NOT all one company in terms of engineering etc. B & D has famously been trash for decades by now, although it started out with reasonably good quality, WAY back when. Nothing B & D is suitable for use—go either P-C or DeWalt, and if I understand correctly there may be two grades of DeWalt, so ask first.
Skil is another good choice for the few tools they still make, if you can find them—they are now OWNED by Bosch but are not Bosch.
I didn’t think anyone fluent in English was still unaware that B & D is garbage, but since I was wrong, they all thank you for the heads-up!
I’m just annoyed that any American company would stoop so low, but it is what it is.
Dadoo
1725 posts in 882 days
posted 667 days ago
I too have had a B&D Jigsaw (a 20 y/o, much older version)...it was extermely noisy and ran at only one speed. I could get more accurate cuts with a demolition (Sawzall) saw than this B&D. But it still works. I bought a new Craftsman Pro version and gave the B&D to my son.
Zuki
1232 posts in 968 days
posted 666 days ago
You gotta love the honesty in these reviews
YooperCasey
posted 666 days ago
So kind of you Dadoo to pass along those heirloom tools to your son :)
25788 posts in 1292 days
posted 666 days ago
I think I’ll go buy a BD Jig Saw. A need something to be mad about.
sharad
703 posts in 696 days
posted 632 days ago
A very outspoken review.
Sharad
-- patanjali
