Grizzly G0675 10" Jointer/Planer Combo Review
Review by earik posted 09-25-2012 05:08 PM 26966 views 1 time favorited 13 comments Add to Favorites Watch
Grizzly G0675 10" Jointer/Planer Combo Review No-picture-s No-picture-s Click the pictures to enlarge them
Hi Everyone,
I’ve spent a lot of time reading posts on this site and making use of the many reviews here, and wanted to post my experience with the new Grizzly 10” jointer/planer combo since there are still not a lot of reviews on these yet. I bought this piece of equipment a couple months back without having owned any previous Grizzly tools, and based a lot of my decision on the tons of positive reviews I’ve heard about Grizzly, especially in the customer service department. I’ll rate each of the following items on a scale of 1 to 5, with 5 being the best.
DELIVERY: 5 out of 5
The jointer weighs almost 300lbs, and comes delivered on a freight truck. I opted for the additional liftgate service so I wouldn’t have to fight with the crate myself. We live up a long steep gravel driveway, so I had to load the crate into the back of my SUV and drive it up to the house. The driver was awesome though, and not only helped me get the crate up into the truck, but also offered to ride up to the house and move it into my garage. First time that’s ever happened! Saia Freight rocks.
PACKING: 2 out of 5
The jointer comes in a crate made of very thin plywood. After unloading the crate from the truck, moving it into the car, and unloading a second time into the garage, the crate gave up the ghost and fell apart all on it’s own. It’s really only a step above a thick cardboard box, and I think a lot of my problems later on were due to packaging that really didn’t work very well. Seriouly, $20 more per box, and I bet Grizzly could save a lot of money on support calls. I’d give it 1 star, but nothing was broken, so it gets an extra star for that. There were some cosmetic scratches on the fence, but nothing bad enough that I felt like I needed a replacement.
ASSEMBLY: 4 out of 5
The jointer itself sits on a stand which you have to assemble first. You won’t be able to lift the jointer by yourself, so this is a two person job. I live out in the woods, and didn’t want to have to call anyone, so I managed to use a car jack and bricks to raise the whole thing up, then slid it over on 2×4s and lowered it down onto the stand myself. Not too much trouble, but would’ve just been easier if another person was there to heft it up with me. The tables were covered in protective oil, which takes 30min to remove with mineral spirits. You also have to assemble the fence and cutterhead guards and connect them. Took about 2 hours to do the whole thing.
FIT AND FINISH: 3 out of 5
You can see how Grizzly manages to get their price as low as they do on some of these tools. Basically, they cut corners in areas that they feel don’t specifically contribute to performance. So cheap packaging, plastic parts, various plastic pieces cut by hand rather than by machine (you can see where the lines waver). The bottom part of the fence on the outfeed table must be a little higher than the fence on the infeed side, since they are at different heights when jointing. If you look under the outfeed side, it reminds me of a freehand routing job – pretty much straight, but wobbly here and there, and definitely not crisp and clean. Yeah, it works, but no, it’s not pretty, and doesn’t give you a feeling of fine engineering and craftsmanship that you’d get with more expensive brands.
ALIGNMENT: 1 out of 5
I had quite a few alignment issues with this machine. Basically, everything that could have been out of alignment with this jointer was. First off, the fence wasn’t 90 degrees, and the 90 degree and 45 degree locks don’t actually lock in at those degrees. You’ll definitely need to straighten this yourself, and every time you adjust the angle of the fence, you will have to confirm that it is really at the angle that you think it is. Because of this, I don’t think I’ll ever use the 45 degree angle feature.
The limit switch, which turns the engine off when the outfeed table isn’t properly locked, wasn’t adjusted properly and wasn’t working. This resulted in a call in to tech support, and I received instructions on a fix. Unfortunately, the fix meant I had to take the jointer off it’s stand, flip it over on it’s side, then adjust a nut with a socket wrench to tighen everything back up. Given the amount of effort I made with my bricks and jack to get the whole thing set up in the first place, it was a bummer to have to redo that.
The tables weren’t parallel, and resulted in concave joints. The fix here is to first make sure the outfeed table, cutterhead, and infeed table are all parallel. This is easier said than done, and the manual even warns you that if you have to bother with this step, you need to have some patience because it can be a difficult job. The issue is that the infeed table is held up by 8 bolts on slotted holes, and to adjust the table you have to loosen all those bolts, hold the table up in the exact position you want it to be, and then tighen all the bolts just right. It’s a major pain in the rear to do it properly, and it took me two tries to get it close enough where I was happy with the result. Even so, I’m still slightly, slightly off of perfect, which is irritating.
The other difficult part about doing the table adjustments is that the side panels to the jointer need to be taken off, and they have a bit of flex in them. So taking them off is easy, but that flex means that it’s actually hard to line the bolts back up with the holes when you are trying to put the sides back on. This part was almost as annoying as getting that infeed table parallel.
After it was all said and done, it took me a good two weeks to get this thing properly set up to the point where I could actually use it. I blame a lot of this on the cheap crating job, but some of it has to do with the design as well. I dread the day I have to move the jointer, as the only way to lift it up it by the infeed/outfeed tables, and I’m sure that will mess with the parallelism and make me have to go through the whole process again.
If you are planning to get one of these, make sure to get a feeler gauge set from Grizzly as well, as you’ll need it when it comes time to get your tables coplanar. You need to be able to measure a 0.060” gap, which can be done using two stacked gauges.
CUSTOMER SUPPORT: 5 of 5
As expected, customer support was awesome. John was prompt, called me back every day to check on my progress, and made a lot of personal effort to make sure that limit switch issue got solved. This is an area that Grizzly has covered.
PERFORMANCE: 3 of 5
This machine comes with a European style blade guard, but it’s a little cheap and rickety. When jointing, it really only covers the part of the cutterhead you are not using, and leaves the working part wide open. Basically, there’s nothing between you and that 1” or so of blade by the fence. So made sure not to put your hands there! For surface jointing, you slide the blade guard all the way over the cutterhead, and then the wood goes under it while your hands stay above it. So for those tasks, it’s much better. It’s probably because my tables aren’t totally coplanar, or maybe just my bad technique (last time I used a jointer was in high school), but I can’t get clean surface joints at all. There are always cut lines, etc, in weird places. I have to be very careful about where I put weight on the wood, and things work much better if you put most of your weight on either the infeed or outfeed tables, but not both. Planing works well, but there is definitely some snipe, so you have to work with lumber that is a bit longer than what you need so you can cut that part off if it’s too bad, or be prepared to sand it down to fix it. Dust collection works pretty well, although you’ll still find quite a pile of shavings in the planer area after you do any amount of jointing. I think it’s probably just one of the qualities of a combo machine like this.
One thing I should mention is that the fence doesn’t have any way of permanently locking into place. You can push down on a lever to tighten it to the bar to clamp it down so it doesn’t move, but that lever doesn’t have any kind of positive lock, and will loosen itself over time. When you are edge jointing a long board and your fence starts to move on you halfway through, it can be a bit of a surprise, especially if your hands are anywhere near the uncovered part of the cutterhead. I make a habit of cranking down on that lever each time I turn the machine on after having experienced that once.
JOINTER/PLANER CONVERSION: 3 of 5
Converting from Jointer to Planer requires the following steps: Disconnect dust collection hose, remove fence, raise and lock outfeed table in upright position, flip up and lock dust collection assembly, re-attach dust collection, then raise planar table to the appropriate height. To convert backwards, just reverse the process. It takes about 2 minutes to do the whole thing. Disconnecting and reconnecting the dust collection hose is the most annoying part of the process, as you have to fight with the assembly each time as it sticks a little, and I’m wondering how long that plastic connector will hold up to me whacking it on the side to get the thing loose.
OVERALL: 3 out of 5
This machine takes a LOT of tuning to get setup properly, so don’t expect to be using it the same day you receive it. However, once it’s tuned properly, it does a decent job of jointing and planing. You learn to work around it’s shortcomings, and can get it to do the job done to reasonably high tolerances. Grizzly support is pretty great, so they’ll do what it takes to help you get it working if (when) you run into issues. Do I wish I had gone with a higher end unit like the Hammer I was looking at as my second choice? Yes, no doubt, but on the other hand, I saved $1500 by going with Grizzly instead, and that buys a lot of lumber. On the other hand, I’m a hobbyist, and do this for fun, and I really only have a limited number of hours that I can put into woodworking. My time is worth something, and I sure spent a lot of it trying to get this thing to work properly rather than actually working with wood, so if you factor in the value of my time, I’m not sure how much I really saved by going the budget route… If I had to do it over, and if I had to go with Grizzly again, I’d go for a parallelogram-style jointer instead, and avoid the headache of trying to get those tables coplanar. More likely, I’d go with a different manufacturer and get something built to higher standards.
Thanks for reading!
View earik's profile
earik
2 posts in 2306 days
13 comments so far
View Everett1's profile
Everett1
213 posts in 2769 days
#1 posted 09-25-2012 06:11 PM
I was looking at the 12 inch model a year ago
I have a one car garage for a shop so one machine would be ideal to take up less space
I ended up with a grizz 8” jointer and 15” planer as I was fearful of how often I’d have to calibrate and you confirmed that for me
Haven’t had to touch the jointer since I set it up when I got it. Planer just needs a blade sharpening
-- Ev in Framingham, MA
View Tennessee's profile
Tennessee
2893 posts in 2750 days
#2 posted 09-25-2012 06:45 PM
Not a real fan of multi-use power stationary tools, and this seems to reinforce that. I have a Jet 6” joiner that sometimes I wish was 12”, but I get by. I have the Grizzly G0453X spiralhead planer, and the Grizzly G0513X2BF 17” bandsaw, and I have had almost no problems save for the initial motor went on the planer in 20 seconds, and I had to replace it, and a bad manual on the bandsaw which said I had the wrong table, (wrong-figured it out about three hours after I got off the phone with customer support), and four weeks later a new table, (same one as what was on the saw), came in with no way to return it. Certainly Grizzly is cheaper, and they do cut some corners, but for my money, so far I really like what I have.
View dustyal's profile
dustyal
1299 posts in 3710 days
#3 posted 09-26-2012 03:27 AM
Thanks for taking the time to write the review. Much appreciated. I’ve been looking at the combo machines as I need to save space and I am a hobbyist. I have been hesitant due to most of what you mentioned. The Grizzly unit does seem more substantial than the Jet units.
-- Al H. - small shop, small projects...
View cabmaker's profile
cabmaker
1744 posts in 3044 days
#4 posted 09-26-2012 03:46 AM
Now there is an honest review ! But wait a minute, you had lots of alignment issues with your grizzly machine but ordered a grizzly measuring devise to correct them ? Gotta think about that one for a while. I do hope it works out for you. I have never recomended combo machines to anyone, why ? I have had a couple. Enjoy the journey ! JB
View Dusty56's profile
Dusty56
11830 posts in 3923 days
#5 posted 09-26-2012 03:54 AM
Problem with combo machines is that when your jointer doesn’t work , neither does your planer !
I’ve yet to hear anything good about these that would make me want to give up my individual machines.
Nice review , well written and good info : )
View AKAndrew's profile
AKAndrew
53 posts in 3011 days
#6 posted 09-26-2012 05:27 AM
Nice review, thanks for taking the time to write it.
View rawdawgs50's profile
rawdawgs50
82 posts in 3253 days
#7 posted 09-27-2012 03:20 AM
Good honest review. As a grizzly user and fan of their tools, I know there are better machines, even grizzly, out there then what you have. I can not blame you for feeling you would go with another vendor… I would of told them to pick their pos up or send me one that works without making it a career to fix it.
best advice, sell that for what you can and purchase a used planer and jointer standalone. It will be the best decision you could make.
every time you use it it will just bring back bad memories and potentially ruin your ww experience.
you live …you learn. For what its worth the 12 inch version is a far superior machine to the 10 inch. Not even in the same class…..but I would never buy it…unless it was for the jointer ability alone.
View Mainiac Matt 's profile
Mainiac Matt
8609 posts in 2564 days
#8 posted 09-27-2012 07:27 PM
Tough break…. I hate to see anybody sink their $$ into a tool and then not be satisfied with it.
I second the opinion that combo machines are a compromise of both functions.
The only fair comparison is against a similarilly priced combo machine.
And yes… the cheap a$$ crates are a joke…. If you read reviews about some of their machinery tools (10×24 lathe) you’ll quickly realize that 9 out of 10 of them fall apart and cause damage. Grizzly should demand better.
-- I yam what I yam and that's all what I yam
View HorizontalMike's profile
HorizontalMike
7770 posts in 3149 days
#9 posted 10-14-2012 01:41 AM
I ended up like Everett, with an G0593 8” jointer and a 13” lunchbox planer. Thanks for the straight up review, as it does confirm some fears I had when originally deciding on this type of equipment.
View Straightbowed's profile
Straightbowed
717 posts in 2533 days
#10 posted 01-09-2013 04:34 AM
I was gonna buy that jointer but someone at the bears den a few years ago told me no no no no go with the dedicaTED JOINTER YOU WILL HAVE BETTER LUCK so thats what I done, so the rest is history I was told not to buy this combo mach its a pc of crap just sayin
-- Stevo, work in tha city woodshop in the country
Dusty56
#11 posted 01-09-2013 04:45 AM
Think about it …if the planer breaks , you also don’t have a jointer at the same time. That’s why I have separate machines : )
View garberfc's profile
garberfc
57 posts in 2490 days
#12 posted 04-24-2013 04:46 PM
Thanks for the great review.
I’ll never understand why companies continue to sell questionable machinery at relatively high prices now that the Internet / review sites are so wide spread…
View B4B's profile
B4B
163 posts in 1593 days
#13 posted 09-07-2014 03:53 AM
Thanks for the review. I’m currently researching my next tool purchase and this review definitely helps. I’m looking at this and a Jet 10” model at about 1/2 the cost.
Since 2012, have you gone back to further adjust your tables for better precision? Have the adjustments held over time? Has it seem much use between then and now?
I’m looking at a jointer next and can see the value in a combination unit for planing, if designed well. . and for occasional use.
If I do go this route, I know what my expectations should be and that is worth something. As a hobby I can’t really justify the space/dollars for a better machine I will only use occasionally.
-- There's two routers in my vocab, one that moves data and one that removes wood, the latter being more relevant on this forum.
