| Review by Jim Crockett | posted 247 days ago | 317 views | 0 times favorited | 8 comments | ![]() |
- Rockler Two-Way Turner's Tape
- Brand: Rockler | Category: Shop Gear
I don’t know about anyone else, but I find new uses for double-sided tape nearly every time I am in the shop. I have been using Rockler’s Turner’s Two-Way Tape for a couple of months now and have been very impressed. It sticks tenaciously and I haven’t had any two parts I have joined slip when template routing or aligning for installation. I sometimes wonder if I actually need screws and glue with this stuff.
1 inch wide, 25 yards
I gave it four stars because sometimes it sticks too well and is a little hard to separate. Unless you have arms like Popeye, chances are pretty good that you are not just going to pull the two pieces apart! This is good when you want to make sure something doesn’t slip or slide when machining but not so good when you want to get them apart afterward. I’ve never had a problem separating the items by sliding a putty knife between the boards and gently pushing at the tape to separate a corner. Once one corner is loose, the boards can usually be separated by hand.
I also would recommend using small pieces rather than one long strip. I normally use pieces no longer than 3/4” and place them at the corners or other strategic locations, usually 3-4 for small items.
Yes, I would buy this item again and probably will. But a roll lasts a long time.
Jim
8 comments so far
GMoney
home | projects | blog
97 posts in 343 days
posted 247 days ago
That is really funny, because I bought a roll of that tape a couple of weeks ago and just picked it this morning and used a piece! It is great. It’s like a double sided masking tape. I was using a carpet tape with a fiberous core that has more tenacity than is needed for stack cutting etc., so this one is nicer to use.
-- Greg, CT
rikkor
8645 posts in 414 days
posted 247 days ago
I know how handy double-stick tape can be. I’ll have to pick up a roll of this. Thanks for the review.
-- Maplewood, MN
CharlieD
61 posts in 256 days
posted 247 days ago
I recently bought some as well. It is oustanding. Used to mount drawer fronts and had difficulty pulling them off !! GREAT stuff
-- Charlie, Humble, Texas
Big_Bob
33 posts in 249 days
posted 247 days ago
I use the tape a lot as well. I find it grabs a lot better if I clamp the parts together (with the tape in place) for a few minutes before I try to use it.
-- Bob Clark, Tool Collector and Sawdust Maker
juniorjock
364 posts in 305 days
posted 247 days ago
I totally agree Jim. A while back I needed to order a couple of things from Rockler and needed to add an item to justify the shipping charge. It just happened to be a roll of this tape. Every thing you say is true….... a little goes a long way.
-- Make things with wood.
GaryK
8565 posts in 528 days
posted 247 days ago
Double stickey is great stuff. I get DUCK brand carpet tape at Lowes or Wal-Mart. The stuff is fantastic.
cajunpen
5345 posts in 606 days
posted 247 days ago
Handy stuff – a man needs handy stuff.
ShipWreck
40 posts in 293 days
posted 243 days ago
I have been using that same tape for golf clubs for years. I use it for installing grips.
I never even thought about using it for woodworking. I have a 1/2 dozen rolls of it in my shop cabinets.
