Don't Bother
Review by Purrmaster posted 250 days ago 1287 views 1 time favorited 15 comments Add to Favorites Watch
Don't Bother No-picture-s No-picture-s Click the pictures to enlarge them
I am usually a big fan of Harbor Freight and have gotten a lot of good stuff there. But these sanding discs are truly atrocious.
Using a random orbital sander, it took about 2 minutes to wear the grit away. On softwood construction lumber. After sanding an area about 10 inches wide by 48 inches long (just one side) the grit was worn completely away. I don’t know whether the grit doesn’t adhere well or if there is simply not enough grit.
Please note: I have only used the 60 grit discs. I don’t plan on buying other grits for obvious reasons.
View Purrmaster's profile
Purrmaster
401 posts in 265 days
15 comments so far
View Dallas's profile
Dallas
1881 posts in 659 days
#1 posted 250 days ago
I have had mixed results with HF sand paper. Some wet/dry I bought was very good and some I bought didn’t last 10 minutes.
I have had good luck with their sanding cylinders.
Craftsman on the lake
2022 posts in 1610 days
#2 posted 250 days ago
I use mirka Abranet paper. It’s a see through mesh. The good about it is that it doesn’t clog and I’m still using grits two years later. It just doesn’t seem to wear out. The downside is that being mesh the hooks can poke through and wear away causing you to need to replace your sanding disk. You absolutely need to use the hook/loop buffer pad that they sell that goes between your sander and the paper. Do that and this stuff works great and literally takes forever to wear out.
-- The smell of wood, coffee in the cup, the wife let's me do my thing, the lake is peaceful. http://gagnerwebsite.com/Deceiver/Craftsman_on_the_lake/Craftsman_on_the_lake.html
View Deycart's profile
Deycart
208 posts in 430 days
#3 posted 250 days ago
I also would not bother with the regular paper below 400 girt. Just garbage. Especially the 320 400 girt that is light grey. One rub and most of the grit came off. Just trash.
View gfadvm's profile
gfadvm
6655 posts in 862 days
#4 posted 250 days ago
Another vote for Abranet. Considering how long it lasts, it is the cheapest sandpaper I have ever used. The backing will wear out before the grit. I then save it to use by hand.
Purrmaster
#5 posted 250 days ago
I’ve heard good things about their sanding cylinders. As well as good things about their oscillating spindle sander. Their garnet sandpaper is terrible. I haven’t used their aluminum oxide or silicon carbide (wet) sandpaper.
View redryder's profile
redryder
1591 posts in 1274 days
#6 posted 250 days ago
Not disc’s but I once purchased the Harbor Freight “sanding blocks”. Without a doubt the biggest ripoff I have ever purchased for my shop. I couldn’t throw them in the garbage fast enough…................
-- mike...............
View Tennessee's profile
Tennessee
1097 posts in 687 days
#7 posted 250 days ago
The cylinders work pretty well, about as good as the stock ones you buy at HD.
The discs I have had poor use, and the belts come apart due to the cheap piece of tape they use to hold it together, but I have also found this tape on some belts sold at Lowes. It’s a blue tape, just look inside the belt and see if it is there.
-- Paul, Tennessee, http://www.tsunamiguitars.com
View Richard's profile
Richard
503 posts in 863 days
#8 posted 250 days ago
I have a lot of stuff from HF just due to the price , but when it comes to sandparer or saw blades I just don’t bother as most every thing in the catagory I have gotten was mostly junk.
I do have the 12 SCMS and the 12 speed benchtop drill press and the older plate joiner and all seem to work just fine for me except the plate joiner fence is a pain to ge set right but outher than that it cuts slots just fine for me.
View Howie's profile
Howie
2449 posts in 1095 days
#9 posted 249 days ago
I buy all my disks from Klingspor. Never had a complaint.
-- Don't rollerskate in a buffalo herd
View Stephenw's profile
Stephenw
240 posts in 558 days
#10 posted 249 days ago
Harbor Freight abrasives; like sanding with burned toast.
-- http://www.garagebulletin.com/
View Dusty56's profile
Dusty56
10557 posts in 1860 days
#11 posted 249 days ago
” like sanding with burned toast.” LMAO : )
-- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did.
View Everett1's profile
Everett1
202 posts in 706 days
#12 posted 248 days ago
Kingspor vote from me love that stuff
-- Ev in Framingham, MA
Purrmaster
#13 posted 247 days ago
Klingspor makes good stuff. I only have one complaint and that is for their sheet sandpaper. Their 2000 grit paper seems to be significantly rougher than 3M’s 2000 grit sandpaper. I’ve used them both for sharpening tools and the Klingspor 2,000 leaves a rougher finish. It even feels rougher than 3M’s silicon carbide 2,000 grit.
I’ve had some of their discs for the Work Sharp and they are great.
View lumberjoe's profile
lumberjoe
2401 posts in 421 days
#14 posted 244 days ago
the only sandpaper I get at HF is the 1” wide fabric backed rolls. It comes in a box from 150 to 400 grit. Looks to be the EXACT same paper woodcraft sells for 26$ except it’s 10$ at HF. It lasts reasonably well. Their ROS stuff is plain junk. Klingspor all the way.
-- http://www.etsy.com/shop/KandJWoodCrafts
View RussellAP's profile
RussellAP
2394 posts in 459 days
#15 posted 225 days ago
I haven’t noticed that their abrasives are any worse than most out there. I just ordered some mirka Abranet paper from Amazon. I use a lot, LOT, of sandpaper on three 5” ORS ranging from 40 grit to 220.
-- Failure does not stop me, it makes me try harder..... because I'm crazy.
