| Review by americancanuck | posted 282 days ago | 1423 views | 0 times favorited | 5 comments | ![]() |
- Kreg rip cut saw guide
- Brand: Kreg | Category: Other
I found this to work very well with one problem. The little red pointer that is used to line up the saw blade with the scale on the beam covers up the numbers making it impossible to see. a good solution would be to make this peice out of clear plastic. Other than that I found this to be acurate and easy to use. It’s a godsend when ripping down full sheets of plywood. Storage with the saw connected is a problem so I have been removing the saw after each use. The problem with this is that the next use requires another time consumeing set up. All in all I FInd this to be a very worthwhile buy.
5 comments so far
redryder
home | projects | blog
1616 posts in 1299 days
#1 posted 282 days ago
Agreed on all points….............
-- mike...............
noweyrey1
20 posts in 966 days
#2 posted 282 days ago
Accurate review. One solution I have for storage and set-up is I drilled holes for the set screws at the front of my saws plate and have a small bolt at the back of the jig so the saw lines up the same each time its attached. It also helps to eliminate the pins slipping and the saw shifting while in use. Works better than I thought it would for $35 though.
QuickWay
77 posts in 779 days
#3 posted 280 days ago
I bought one of these and love it. I keep a cordless saw permanently attached. It’s sure makes cutting sheet goods a lot easier. Hats off to Kreg.
-- Bill Native Texan
Purrmaster
406 posts in 290 days
#4 posted 278 days ago
How well does it work for ripping not very wide solid boards? I’m looking for a way to make accurate rip cuts with my circular saw, as I don’t have a table saw.
americancanuck
77 posts in 807 days
#5 posted 278 days ago
purrmaster. it should work all right. set up would be difficult and safety in the cut might be a real consideration. definately not a replacement for even a cheap table saw.
