| Review by SirFatty | posted 259 days ago | 1689 views | 2 times favorited | 6 comments | ![]() |
- Leecraft HT-1 Zero Clearance Insert
- Brand: Leecraft | Category: Tablesaw Accessories
I’ve always made my own zero clearance inserts, and on the old Craftsman table I used previously, it was a pain to make them correctly. With my new Porter-Cable saw, it looked to be even more painful. This time around, a purchased ZCI seems like the way to go. A quick search showed one manufacturer appearing multiple times in the search results: Leecraft.
A couple blanks were purchased from, and fulfilled by, Woodcraft via Amazon.
When received, I was surprised by how heavy and solid these phenolic inserts are. They sit completely flat and when the leveling screws and tension screws are adjusted, there is absolutely no movement. The only thing about this particular insert is the odd color and pattern on it. The second is more of a DayGlo orange.
A piece of 2×4 was clamped across the insert and then the blade was slowly raised until it was fully through. A similar process was followed for the dado cutter, but the blade was raised much slower. It took about a minute to raise the 3/4” dado up through the phenolic material.
Several test cuts were made and it worked as expected, well worth the price of $25 (each).
6 comments so far
Tedstor
home | projects | blog
929 posts in 805 days
#1 posted 259 days ago
Yep. I have the same brand insert for my Crafty TS. A great product.
lumberjoe
2401 posts in 420 days
#2 posted 259 days ago
I agree, I have a few for my R4512 (regular and Dado). The price is hard to swallow, but there is no doubt these are quality inserts. Does your saw not have a riving knife?
-- http://www.etsy.com/shop/KandJWoodCrafts
SirFatty
324 posts in 384 days
#3 posted 258 days ago
Lumberjoe: indeed it does.. but I did not cut the insert to accept it yet.
Cosmicsniper
2150 posts in 1331 days
#4 posted 258 days ago
I bought two a these recently myself. Very good inserts…much better than my handmade ones.
-- jay, www.allaboutastro.com
lumberjoe
#5 posted 255 days ago
The inserts for the R4512 were pre-cut for the riving knife. I wonder if there is a “with riving knife” option for your saw
SirFatty
#6 posted 255 days ago
Jumberjoe: not that I’m aware of, but there were instructions with the insert detailing how to cut the slot (they recommend a jig saw).
