Works on Miter Saws and Biscuit Joiners
Review by pintodeluxe posted 08-17-2012 05:05 PM 3021 views 2 times favorited 5 comments Add to Favorites Watch
Works on Miter Saws and Biscuit Joiners No-picture-s No-picture-s Click the pictures to enlarge them
Great product!
Helps corral the dust at the miter saw (2-1/4” hose on a 12” Dewalt compound miter).
This switch completely changed the performance of my Dewalt biscuit joiner. Previously, the joiner would clog with sawdust, which required disassembly to clear. Also the chips would fly in your face. Now the vacuum is convienent to use, and I never see a single chip when biscuit joining. I use the small flexible shop vac hose from Woodcraft for the biscuit joiner.
It works great.
View pintodeluxe's profile
pintodeluxe
5815 posts in 3048 days
5 comments so far
View 47phord's profile
47phord
182 posts in 2472 days
#1 posted 08-19-2012 12:07 AM
How does it work, do you plug it into an outlet? If so, what is the max amperage? It sounds useful.
View cutworm's profile
cutworm
1075 posts in 3028 days
#2 posted 08-19-2012 01:27 AM
Been looking at this for a while. I guess it’s time to get one. Or two.
-- Steve - "Never Give Up"
pintodeluxe
#3 posted 08-19-2012 06:45 PM
47phord,
It plugs into the outlet, and you plug a tool and a vacuum into the device. It works with a 15 amp miter saw.
It makes biscuit joining tabletops so much more enjoyable.
View thenetdog's profile
thenetdog
10 posts in 2494 days
#4 posted 08-20-2012 08:20 PM
Specifically, the box is a relay. When you draw current through the tool outlet it switches on the other outlet so your vacuum runs with the tool, and then when you shut off the the tool it waits another 5 seconds and then shuts off the vac. This saves you from ever turning your vacuum on and off by hand, very nice. I believe it is 15A so not good for table saws, but great for routers and miter saws for sure.
View Sarit's profile
Sarit
550 posts in 3374 days
#5 posted 09-07-2012 10:29 PM
One of these days I need to get my electrical engineer co-worker to design me a relay so I can auto-start the vac on another circuit. Running a big shop vacuum w/ a 15 amp tool on the same circuit often trips the breaker.
