| Review by shipwright | posted 318 days ago | 1876 views | 3 times favorited | 18 comments | ![]() |
- . Ergo-Grip paint scraper, Item # 04512
- Brand: . | Category: Gluing and Finishing Supplies
I’ve posted two home made veneer hammers in the past as projects. This one comes right off the shelf and it works better than either of my previous attempts. The only modification needed to transform it from the Clarke Kent of the paint scraper world to the Superman of the affordable, available veneer hammer world is that you need to spend a few moments at the bench grinder dulling it down and smoothing the edge.
The main requirements of a good veneer hammer:
1) It must allow you to put serious pressure on a small area. This tool is ergonomically designed to allow you to exert the serious pressure needed to scrape stubborn paint. It has a thin edge to get the force onto a small area and it comes in a variety of size for different veneering applications….... Check!
2) It must have angled edges at the ends of the blade to allow hammering in tight corners….. Check!
3) It should be easy to clean…...Check!
I’ve used this one on a few jobs now and find it a very good substitute for the much harder to find and expensive ones sold as veneer hammers
If you ever need a paint scraper, just loosen the screw and rotate the two sided blade!
I would like to have given it five stars, which it deserves as a pressing tool but real veneer hammers have some advantages in terms of holding heat and actually “hammering” veneer pins.
It comes in lots of sizes and shapes, all of which would work depending on the job at hand.
You can look at them all here.
Note: This company is unaware that they produce a veneer hammer.
IMHO, Paul
-- Paul M ..............If God wanted us to have fiberglass boats he would have given us fiberglass trees. http://prmdesigns.com/
18 comments so far
Viking
home | projects | blog
857 posts in 1392 days
#1 posted 318 days ago
Shipwright;
What is a veneer hammer?
-- Rick Gustafson - Lost Creek Ranch - Colorado County, Texas
bunkie
411 posts in 1344 days
#2 posted 318 days ago
Shipwright,
Very cool. I especially like that it still works as a scraper.
Viking,
A veneer hammer is used to press veneer against the underlying substrate. Imagine a very dull blade set at 90 degrees to the handle. To use it, apply the glue to the veneer (it works best with hot hide glue), set the veneer in place and draw the blade of the veneer hammer on the surface of the veneer applying as much pressure are possible. You really don’t use to to “hammer” the veneer, just to apply pressure. The design allows a tremendous amount of pressure to be applied. It’s like using a J-roller, although one should never use that tool to apply veneer as it can damage the surface and it doesn’t apply nearly as much pressure.
-- Altruism is, ultimately, self-serving
Schwieb
1136 posts in 1658 days
#3 posted 318 days ago
I’m of the opinion that there is really nothing new in the world just reapplications of the best of what works and a universal struggle to accomplish a required task. I’ve always been intrigued by how different cultures solve the same problem. At times I have felt guilty about using something that I already had and modifying it into a tool that would do what I needed as well or better and faster than if I had tried to make it. Not so much anymore. There are so many remarkably well designed tools available, that are relatively cheap compared to our time. None the less I always appreciate a fresh approach on things. I can see how this thing could work as well or better than “conventional” veneer hammers.
-- Dr. Ken, Florida - Durch harte arbeit werden Träume wahr.
Viking
#4 posted 318 days ago
Thanks Bunkie!
I am a veneer sub-amateur!
shipwright
3479 posts in 995 days
#5 posted 318 days ago
Actually hammer veneering can be done only with hot animal glue as it is dependant on the seal created at the edges of the veneer by the quickly cooling glue. As the glue cools and gels, it seals the edges. No more air can get under the veneer. Therefore if you “hammer” the air out you have exactly the same effect as a 100% efficient vacuum bag…....................but way cheaper and easier.
Here’s an excellent video.
grizzman
5465 posts in 1500 days
#6 posted 318 days ago
i always enjoy finding a tool in disguise…lol..there usually much cheaper, but as you say, they might not be designed to hold the heat as you mention, but some things can be worked with, thanks for the review here and showing a tool that can be used for this application…i love saturdays…finding a new tool makes them even better…
-- GRIZZMAN ...[''''']
bunkie
#7 posted 318 days ago
Shipwright, I didn’t know that. I’ve yet to try using hot hide glue, but now I think I’d like to give it a try knowing that there’s a cheap, effective veneer hammer out there. Thanks for sharing this!
Can you melt hide glue in a double boiler? Or do you really need to have the hot pot? I seem to remember that we’re talking about a melting point somewhere between 140 and 200 degrees farenheit, is that right?
Roger
9479 posts in 1001 days
#8 posted 318 days ago
Very interesting, and thnx for the link/s
shipwright
#9 posted 318 days ago
bunkie, Yes you can get away with a water bath in a kettle with a thermostat.
The “Rival” available at Walmart in the USA (but not in Canada) is a classic. They are around $10.
200 degrees will kill your glue. 140 is optimum.
Keep an eye out. I’m preparing a “hide glue for beginners” blog.
grizzman
#10 posted 318 days ago
oh goodie, i need that blog,i have two cans of hide glue and have used it one time, and need as much knowledge as i can get on it, i would rather get it from you Paul then say a book, practical experience is the best…ill watch for it…grizz
cathyb
548 posts in 1441 days
#11 posted 318 days ago
I agree with the Grizzman. Paul, it’s high time that you started that book. You know we would all want an autographed copy. With your skills, you could probably have it out by Christmas. Sign me up for a copy please….
-- cathyb, Hawaii, www.cathyswoodworking.com
shipwright
#12 posted 318 days ago
Thank you Cathy, but I’ll leave the book writing to the real experts.
I’m still a novice …. except maybe at building boats.
Douglas Bordner
3907 posts in 2260 days
#13 posted 317 days ago
Glad you posted the Rival solution, what a great deal as opposed to using the 300 dollar model.
Do you have to heat the hammer blade at all?
BTW, I for one would be highly appreciative of that Hot Hide Glue 101 blog. Thank you so much for sharing your skills.
shipwright
#14 posted 317 days ago
Douglas, No the blade doesn’t need to be heated.
The heavy metal hammers hold enough heat to re-soften and re-press little bits of marquetry that you want to adjust or repair.
The blog is here
Douglas Bordner
#15 posted 317 days ago
Thanks!
I have read another person’s bit about using the hot-pot for glue. On his iteration his glue jar is down in the pot so that humidity aids in keeping the glue from skinning over. But as I have veneered not one board with hide glue, and my hot-pot is still in it’s box, I will be the first to admit that I know not from which I speak…
View all comments »
showing 1 through 15 of 18 comments
