This is The ONLY Construction Aheasive to Use
Review by Eric M. Saperstein posted 07-28-2012 03:11 AM 43415 views 4 times favorited 11 comments Add to Favorites Watch
This is The ONLY Construction Aheasive to Use No-picture-s No-picture-s Click the pictures to enlarge them
I’m going to keep this VERY simple … I strayed from this product today and regret it already.
Ignore all other construction adhesives. PL Ploy is the one to use.
It cures in 24 hours as long as the temperature and humidity are within a normal day. It’s much faster in the summer with high humidity and it’s slower in the winter when its cold and dry. This can be adjusted by adding some moisture to the mix (spray a wood surface lightly … before applying)
We use this stuff constantly. It holds to anything, fills gaps, and it can be dyed with transtints.
Liquid Nails is a waste of time and money – watch out they say “DRY” time NOT cure time w/ that product. Some of their cure times is 2 weeks. Who has two weeks to wait for glue to dry??? Not me …
We use this on wood – even rotten wood and it works. Dry antiques – works … concrete / stone – works … it’s flexible also and fills huge gaps in weird situations. This works great when fixing damaged or rotten mortis and tenon joints.
It creates amazing hydraulic pressure – thus you WILL crack something if you put in too much when you have a solid joint. Be very careful when you are making a new piece of furniture. HOWEVER if you have a cracked leg or something with lots of odd nail holes left in it it works great. When you squeeze a joint it will press the adheasive into every open hole or crack and ooze out securing as it dries.
I’m just rambling this – not making the review sophisticated or throwing in a ton of side stories. This product simply WORKS … and the competition has given us every possible failure. Loctite poly has never failed me …
-- Eric M. Saperstein, Master Craftsman www.artisansofthevalley.com
View Eric M. Saperstein's profile
Eric M. Saperstein
766 posts in 3446 days
11 comments so far
View Binn's profile
Binn
93 posts in 3152 days
#1 posted 07-28-2012 03:50 AM
Eric,
You are right! This glue is great, I built back in December 2011 ext. stairs for my sister and used this for glueing the 6×6 post to concrete and to the risers and 2×12’s making the ,I cannot remember what they are called , you know the boards the steps are nailed to. Anyway I used this PL glue and it sets up quick and holds. I glued every tread so there would not be any cupping even with the screws, and this was treaded lumber. As of today the glue has held, no cupping with the treads even after 8 months in the sun , heat and cold. You know how bad treaded lumber cups and twist, but her stairs look great. I also used heavy deck screws (the blonde color screws that have the star head) with all the wood NO NAILS, all screws and PL polyurethane glue. I also bolted all the post to the 2×12’s that make the deck frame. I told my sister that her house would blow away before her deck and stairs and she lives in New Orleans. I think the Liquid nail is ok for interior work if you have time for it to dry, but NOT outdoors . If I can figure how to post photos I will.
-- Barry, Louisiana
View ChrisForthofer's profile
ChrisForthofer
150 posts in 3265 days
#2 posted 07-28-2012 05:00 AM
I’ve used this stuff several times outdoors in my projects and it is the best stuff going imho. Holds like grim death, stays flexible enough to move with the wood through the seasons and bonds most anything to anything. 2 thumbs up for me too.
-- -Director of slipshod craftsmanship and attention deficit woodworking
View b2rtch's profile
b2rtch
4863 posts in 3246 days
#3 posted 07-28-2012 09:18 AM
In general Loctite products are excellent.
The very first time i worked with a Loctite product was in 1967 in France.
I have quite en experience with them and they never let me down.
-- Bert
View rasp's profile
rasp
75 posts in 2456 days
#4 posted 07-28-2012 12:58 PM
I like the PL Premium 9000 Advanced or whatever it is. near instant tack, great hold. installed a lot of wall panels and other architectural details with this stuff. Also fills voids nicely, but large blobs take longer to fully cure
don’t bother with ‘no more nails’ and other imitators
View Edziu's profile
Edziu
151 posts in 3249 days
#5 posted 07-29-2012 01:37 AM
I’ve used this stuff and it is the real deal. I swear by it for so many applications. I even reinforced a crack on a piece of cast iron with this stuff, doesn’t look pretty, but it does the job.
View Boneski's profile
Boneski
143 posts in 3331 days
#6 posted 07-31-2012 11:23 PM
Loctite products are excellent. I hope they sell this stuff in Australia. “No more nails” or “No more skill” as I like to call it is only an average product at best.
-- Blinded by brilliance
Eric M. Saperstein
#7 posted 08-01-2012 02:19 AM
Well the white liquid nails goop still isn’t fully cured – obviously w/ a TWO WEEK cure period and this all started on Friday. ... But it didn’t come flying apart when the one leg I put together with it was chucked up and spun on the lathe.
Side note – Kinda weird, last time these table legs turned was some time around 1906 … 106 years later I split them at every seem, glue them up, and return them. More on that project later …
Now the PL stuff – all fully cured and solid. No issues … even the stuff I put together YESTERDAY. Actually some small pieces glued this morning were ready to machine this evening!
View knarfc's profile
knarfc
1 post in 1031 days
#8 posted 02-14-2016 01:08 AM
I am now trying to use this Loctite PL Fast Grab Premium adhesive, but it is very hard to get it out of the tube. I have looked for a date so I can tell if it is past its use date, but no date on the tubes to be found. My hands hurt from trying to squeeze the caulking gun. I’m gonna return these 8 tubes and go to another store and see if they are any better. Knarfc.
View builtinbkyn's profile
builtinbkyn
2653 posts in 1138 days
#9 posted 02-14-2016 01:49 AM
Did you pierce the seal after cutting the nozzle? There should be an aluminum foil seal that needs to be pierced with a nail or the pointy thing on your caulking gun or nothing will come out.
I am now trying to use this Loctite PL Fast Grab Premium adhesive, but it is very hard to get it out of the tube. I have looked for a date so I can tell if it is past its use date, but no date on the tubes to be found. My hands hurt from trying to squeeze the caulking gun. I m gonna return these 8 tubes and go to another store and see if they are any better. Knarfc.
- knarfc
-- Bill, Yo!......in Brooklyn & Steel City :)
View shanewoodsman's profile
shanewoodsman
1 post in 907 days
#10 posted 06-16-2016 08:25 PM
Will this product work for gluing up some polystyrene (foam) ceiling tiles to cover a popcorn ceiling? I want to cover up the popcorn instead of scraping it, but need to find a glue that will adhere to the popcorn surface and the foam tiles I want to use to cover it – please let me know if this product can handle that! Thanks!
View Stiefel463's profile
Stiefel463
1 post in 434 days
#11 posted 10-02-2017 10:18 AM
Warrior and the Sting. And also the WWE 2K18 Standard Edition There are rumours that Kurt Angle.
