| Review by PurpLev | posted 304 days ago | 1586 views | 6 times favorited | 12 comments | ![]() |
- CGW 6" Aluminum Oxide Grinding Wheel
- Brand: CGW | Category: Sharpening Accessories
I got my VS grinder a while back after getting my lathe to sharpen my HSS bits and for the longest time was plain disappointed by how long and how hard it was to shape and sharpen those bits, and always considered replacing the factory supplied wheels with after market replacements…
I should have done that much sooner!
There are many alternatives out there, and I ended up going for the blue and white aluminum oxide wheels from CGW (at the moment of this writing sold by wholesale tool company at wttool.com). I was looking at the equivalent Norton wheels and since I have a 6” grinder (should have gone for the 8” but then again I was trying to minimize expenses as always) and the 6” wheels are not as easy to find for the grits I was looking for and all from 1 supplier (getting from multiple suppliers ends up doubling shipping) I ended up going with a different brand since WWT had everything that I needed in 1 place, and it was by far cheaper than any WW related site offering similar wheels (I think at half the cost).
Shipping (CGW and WTTOOL)
I read on amazon and other places where other brands of wheels were purchased from that the wheels were shipped loose inside a box that was too large causing the wheel to shift and move about in the box which ends up being chipped. CGW packs their wheels individually in a tight box which protects the wheel (see pic #2), more than that, WTTOOL packed 3 wheels in a protected wrapper and packed that tight in a larger box with added cushions to even better protect the shippment – BRAVO!!! I was pleasantly surprised.
Mounting
while the website does not specify this (unknowingly as to why…) the wheels come with telescoping bushing to fit the 1-1/4” bored wheels on grinders with shafts of 1” / 3/4” AND 1/2” (mine) diameter – since wwtool did not mention this on the product page, I was planning on making those myself, but did not mind NOT having to do that at all.
vibration and turning
I am not sure if it’s the bushing or the wheels themselves, but they added significant vibration to the grinder as compared to the factory supplied wheels. I may try to replace the bushings, and/or readjust the wheel prior to locking it again to see if this can be eliminated completely. After truing the wheels the vibration reduced, but not gone completely. I may need to true them a bit more which might do the trick as well. they seem to only start vibrating when I’m running the grinder at full speed (VS) so for now I’m running it at 80/90% which takes the vibration out. (-1 point in the score here)
cut performance
this is where I was blown away. compared to factory wheels, these wheels cut FAST! I got 36x and 60x for roughing (blue wheels) and 120x for finishing (white). I figured If the 60x cuts fast enough, I won’t be using the 36x unless I must. compared to the 36x factory wheel, this 60x blue wheel cuts WAY faster (I am guesstimating x10 faster) – and more importantly – WAY cooler. whereas with the factory wheel I’d have to dip in water every 1 second, these can cut for a good 10 seconds before it gets too hot to hold – significantly better!
I was able to shape the HSS bit seen in pic#3 in a matter of about 1 minute, whereas with the factory wheels it would take me 10-15 minutes to get it done from a square blank. major improvement.
Bottom line
These wheels cut fast, cut cool, and I was able to get the 3 wheels for what other WW places would charge you for just 1. regardless, these are a major improvement over factory wheels, and I would highly recommend getting those factory wheels replaced sooner than later (and if you don’t care – I have 2 factory wheels for you that I will never use)
12 comments so far
home | projects | blog
34370 posts in 2569 days
#1 posted 303 days ago
Great review Sharon.
BlankMan
1487 posts in 1522 days
#2 posted 303 days ago
Thanks for the info. I’ve been looking for good wheels to make HHS tools for my lathe. Mostly for radius ones, for fillets and grooving for like o-rings and such.
-- -Curt, Milwaukee, WI
Wildwood
346 posts in 303 days
#3 posted 303 days ago
I have been a proponent of saving money on sharpening and sharpening supplies since started turning. Back then, friable wheels from all manufacturers bought for not much money including shipping. I suggest shopping sales, and check best price on shipping too, or free shipping. If in a turning club look into buying grinding wheels by the case.
Everyone has a grit preference you need a medium wheel for repairing & changing bevel angles on turning tools. I would not go lower than 46 grit medium coarse wheel. It is true for fine wheels I like 80 grit wheels for re-sharpening. Others prefer 100 to 150 grit fine wheels.
Best friable wheels for wood turners have medium hardness of I, J, and K. If can afford SG wheels they are top of the line for woodturners. Normally a K wheel last longer than either I or J, lot depends upon how often you sharpen, and pressure applied while sharpening.
Even though wheels differ from one manufacturer to another, still think price important factor in determining your choice.
Not sure if it matters whether you buy, white, blue, or pink CGW (Camel) wheels all seem to be K-grade. Have used both white & pink CGW wheels and had no problem with them.
A nice primer on grinding wheels including installation and safety:
http://pacificgrindingwheel.com/index.php?option=com_docman&task=doc_view&gid=38
-- Bill
eddy
885 posts in 1533 days
#4 posted 303 days ago
thanks for the review i have been looking at getting these wheels from the local woodcraft store for a little bit
just was not sure of quality i feel better about going out and getting one now
-- self proclaimed copycat
CL810
536 posts in 1157 days
#5 posted 303 days ago
Thanks for the post Sharon. I just compared pricing and the savings are indeed significant.
I also recently purchased a PC VS grinder. Interestingly, my vibration was significantly reduced when I replaced the mfg supplied wheel with a blue one. Otherwise my experience has been the same.
-- "It's amazing how much can go wrong when you think you know what you're doing."
ssnvet
1557 posts in 497 days
#6 posted 303 days ago
+1 for Wholesale Tools…
I’ve been getting their sales flier for a year or so now and have used them for metal working tools….
Didn’t even think to price grinding wheels with them…. but I will now!
Thanks for the review.
-- Matt, Pine is fine, but Oak's no joke!
gfadvm
6635 posts in 859 days
#7 posted 303 days ago
When I was making LOTS of bits and spurs I bought all my abrasives from our local WT here in Tulsa and was always well satisfied but had the vibration problem with some and not others. I just assumed the adapters weren’t true/centered.
ssnvet
#8 posted 302 days ago
ordered a 120 white and a 60 blue today…
thanks again for the review
PurpLev
7749 posts in 1817 days
#9 posted 302 days ago
ssnvet I think you’ll like it, works great for HSS. let me know if you feel any different. am curious to get others opinions.
Roger
9191 posts in 973 days
#10 posted 301 days ago
Thnx for the review, and also thnx Wildwood Bill for that link.
Jimbo4
710 posts in 931 days
#11 posted 299 days ago
PurpLev, I bought the same wheels from Woodcraft, and they were so out of balance my whole workbench did a dance ! Took them back to Woodcraft to exchange – they wouldn’t. Gave me a new set of bushings – didn’t work.
Bought new Nortons from Craft Supplies – work perfect ! Just from that experience, I will never buy CGW again. Bad taste – probably – but all it takes is once.
-- *Arachnoleptic*: The frantic dance performed just after you've accidently walked through a spider web.
beech
5 posts in 201 days
#12 posted 163 days ago
Thanks for your review and so many insightful comments from the community.
A use this company in Philadelphia who always help me with my questions and get me the best products.
Check them out at AA Abrasives
They have a great grinding wheel selection.
