Danish Oil vs. Danish Oil: Deftoil vs. Watco Brand
Review by Manitario posted 304 days ago 3097 views 0 times favorited 9 comments Add to Favorites Watch
Danish Oil vs. Danish Oil: Deftoil vs. Watco Brand No-picture-s No-picture-s Click the pictures to enlarge them
Most of the finish on my projects involves Danish oil; it is a simple, easy to apply finish and wipe on Poly can be applied if further protection is needed beyond what the poly content of the DO provides. Most of the big box stores carried “Watco” brand, so growing up it is what I watched my father use, and then what I used when I started into woodworking. Over the last 6 months though I’ve found it increasingly difficult to find DO in big box stores, maybe the crackdown on VOC’s or maybe it just doesn’t sell quick enough. Regardless, I’ve had to start buying “Deftoil” brand of DO. The application instructions are very similar between brands:
Watco “Flood surface. Keep wet for 30min then wipe off unabsorbed stain. Reapply finish and let sit for 15min then wipe completely dry.”
Deftoil “Keep surface wet for 30min reapplying as necessary as stain is absorbed. Wipe dry after 30min.”
I’ve found out the hard way that if you follow the Deftoil instructions you’ll cry little oily tears as the wood surface will continue to weep finish for the next week, leaving a splotchy, uneven finish. I’ve tried this on walnut, cherry and maple with similar crappy results. The Deftoil DO seems to work best when applied as a wipe on poly; very thin coats and let dry completely between coats. My guess is that the poly content of the Deftoil is higher than the Watco brand. I’ve never had a problem with the results from applying the Watco according to instructions. Anyways, the Deftoil finish looks good when applied in very thin coats, just wish I hadn’t had the frustration of finding this out the hard way.
2 stars for making me sand down a bunch of stuff I tried finishing according to instructions.
-- Rob, Sault Ste. Marie, Ontario
View Manitario's profile
Manitario
1862 posts in 1049 days
9 comments so far
View lab7654's profile
lab7654
184 posts in 413 days
#1 posted 304 days ago
Always good to have more than one option, just in case Watco becomes unavailable. Watco danish oils have served me great as well.
-- Tristin King -- When in doubt, sand it.
View Tennessee's profile
Tennessee
1089 posts in 680 days
#2 posted 303 days ago
My local Ace Hardware carries all the Watco products, that is where I get mine. Never even saw Deftoil.
-- Paul, Tennessee, http://www.tsunamiguitars.com
View mbs's profile
mbs
968 posts in 1106 days
#3 posted 303 days ago
I had the weeping experience with watco. After 2 days of repeated drying I shipped the product to Florida and when it got there the finish looked horrible. The finish had weeped and dried on the surface. I took some 600 grit sandpaper and wet sanded the surface with watco then wiped it down with clean rags and everthing was fine. It wasn’s much effort or cost to do it but it was worrisome until I finished it. Ironically, I talked with someone who told me to switch to Deftoil becasue they never had that problem.
Both Watco and deftoil are readily available at local stores.
-- Sorry the reply is so long. I didn't have time to write a short reply.
View dustyal's profile
dustyal
1125 posts in 1641 days
#4 posted 302 days ago
I’ve had the weeping effect using several oil products… I was just over applying thinking I was following directions.
I’ve learned the hard way, regardless of product, to apply in multiple thin coats. I can usually stop at three… rubbing the second coat out with 0000 steel wool.
-- Al H. - small shop, small projects...
View Jim Bertelson's profile (online now)
Jim Bertelson
3335 posts in 1330 days
#5 posted 302 days ago
Thanks for the review. So far, I haven’t had any problem with WATCO, and I have used a lot of it over the years. I find it harder to get big cans of it, but it still is available here. Last time I bought it, I went to a paint speciality store, and bought 3 gallons of assorted types.
-- Jim, Anchorage Alaska
View Willardz's profile
Willardz
51 posts in 476 days
#6 posted 302 days ago
I use Watco danish oil all of the time. Home depot in the Atlanta area now carries it in the small containers. Before the only places that had it were Woodcraft, and Rockler
-- I have Carrie, food, shelter, and wood to turn. What else do I need? Zeke Willard
Willardz
#7 posted 302 days ago
Never tried Deftoil or seen it, but glad it is there if Watco dissapears
View Mauricio's profile
Mauricio
5102 posts in 1317 days
#8 posted 299 days ago
Good info!
View OSU55's profile
OSU55
12 posts in 155 days
#9 posted 25 days ago
I’ve used both brands with success. I found the weeping about the same with both. I don’t use either anymore. It’s cheaper and you get a tougher finish just using polyurethane, and not the “wipe-on poly” stuff – it’s just thinned regular poly. About any of the box store brands are fine – the thicker the better really – you get more actual product for your money. Application is much the same as with the “oil finishes” – Thin it 25-50% with mineral spirits, spread it on with a brush, sponge, whatever, and let sit for 5-10minutes. Keep flooding the surface where absorbed, and wipe off. If it gets sticky, just flood more on and it will wipe right off. You can wet sand with paper, steel wool, scotchbrite. 2-4 coats will do – the surface is completely sealed and you will just be wiping off all of the product. Select your sheen accordingly. Can be mixed with any solvent stain for some color.
