Work well, annoying to adjust
Review by lumberjoe posted 06-25-2012 02:47 PM 2090 views 0 times favorited 5 comments Add to Favorites Watch
Work well, annoying to adjust No-picture-s No-picture-s Click the pictures to enlarge them
I used two of these for my cross cut sled I just made. At 5.99 each, they looked like a good value. I was unable to find many reviews on line, so I figured I would give them a shot.
The good
They can be clamped down pretty tight to hold the piece in place
They are inexpensive (~6.00)
Everything turns well on the bolt. No stripping
The Bad
I don’t like the design. These have two locking mechanisms. There is a knurled knob at the bottom that locks the bolt to the track. After locked to the track, you slide the clamp on and screw down the knob. It’s very diffucult to get at the little knurled knob without completely unscrewing the top knob and removing the clamp. Also the small knurled knob is 100% plastic – even the threads. I don’t think this was designed to be moved around much.
I should have got these:
I have a few of the bolts/knobs from woodpeckers and they are awesome. Woodcraft only had one of these in stock and I wanted a matching set. There is only one clamping mechanism on the woodpeckers – no need to clamp to the track and the work piece. This makes adjustments A LOT easier.
All in al, the Kreg Trak Clamps work. They hold the piece in place. With something that will inherently be moved often and not just swung out of the way like a track clamp, these require a lot of effort. I will be replacing these on the cross cut sled and finding another use for them where they won’t have to be moved around much. (drill press maybe?)
Edit 7/25/2012
I am bumping these down to 1 star. Both have completely failed. The bolts ate through the plastic threads on both of them. They are in the trash now (but I kept the only thing worth saving, the bolt)
View lumberjoe's profile
lumberjoe
2899 posts in 2485 days
5 comments so far
View b2rtch's profile
b2rtch
4868 posts in 3285 days
#1 posted 06-25-2012 03:16 PM
Thank you Joe.
-- Bert
View toothpickmaker's profile
toothpickmaker
5 posts in 3259 days
#2 posted 06-25-2012 06:21 PM
Rockler makes two T-track hold downs. One is 3-1/2”x3/4” for $5.29. the other 5-1/2”x3/4” for $8.29.
I have a set of the smaller pair that I use constantly on my drill press table. Had them for about two years now. They work great, no complaints. I’ll be picking up the larger set next time I’m in Rockler.
lumberjoe
#3 posted 06-25-2012 09:00 PM
thanks for the tip!, I’ll check those out.
View abie's profile
abie
880 posts in 4007 days
#4 posted 07-03-2012 02:56 PM
Nice but..
I have made my own to match the Incra style and I much prefer to have my own home made clamps..
I am a wood nut.. and enjoy making things like these..
Just my two cents…
-- Bruce. a mind is like a book it is only useful when open.
117417 posts in 3813 days
#5 posted 07-03-2012 03:09 PM
thanks for the review Joe
