Hock Blades Stanley 2 3/8 replacement for #5 1/2
Review by Don W posted 06-21-2012 02:36 PM 9450 views 2 times favorited 21 comments Add to Favorites Watch
Hock Blades Stanley 2 3/8 replacement for #5 1/2 No-picture-s No-picture-s Click the pictures to enlarge them
After restoring some 200-300 bench planes this was my first replacement iron purchase. After purchasing a Stanley type 11 #5 1/2 at a flea market, (Seen here, along with some restoration pictures) i decided to purchase a new iron for the worn out existing one. Since Lee Valley was running a no shipping promotion, I decided to go with the #19P2005, 2-3/8” x 7” Hock Plane Blade.
The plane arrived slightly before I finished the restore. First this is an earlier type 5 1/2 which original took a 2 1/4” blade. I had measured it before ordering and the blade was actually 2 5/16”, so I wasn’t sure which one it really was, and maybe it wasn’t original. I figured removing 1/16” if need be wasn’t an issue, and that exactly what I wound up doing.
These pictures are with the hock blade straight out of the package. First are pine second set are red oak.
While doing the above testing, both for the restored plane and the new iron, I noticed the mouth was a little tight with no allowance for a more aggressive cut. I’ve heard others say no modifications were required for a new Hock iron, so I started doing a little comparison. I went as far as sharpening and putting the old iron back in. It was still very tight. I happened to have 2 other Stanley #5 1/2s in the shop so I started measuring and sure enough, the recently restored plane was much narrower than my other two, and they both have the original Stock irons, so a few swipes with a file to widen the mouth was in order.
I then took the Hock to the DMT’s. The back was perfectly flat, so no work was needed. The majority of work was to get the corners rounded to eliminate the strike marks. Honing was simple and easy. Noting again this is my first new blade I must say its the easiest iron I’ve honed.
So after honing oak shot.
I’m still not an advocate of replacing stock Stanley (or any manufacture for that matter) irons just because it saves some plane tuning time, but if the iron has been sharpened out, and the end is near, I can now recommend the Hock Plane Blades.
View Don W's profile
Don W
19047 posts in 2805 days
21 comments so far
View RussellAP's profile
RussellAP
3104 posts in 2524 days
#1 posted 06-21-2012 02:41 PM
I wonder how well the new steel will hold up?
View CharlesAuguste's profile
CharlesAuguste
126 posts in 2779 days
#2 posted 06-21-2012 02:48 PM
Oh no problem there, that new steel will outlive all of us for sure!
-- "the future's uncertain and the end is always near" J. Morrison
View ShaneA's profile
ShaneA
7064 posts in 2836 days
#3 posted 06-21-2012 02:51 PM
Kind of suprising this is your first one. Especially since WC has had a few of the IBC/Pinnacles without the flat tops : ) on sale for a while. Thanks for the review.
Don W
#4 posted 06-21-2012 02:56 PM
I’ve watched the WC sales and would like to put a new IBC on my 604, but that size never seems to go on sale. I really want to compare the 2.
View AnthonyReed's profile
AnthonyReed
10083 posts in 2678 days
#5 posted 06-21-2012 03:01 PM
Great to get your seasoned opinion on the Hocks Don. I’m glad to hear it worked well for you too.
Thank you for taking the time to post your findings.
-- ~Tony
ShaneA
#6 posted 06-21-2012 03:19 PM
Yeah i have been eyeing the 2” blades too, need those to be on sale!
View mafe's profile
mafe
11771 posts in 3327 days
#7 posted 06-21-2012 08:25 PM
Sure looks sweet.
Best thoughts,
Mads
View Brit's profile
Brit
7605 posts in 3081 days
#8 posted 06-21-2012 08:34 PM
Great review Don. It means a lot coming from someone with your knowledge and experience.
-- Andy - Old Chinese proverb says: "If you think something can't be done, don't interrupt man who is doing it."
View Dave's profile
Dave
11429 posts in 3078 days
#9 posted 06-21-2012 09:37 PM
Don is there a noticeable difference between the feel of the stock irons and the Hock blade? Such as smoother adjustment, chatter and edge holding.
Nice review.
I need some new iron. And Hock is on the list.
Don W
#10 posted 06-21-2012 09:55 PM
Dave, remember my opinion is based on a few minutes of testing, but as for regular use, I didn’t see any difference than a well sharpened stock iron. I’ll post back if that changes as I use it.
View Dave's profile
Dave
#11 posted 06-21-2012 10:24 PM
Thanks Don I am interested.
View Johnnyblot's profile
Johnnyblot
319 posts in 2514 days
#12 posted 06-22-2012 09:11 AM
Hi Don
I wasn’t sure from the pic if you were using a new chipbreaker too?
As I have mentioned elsewhere, when I was with David Charlesworth, he was using his no.5 1/2 with a Hock blade & chipbreaker. Obviously it was ‘highly tuned & honed and worked beautifully. This was the plane he used all the time. So I have no doubt you will be more than happy with your setup.
Cheers
John.
-- Gossamer shavings just floating around the back yard….-Bandit
Don W
#13 posted 06-22-2012 12:27 PM
John, I never had a doubt that I would be happy with its performance. My anticipation came from the thought that a new, thicker blade would really produce an edge unobtainable with a stock iron. We hear so much marketing hype, and many many woodworkers who buy replacement blade for all of their planes, just because they believe they are better, that I’ve always wondered if it was true. I’ve restored a lot of stuff over the years and have developed a need to keep as much original as I can while making the piece as good as it gets. Its often a trade off, but if I can fix an original part, I usually will. I’m betting some day an original vintage iron will find its way back into this plane, because I now know the shavings will be exactly the same. That’s not a knock again Hock, its a fine blade, but so are most of the vintage blades already in the planes. Of course I’m talking pre-wwII when they still put a decent amount of metal in them.
To answer you question, I am using the stock chip breaker. I suppose in all fairness I should test that as well, but I’m betting I already know the answer. For the guy who doesn’t want to be bothered to learn all that is needed in tuning a plane, its probably paramount a new blade and chip breaker be purchased.
I still believe the best results comes from learning how the tool works, and making the tool perfect.
Whew, off my soap box now. I should of had my second cup of coffee first.
Johnnyblot
#14 posted 06-23-2012 10:57 AM
Don- I totally see where you are coming from and I applaud you for it. You are right about the marketing hype! We are constantly led to believe that the latest shiny- whirligig thingy-majig is the absolute have-to-have item!
It is also essential, as you say to master the fundamentals of how and why a tool does what it does.
This is why on the first week of David Charlesworth’s course is spent sharpening chisels & plane blades. Then stripping down your plane, tuning it and reassemble it. My point is this for me was a lesson in what planes should ideally be like. So from then on I’ve strived to achieve the same level (IMHO) as my no:5 1/2 Lie Nielsen, (still my most favourite plane :-)
You are so very lucky that you seem to have an almost unlimited supply of pre-ww2 planes. Here in the UK we pay through the nose and then some- to own those vintage planes.
So the (few) planes I’ve ‘acquired’ have been very cheap Stanley’s from 1960’s era. By this time if there was a short cut to be had- they’d make it. That’s not to say that these planes are useless, it’s just that by the time I get my mitts on them they are rusty (I know preaching to the converted here lol) but the blades are crap and the chipbreakers are worse. I know I can replace these easily ( and cheaply) for approx £30, with a 3mm Quangsheng cutter/chipbreaker. The hard part then is only to find a plane with a good shiny chrome lever cap. They are more difficult to find The rest I can sort out with TLC & elbow grease:-) At the end of the day I should have a plane as good as (almost) my LN.
Off my soap box now and have a cup of tea.
Carry on the good fight mate. I often have a laugh to myself when I remember you and your “heavy luggage”. You must be an airlines worst nightmare? Lol.
John.
View Brit's profile
Brit
#15 posted 06-23-2012 06:55 PM
Is Don travelling in his suitcase now then? :o)
