Decent Bandsaw for the Price...With Some Modifications
Review by lab7654 posted 06-18-2012 03:56 AM 11916 views 0 times favorited 13 comments Add to Favorites Watch
Decent Bandsaw for the Price...With Some Modifications Decent Bandsaw for the Price...With Some Modifications Decent Bandsaw for the Price...With Some Modifications Click the pictures to enlarge them
Let me just start off by saying that this is my first review here on LumberJocks, as well as my first experience with owning a bandsaw. I have to admit, the only other experience i have with bandsaws is operating the industrial-sized Powermatics at my highschool, so my expectations may be high from that, or low from lack of personal experience.
I bought this about a year ago because it was relatively well built compared to the other 9-10” bandsaws on the market. When it first arrived, everything went together pretty quickly without hassle. I took note of the small—but useful—features it included: quick-release blade tension, window for blade tracking, and wheel brush. One thing it doesn’t have is a fence, and that is sorely missed by me. After I wrestled the blade on (first time doing this) I fired it up and cut through countless plywood and 2×4 scraps, making many curved cuts. I soon found out that the stock blade and blade guides were pretty much junk, so I ordered up a 1/2” and 1/8” Timberwolf blade, as well as some Cool Blocks. Here lies my first problem. The manual states that the maximum blade width is 1/2”. This is not true. When the blade is on, it has to ride very far forward on the wheel, with the teeth almost sticking off of it. This is because the top thrust bearing won’t go back far enough to accommodate a 1/2” blade. O.K., good to go from there, right? Wrong. The metal blade guard on the left of the saw is also positioned wrong. Unless you bend it forward like I did eventually, the blade will creep forward enough while sawing enough to hit the guard and make a huge screech, scaring me enough to jump back away from the cut. Oh well… lesson learned, buy a 3/8” or less blade next time. As for the actual cut, the 1/3 horsepower motor does a surprisingly well job of resawing (granted that it was only 3” material, despite the 4” max).
My most recent problem occurred to me when I was cutting a 2×4 into a 3-D reindeer, plunging the blade through the full width of the stock. I was focused enough at the beginning of the cut not to notice, but in the middle of it I realized that the saw has terrible vibration issues, so much that I can barely make out the template lines I had. To finish the cut, I just put a clamp from the table to the miter saw stand I have the saw on. I’m not yet 100% sure what the issue is, but i suspect imbalanced wheels and/or poor tires.
Overall, I think this is a good starter saw if you can modify and replace some things on it, but I hope to soon have a 14” saw in the shop so I can reserve this one for small or very curvy work. I rated it as 2 stars, but it’s a very strong 2 stars and would be 2 1/2 if the system were fraction-friendly.
-- Tristin King -- When in doubt, sand it.
View lab7654's profile
lab7654
266 posts in 2332 days
13 comments so far
View dbhost's profile
dbhost
5747 posts in 3317 days
#1 posted 06-18-2012 04:47 AM
I’m not a huge fan of 9 or 10 inch band saws. I just hope your experience with this didn’t sour you to say a Central Machinery 14” band saw. I have had one for a few years and love it. The OEM blades are garbage, but that is true of almost all band saws… Just swap good blades and cool blocks at it and you are fine…
Of course if you can find a Grizzly G0555X, or better yet a Powermatic on the cheap then go for it!
lab7654
#2 posted 06-18-2012 03:46 PM
I’m considering the Central Machinery 14” saw, due to the mostly positive reviews I’ve seen. It’s either that or one of the cheaper Grizzlys.
View patcollins's profile
patcollins
1687 posts in 2950 days
#3 posted 06-18-2012 05:50 PM
A small saw such as this should only go up to 1/4 inch blades due to the force you need to properly tension the blade. I have a 9 inch skill taht is a pretty decent saw, but made the mistake of buying a 3/8” blade for it.
View Tennessee's profile
Tennessee
2876 posts in 2599 days
#4 posted 06-18-2012 07:50 PM
I believe the 14” Central Machinery saws are just about duplicates of the old Reliant 14” saws, which I bought one in 1999 and it still runs today in my shop. I’ve added a Porter Cable which was a mistake, and soon plan on a large 12” resaw Grizzly, but after adding a set of upper bearings years ago, the Reliant has held up fine. It did poop it’s start switch, which today looks the same on the Central as the Reliant. That is the only thing that gave me trouble, save that I added upper bearing guides.
I paid $299 for my Reliant back in 1999. When I get the Grizzly in a few weeks, I plan on putting the Reliant on Craigslist for $150-175.
I don’t see why you would have any problems with a Central Machinery 14”. But think about putting on upper bearing guides, it made all the difference in stability. In the meantime, have fun with your benchtop. When properly set up with a thin blade, after you get the bigger saw it will make a great small part cutting machine.
lab7654
#5 posted 06-18-2012 08:45 PM
patcollins
The tension mechanism does a surprisingly well job of handling the 1/2” blade, but you are right, smaller blades are definitely better.
Tennessee
I’ve never heard of the Reliant brand… will definitely check them out. The more options the better.
View Dusty56's profile
Dusty56
11819 posts in 3773 days
#6 posted 06-18-2012 11:45 PM
Reliant brand is now extinct…it was sold by WoodWorkers Warehouse before they went out of business.
They often come up on Craigslist.
I also can’t see using a 1/2” blade on your tiny saw.That is the maximum recommended size to use on a lot of 14” saws.
lab7654
#7 posted 06-19-2012 12:18 AM
Yeah, after a bit of research I see that Dusty is right. No hits on any Reliant saws. As for the 1/2” blade again, it does seem a bit odd that a 1/2” blade would work, and it really doesn’t capacity wise, but I have ripped a decent amount of red oak with it and it seems to work fine. The blade itself, a Timberwolf, is superb and probably the only reason I haven’t thrown this saw out the door.
Dusty56
#8 posted 06-19-2012 02:55 AM
The Timberwolves are lower tension blades to start with , so that may be the reason it works for you.
lab7654
#9 posted 06-19-2012 03:02 AM
You’re probably right, although the tension is pretty much maxed out. Not surprising there.
View themelster's profile
themelster
12 posts in 2012 days
#10 posted 10-29-2013 06:27 AM
Anyone know if the Carter Stablizer STD2 fits this 9” band saw?
View Loco's profile
Loco
210 posts in 1834 days
#11 posted 10-29-2013 08:10 AM
Putting a stabilizer on that bandsaw is like putting Centerline racing wheels on a shopping cart.
-- What day is it ? No matter. Ummmm What month is it ? No moron. I paid for a 2 x 6. That means Two inches by six inches. I want the rest of my wood.
Dusty56
#12 posted 10-29-2013 10:44 PM
LOL , Loco : )
lab7654
#13 posted 10-30-2013 03:15 AM
He’s right though, as time goes on I have to really convince myself that tossing this thing in the dumpster isn’t the right thing to do.
