Harbor Freight Scroll Saw
Review by Remedyman posted 345 days ago 4627 views 2 times favorited 11 comments Add to Favorites Watch
Harbor Freight Scroll Saw No-picture-s No-picture-s Click the pictures to enlarge them
It was suggested that I review this product so I figure what the heck, the least I can do is try to add to the community.
I have had the saw for about 2 weeks now. Overall, I think it is a great saw. I have cut plywood and pine with it. I haven’t had the chance to run any hardwood through it yet. It doesn’t cut fast but it is a scroll saw so it isn’t expected to. One thing I have to give it credit for, it isn’t very heavy but it doesn’t jump around my table either.
Pros: Quiet (until you are cutting wood), vacuum port (in front so kind of in the way). I guess I don’t have too many. It is a scroll saw and does what a scroll saw is supposed to do.
Cons: the thumbscrew that holds the foot wants to slide. I figure I am going to put some epoxy or silicon caulk on it. A dab should give it just enough grip to work fine. The dust port doesn’t work with either of my two shop vac hoses so it might not be a standard port. Of course it could be me. So who knows.
All in all, I like it. Especially since I got it for like half of the sale price.
I gave it four stars because there are some features I could see it having but it does exactly what it is supposed to do in my book. Also I would like to point out, that it looks EXACTLY like the Skil Scroll Saw I saw at Lowes without the side light. I expect it to be the same thing.
-- As long as our customers are happy, we have done a good job. Even if we are our own customer.
View Remedyman's profile
Remedyman
47 posts in 362 days
11 comments so far
View ssnvet's profile
ssnvet
1522 posts in 494 days
#1 posted 345 days ago
Looks just like the old dremmel model.
I wonder if the factories in Asia turn the old production tooling around and build the same thing off brand.
-- Matt, Pine is fine, but Oak's no joke!
View MT_Stringer's profile
MT_Stringer
707 posts in 1396 days
#2 posted 345 days ago
“The dust port doesn’t work with either of my two shop vac hoses so it might not be a standard port. “
Duck tape is your friend!
Thanks for the review.
View dbhost's profile
dbhost
4748 posts in 1397 days
#3 posted 345 days ago
I have an old Dremel scroll saw, and was looking at the HF when I found the Dremel on Craigslist… The HF is mostly stamped steel, including the table. The Dremel used a lot of cast parts, mostly aluminum castings, but solid castings no less, including the table… I shied away from the HF due to concerns it would vibrate a lot… Looks like I was wrong on that one!
I am half tempted to see if the table on my old Dremel would fit one of these HF machines if the Dremel dies…
View TheOldTimer's profile
TheOldTimer
183 posts in 1251 days
#4 posted 344 days ago
Do you need a hex wrench or screwdriver to remove the blade from the blade holder? On mine, which is quite old, you need a hex wrench to remove the blade. This is a pain when you need to relocate the blade for another cut or multiple cuts.
-- TheOldTimer,Chandler Arizona
View Eric_S's profile
Eric_S
1522 posts in 1360 days
#5 posted 344 days ago
I have this too. Its not bad for the price but for pinless blades its a real pain to change. There is a guy that machines his own aftermarket attachments for this saw and other brand models to replace the connectors making pinless blades very easy to attach and switch. I’ll find the link for you. Cost around $40
The dust blower I didn’t think was that great either so I bought a much better one from that guy as well although it took some finessing to get it to fit with this model.
Also, the cutter plate sits too deep and has way to large a hole so I replaced with a planed piece of hardware that sits level to the table. After these three adjustments it performs stellar and is still cheaper than high end models.
-- - Eric Indianapolis, IN
Eric_S
#6 posted 344 days ago
The guy I mentioned is Frank Pozsgai. Here is his website…
http://www.pozsgaidesigns.com/index.htm
And here is a direct link to his retrofit parts. The part is actually only $30, #7 listed on this page. It also fits the Dremel model people mention above so yeah they may be similar.
http://www.pozsgaidesigns.com/page0006.htm
He was very good about delivering promptly and I was impressed with his parts.
#7 posted 344 days ago
I was just looking at the saw today at H.F.. I didn’t buy it because I wanted to get a review on it first. I can’t believe it just happened to be the very first review I open the page to. LOL! Thank you for your review. I have a reducer (from my H.F. dust collection system) that will fit that pesky little dust port! Thanks again!
-- It is fun to see where an imagination and two bored saws will get you.
View Tennessee's profile
Tennessee
1089 posts in 680 days
#8 posted 343 days ago
You can buy the adopter for those oddball HF dust collection ports at HF. Hard to find, they put them in a strange area. The ossalating sander has the same silly size port. I bought one of those adopters and my rigid vac fits fine.
-- Paul, Tennessee, http://www.tsunamiguitars.com
Remedyman
#9 posted 343 days ago
I have to again thank the great people of lumberjocks for sharing their knowledge and experience to my advantage.
View Mike Gager's profile
Mike Gager
613 posts in 1432 days
#10 posted 340 days ago
i have one of these saw, i think it does a good job especially for the price. FWIW its also very similar to the ryobi saw at home depot, as well as ones made by rikon, shop fox, jet, rockwell, sealy, atika, scheppach, wen, ledacraft, woodstar, and probably a dozen other names
View jacob34's profile
jacob34
388 posts in 429 days
#11 posted 334 days ago
I had one of these, I did not like it and sold it online, honestly more because I am not a big fan of scroll saws than because it didn’t work.
-- two men walk into a bar the third one ducks, which are you??
