Great cyclonic dust separator
Review by Alexandre posted 362 days ago 2719 views 1 time favorited 10 comments Add to Favorites Watch
Great cyclonic dust separator No-picture-s No-picture-s Click the pictures to enlarge them
The dust deputy is a great dust separator for my Ridgid shop vac.
I gave it 4 stars out of 5 because for a few reasons:
1. It’s really unbalanced without a cart when you move it
2. Its pretty awkward moving it unless you build a cart.
3. Static electricity during dry times is a pain and a hassle as some dust gets in because it tends to stick to the cyclone.
4. The container fills up quickly, probably a 35 gal drum would be nice.
5. The price is pretty high for a piece of moulded plastic and 2 plastic buckets
6. The hose that came with mine
is one of those SUPER HEAVY DUTY hoses that look totally bulletproof, weigh about the same weight as the dust deputy and that make the dust deputy start to sag on the bucket lid…
Otherwise, it is a great addition to my shop.
My Ridgid shop vac is one of those shop vacs that EVEN when the filter is clogged and the drum is basically full, it still has suction
So, After sucking up the usual shop mess from the table saw, router table, mitre saw and sander, the Dust deputy filled up but the vacuum was nice and empty, except for about 1 teaspoon of dust.
Pretty efficient.
Thanks for reading my brief review!
Thanks
Alex.
-- My terrible signature...
View Alexandre's profile
Alexandre
1417 posts in 364 days
10 comments so far
View BigAl98's profile
BigAl98
60 posts in 1212 days
#1 posted 361 days ago
One way around item 2 is to put a weight at the bottom of bucket the dust deputy sits on…a disc brake (used) works really well…mine was a Hyundai 2008.
-- Al,New Jersey - Don't Look At Me I'm Not A Politician
View meikou's profile
meikou
112 posts in 1807 days
#2 posted 361 days ago
Did you get the basic one or the ones with the extra buckets / hardware? You can make it so it attaches to the vac. I lost those bits so I never did :(
View MT_Stringer's profile
MT_Stringer
726 posts in 1403 days
#3 posted 360 days ago
I bought the one with two buckets. It works great with my Shop Vac. I hooked it up to my planer and it captured all the chips with basically nothing actually making its way to the vac. For my small shop (part of a one car garage) it is perfect.
Alexandre
#4 posted 360 days ago
I have the one with the 2 buckets.
Don’t make it attach to your vac, it’s better to build a seperate cart with your DD and your vac.
View b2rtch's profile
b2rtch
2958 posts in 1221 days
#5 posted 359 days ago
This the way I mounted mine:
https://s3.amazonaws.com/ljimg/lvqw0ta.jpg.
It works week but I already had to re-glue the top several times
-- Bert
View 308Gap's profile
308Gap
322 posts in 1176 days
#6 posted 359 days ago
As for the static I wound some copper wire around it and and used an alligator clip to ground it to an outlet. I move mine to whatever machine I’m using and vac the garage floor also. My shop vac filter is over a year old and still looks good. All plastic buckets hold static, you can even wipe em down with a dryer sheet.
-- Thank You Veterans!
View Retrowood's profile
Retrowood
100 posts in 591 days
#7 posted 359 days ago
I believe you can get 6 and 7 gallon buckets with same tops which will give you a bit more room for chips before dumping. Available at U.S. Plastics in Lima Ohio, place sites right next to I-75.
Retrowood
-- Retrowood
Alexandre
#8 posted 358 days ago
Wow, thanks!
I am going to the local dump for a good used 35gal steel drum with a lid.
View MJCD's profile
MJCD
348 posts in 544 days
#9 posted 344 days ago
I’ve had a SDD setup for about 5 months now, and have upgraded the plastic bucket to a industrial recycle bin – heavy-duty ribbed plastic, at about 40 gal capacity. With this, I’ve bolted the SDD to a 3’ diameter 1/2” MDF plate, properly drilled for the SDD attachment, then used EDPM (weather sealant rubber) to rim the can – this creates an air-tight seal. With this, the SDD and my FEIN shop vac can really pull in the chips.
I agree the plastic SDD is over-priced for what it is (the cost to produce); however, it’s a great value in what it does.
MJCD
-- Lead By Example; Make a Difference
View BigPeteCT's profile
BigPeteCT
3 posts in 17 days
#10 posted 16 days ago
I got one of these for Christmas last year. After connecting to my shop vacuum, we built a DIY dust collection system out of shop vac parts and PVC pipe and fittings. The pipe was placed in the rafters with connectors above my stationary power tools, caps for when they were not in use, and all with parts I had. I didn’t spend an extra dime in doing this.
No additional loss of suction with the shop vac, as the bag is virtually empty, and I just empty the cyclonic bucket when it gets full. This thing is awesome!
-- Thank you and tight joints, Peter
