| Review by Tennessee | posted 384 days ago | 2352 views | 0 times favorited | 10 comments | ![]() |
- Harbor Freight 93431 5" Random Orbital Palm Sander
- Brand: Harbor Freight | Category: Sanders
I have to admit, I am a sucker for a good random orbit sander. We all started off many years ago with the square ones that always left swirl marks, and then one day there it was, the round, 5” random orbit sander. My first was a Porter-Cable with the stick-um pad, which soon got a hook and loop system and served me well until the wheel would just start spinning out of control as soon as you lifted it off the wood. They had come down so much in price I bought another, this time variable speed which I never used.
Then I found a Black and Decker on sale, the red one, which in my mind has too big an orbit and is good as long as you want to hog off a lot of wood. I only use it with 80 and 120 grit, then it gets put away.
Then one day in Harbor Freight, I see the 93431 for sale, $22 bucks. I just could not resist.
Pros:
Lightweight, good hook and loop system, good off-on switch, nice thick pad, fairly efficient dust collection system, long cord, easy to hold, wheel doesn’t hardly spin at all when off the wood. No tendency to walk.
Cons:
Motor stunk up a little the first two-three minutes, the cloth bag comes off (very rarely), dust collection system is relegated to the bag with a funny, oval hole, no way to hook on a small vac hose.
I don’t know who makes this, (Emerson?), but this thing hangs in with every other one I own, which is two P-C’s and a B&D, which I use the least.
I’ve probably got about ten hours of sanding on it now, and it performs well every time. If you ae in the market for a random orbit sander, and don’t have a central dust collection system, I’d recommend you go buy one for the lousy $22 bucks, they are still on sale as far as I know.
-- Paul, Tennessee, http://www.tsunamiguitars.com
10 comments so far
lumberjoe
home | projects | blog
2399 posts in 418 days
#1 posted 384 days ago
I have one also. I loved it! Then a month after I got it it started shooting sparks. I did use the hell out of it though, but I have a cheap Ryobi ROS that has held up much longer and is still going. I use it for 60 – 100 grit sanding. After that I get out the PC 330 speedbloc and clean up the scuff marks and finish sand.
-- http://www.etsy.com/shop/KandJWoodCrafts
woodman88
97 posts in 818 days
#2 posted 384 days ago
I had 2 of them that my brother gave me after using one time.I used one of then twice and would not hold my Mirka hook and loop and when it did the swirl marks were terrible. Maybe you got lucky but my experience with most of HF stuff has not been too good
jumbojack
681 posts in 794 days
#3 posted 384 days ago
I have had one for over a year. I use it most every day. Works like a charm. I hit it once a week with a blast from the compressor. I am going to get one or two more soon. I can not imagine being without one. They are too valuable to be without.
dustyal
1125 posts in 1645 days
#4 posted 384 days ago
Can’t complain about mine… I bought one for one purpose only… to do a double car overhead garage door that was in really bad shape Thought I could use abuse this cheap $25 sander and simply throw it away. It’s was abused… but still working fine… I used plenty of 60 and 80 grit paper.
My Dewalt and Bosch sanders are better, more enjoyable to use… but not 3 or 4 times the price better. However, I would still use them for fine woodworking.
-- Al H. - small shop, small projects...
abie
433 posts in 1941 days
#5 posted 384 days ago
Our Shop here at the wrinkle farm bought two and have several others but the HF sander is still cranking along,,
the price was right and PC and DW are all made in China too.
-- Bruce. a mind is like a book it is only useful when open.
eccentrictinkerer
25 posts in 1198 days
#6 posted 384 days ago
I hpe you haven’t trash-canned your Porter-Cable sander.
I had the same problem and found a mod kit from P-C.
If your ROS is fairly new you may just have a broken clutch belt.
Video here
Good luck!
J.D.
Tennessee
1089 posts in 684 days
#7 posted 383 days ago
Hey, J.D., thanks for the tip! I still have that sander, exactly as shown in the pictures, and I know for certain that the clutch belt is NOT THERE anymore. Hard to tell where that thing went!
I’ll be looking into getting another belt and bringing that sander back online!
Thanks again!
Tennessee
Tennessee
#8 posted 381 days ago
J.D., I took my old PC apart and sure enough, the belt was gone. Instead of going to a parts list, I remembered that I keep a full supply of O-rings in house, and some of them are larger. Got them out, one fit pretty good, and it runs like new! Don’t know how long the O-ring will last, but it is a .15 cent O-ring so I don’t care.
Thanks!!
Nighttripper
41 posts in 338 days
#9 posted 266 days ago
Paul,
I need a new ROS…I’m really thinking about picking up the HF for $20…..I just am concerned about the higher grits (220) ? I’m aiming for an elegant finish on a box I just made for my wife and I don’t want to mess it up by being cheap with a sander.
lumberjoe
#10 posted 266 days ago
The short time mine worked, it did a pretty good job. It does vibrate a lot more than other sanders I used, but I was able to get things smooth with no chatter or scratch marks.
