Great Workshop Helper - Horrible Directions
Review by teenagewoodworker posted 257 days ago 215 views 0 times favorited 5 comments Add to Favorites
teenagewoodworker
2143 posts in 308 days
Great Workshop Helper - Horrible Directions No-picture-s No-picture-s Click the pictures to enlarge them
well i just got my second workmate so i figured that i could do a review on this one because it is the newer version (my old one was the one my dad had for about 10-15 years. it is a great little shop helper. it works at a vise, a workbench, and if you put a piece of plywood on it when it is fully extended than i little assembly table. there are many many little uses that you will find for this around the shop. they last a long time as my dad’s did also.the only reason why his broke was that i sawed through it with a circular saw because i forgot to shift it down and i just cut. so i made another top for it and now i have another use for it, i put my miter saw on top of it. even when its broken i can find uses for it. the only reason why i gave it 4 stars was because the directions are pretty bad. but at least they are good enough that i can understand them enough to get the thing together. also a couple of holes didn’t line up so i had to re-drill and the one for the pins in the handle was too small so i had to drill that bigger. otherwise i love this. if i had the change i would buy another one. its just a great little shop helper that you can find hundreds of uses for.
P.S. Also the vise is about (just a guess, trying to remember from when i made a new top for it) 24” long so it can accommodate big pieces and is ideal for locking down the pieces while planing.
5 comments so far
View Woodshopfreak's profile
Woodshopfreak
331 posts in 282 days
posted 257 days ago
I know arn’t these things just great. I have two as well. My dad had the workmate 300 I belive from around ten years ago and I bought one that is really nice, it’s the workmate 375 and it has this little bar that you have to pull and the whole thing collapses in less then five seconds. Then it has wheels to move it. It also holds my 90 pound behemith benchtop jointer, and does fine. It is rated to hold 300 pounds! These are really indespensible and are great to have around the shop. Great review.
-- Tyler, Illinois
View GaryK's profile
GaryK
8565 posts in 528 days
posted 257 days ago
Someone gave me one of those years ago. I still don’t think I ever used it.
View rikkor's profile
rikkor
8645 posts in 414 days
posted 257 days ago
I have my little lathe on one of these.
-- Maplewood, MN
View ZachM's profile
ZachM
38 posts in 245 days
posted 245 days ago
I stick my miter saw on one of these since I don’t have a real workshop.
View tenontim's profile
tenontim
962 posts in 284 days
posted 245 days ago
I kicked one of these around for years, and you guessed it, I didn’t figure out a use for it until I got rid of it. I come up with things it would be handy for at least once a month. Oh, well.
-- Tim -- http://tmuli.com
Bookmark And Share This Page
