DowelMax precision dowel jig
Review by Sawdust2 posted 611 days ago 2343 views 0 times favorited 14 comments Add to Favorites Watch
DowelMax precision dowel jig DowelMax precision dowel jig DowelMax precision dowel jig Click the pictures to enlarge them
I’m making a Futon Sofa Bed for my grandson. While cutting the parts I was 1” short on the upper and lower rails for the end pieces. The difference was merely the tenons, not the space between the stiles. So I called Gil, my friend with the trusty DowelMax, and we took advantage of an alternate way to fasten the pieces.
The DowelMax is finely engineered. You can use it to install any number of dowels in various arrangements. The video that is available gives a great tutorial on how to use it. The only limitation we could find is that the thickness of the wood must be in 1/4” increments. I suppose you could use shims for other thicknesses but it would not be as precise as the milled aluminum shims provided.
In my case we needed to offset the rail 1/4” from the stile. Not a problem. We centered the dowels on the rail and then registered the outside of each piece. Just playing around with the tool we decided, using the Americanism “If one’s good, two’s better” to maximize the number of dowels we used in each rail, the bottom rail being 1” wider than the top rail.
The DowelMax comes with a 3/8”bit and the guides have very little tolerance. You must insert the bit into the guide before you activate the drill motor or you are going to etch the guide. (Unless you have nerves of steel and better hand-eye coordination than this old man.)
The system seems to work best if you slow down the drill speed as you are pulling the bit from the guide. And it also helps to clear the grooves in the bit before you start on the next hole.
Not my tool so I don’t have the exact price but it was in the hundred’s of dollars. Absolute money back guarantee. The owner/designer seems to enjoy talking with his customers and is as helpful as can be.
I’ve used 3-4 different dowel jigs and this is, without a doubt, the most precise and best engineered dowel jig I have ever seen. I was absolutely confident that the pieces would fit together as planned. They did.
View Sawdust2's profile
Sawdust2
1181 posts in 980 days
14 comments so far
View BarryW's profile
BarryW
871 posts in 798 days
posted 610 days ago
I don’t have a dowel jig at the moment…you’ve sold me.
-- /\/\/\ BarryW /\/\/\ Stay so busy you don't have time to die.
View DannyBoy's profile
DannyBoy
442 posts in 757 days
posted 610 days ago
Sounds awesome. I haven’t had the pleasure of using a doweling jig before. I had to do some without once and that is hell. I think I spring for the headache proof version you’ve suggested.
-- He said wood...http://hickbyassociation.blogspot.com/
View tenontim's profile
tenontim
1319 posts in 636 days
posted 610 days ago
I have one of these, made by a different manufacturer. It has a screw adjustment, so it works on any thickness of wood, self centering. I think I got it from Grizzly. I use mine all the time for drilling peg holes in the sides of table tops. Great little tool.
-- Tim -- http://tmuli.com
View GaryK's profile
GaryK
9521 posts in 880 days
posted 610 days ago
Great review. I’ll have to look into one of these.
View John Gray's profile
John Gray
1748 posts in 777 days
posted 610 days ago
Thanks for the post! Your grandson should be happy as the wood is beautiful, couldn’t buy one that nice at the store.
View rikkor's profile
rikkor
11338 posts in 766 days
posted 610 days ago
DowelMax is near the top of my “must have” list.
View Phildo92027's profile
Phildo92027
37 posts in 691 days
posted 610 days ago
I have both a horizontal boring machine and the DowelMAX. If I have to dowel 1/4 or 3/8” material my FIRST choice is the DowelMAX. The accuracy and repeatability of the tool is “spot on”. The is the only choice for a home workshop doweling solution. Not cheap, but worth it!! I have made additional spacers to allow for various setbacks from the edge as well as flush.
-- Phil, Near San Diego, CA
View cajunpen's profile
cajunpen
5970 posts in 958 days
posted 610 days ago
Nice review Lee. I seem to recall MsDebbie singing the praises of the Dowel Max as well. I guess I’ll to put it back on the front burner and give it another look. Something about M&T joints just scare me. Dowel Max might be my best bet.
View Tony's profile
Tony
18 posts in 610 days
posted 610 days ago
When my Dowel Max came I was too impatient to read the printed instructions. I relied on my memory of the internet demo. I drill 5 holes in each piece, inserted the dowels and squeezed all together by hand. It was flush all around! There was no need for the dead blow hammer. I built a work bench with it. Ten dowels per joint, 4 joints per leg set. These 40 dowels all lined up. As with a joints, your lumbers must be jointed and cut square. I’m now working on a cabinet for the bench.
-- Tony, Sacramento
View brunob's profile
brunob
1469 posts in 1061 days
posted 610 days ago
I have a DowelMax. Love it.
-- Bruce from Central New York
14159 posts in 1053 days
posted 609 days ago
not sure what the thickness issue is. You can adjust the tool in so many different ways.
Sawdust2
posted 609 days ago
MsDebbieP it could be that we have used it so little we have yet to discover all that it can do.
View motthunter's profile
motthunter
2079 posts in 691 days
posted 609 days ago
nice review. I also hear that they are great.
-- making sawdust....
View Douglas Krueger's profile
Douglas Krueger
379 posts in 615 days
posted 552 days ago
Now that I have had my Dmax for a couple of months and put it thru some of its paces on several projects and the verdict is that this is a tool that lives up to its advertised capabilities. when used as instructed the dowels match up perfectly each and every time, the times that it doesn’t will always be a ‘duuuuh’ moment. The precision of fabrication and the quality of the metals is top notch. The learning curve is almost none existent as the DVD and book are very easy to comprehend and follow even for a ‘learning’ challenged person such as myself.
It even works in a ‘freehand’ mode, I used it to place a pivoting dowel in a round knoib for a rotating spice cabinet latch and it worked perfectly after doing a little rasping on the dowel to give it free movement in the hole. It has also been used for a ‘thru dowel’ allowing the dowel ends to show and creating an exposed dowel. I have shipped in some cherry, oak and walnut doweling that is used in these applications and use this as a filler plug on top of the ‘real’ dowel to give the desired look.
A couple of things to know, the bit will clog up rather easily and it may take 2 or 3 passes to get to the correct depth. Take time to adjust the hole depths (via the drill bit collar) especially when drilling thru the thickness of a board of 1 inch or less.
The 1/4” dowelling system is well worth the money and allows for some much thinner board applications.
All in all I would definitely buy this tool again and only regret that quality and accurately sized dowels are hard to find in Thailand so I have purchased a LN dowel plate to fine tune the ‘iffy’ dowels purchased here.
It has made assembly a breeze and is definitely a tool that will live beyond my years on the planet. It has gained my respect and I even designed and built a box to house all the various parts (can be viewed in my home page projects)
-- I can so I wood but why are my learning curves always circles
