My Experience (so far) with the Powermatic PM1800
Review by Woollymonster posted 04-07-2012 07:02 PM 11094 views 0 times favorited 24 comments Add to Favorites Watch
My Experience (so far) with the Powermatic PM1800 No-picture-s No-picture-s Click the pictures to enlarge them
Hello! I am not new to forums or new to woodworking, but I am new to THIS forum. I joined mainly to post my review of this saw but looks like a good forum with a lot of information and good people. So hello from Texas!
RobWoodWorker’s post was one of a few reviews that I read (there are only a few out there) before pulling the trigger on this PM 1800 mega bandsaw. Rather than rehashing a lot of the same data, I thought I would just piggy back onto Rob’s post and compare my findings to his. Hope you don’t mind Rob!
My first impression when I saw this thing was the same as his, “this thing was huge”! I first saw one at Circle Saw of Houston, the leading local supplier of “high end” woodworking power tools in the area. Now, Circle Saw ain’t what it used to be, but nothing in the US is. They just so happened to have one of these things in stock. Not on the show room floor mind you, but in the back warehouse wrapped up in a crate, just the way it arrived from the factory.
I have not had any dust collection issues. I don’t have a central dust collection system in my shop but use the Delta 50-850A 1.5 HP, 1200 CFM Dust Collector with Canister. It has way more than the 400 CFM requirement and gets every spec of dust out of the saw.
Rob states: “Alignment is pretty straight forward.” I would agree. This is the biggest bandsaw that I have ever owned but not the first. I also grew up working in mills that used production grade American made power tools. So the whole set up went without a hitch.
Rob States: “Out of the box the supplied 3/4” blade tracked dead on. No adjustments at all.” This was not the case for me. After meticulous set up, I thought I would jump right in there and re-saw a 12” board. I had about a 2’ section of finished 12” select white pine so I moved the fence to split it down the middle and put the factory edge to the fence.
Everything else was set dead on. This time I jointed one side of a 2×4 and re-sawed a 1/8” thick piece of veneer off the rough side. This cut tracked true and the piece was fairly uniform throughout.
I bought this saw for its massive re-saw capability. It will take up to a 1.5” blade.
I agree totally with Rob on all his pros/cons and his suggestions for improvement with the additional issues noted above. His assessment was very thorough and well written. Another exception for me was that I had no issues setting up the rails, fences, and sight gauge. That all went together just fine.
Woolly
Online Manual
Online Demo
Online Video 2
View Woollymonster's profile
Woollymonster
31 posts in 2416 days
24 comments so far
View RobWoodCutter's profile
RobWoodCutter
116 posts in 3405 days
#1 posted 04-08-2012 02:13 AM
Woolly,
I am still happy with my PM1800. I threw away the original blade after just a few cuts.
I did not have any leveling issues like you did. I actually had a custom mobile base made for it from a local welder.
I ended up getting a Magnate m160m112V2 M-42 Bi-metal blade (1-1/2” wide, variable 2-3 tpi) only about $90 from Amazon, if I remember correctly and just use the bandsaw for resaw.
Although it says it can use a 1-1/2” wide blade, (it can) but you have to take the fence guide rail loose to get it on. A 1-1/4” goes on fine, but the 1-1/2” is just too wide.
Rob
-- Rob-Yorktown "Shop's still not done, Tools are bought, Wood is bought, need to find time to start a project.."
View NormG's profile
NormG
6266 posts in 3179 days
#2 posted 04-08-2012 02:32 AM
Wow, what a journey. Hope it improves
-- Norman - I never never make a mistake, I just change the design.
View JohnnyB's profile
JohnnyB
105 posts in 2565 days
#3 posted 04-08-2012 04:40 AM
Your experience would certainly be disheartening. I hope you can get the machine dialed in to perform as you want it to. Incidentally, I think it is not entirely a fair generalization to condemn the quality of Taiwanese or Chinese machinery or other products. I believe they have the capability of turning out high quality work, especially when partnered with American or European companies, but much of their manufacturing is devoted to holding costs down. In the end, the companies that put their names on the machinery, whether it is Powermatic, Delta, or Grizzly, must bear the responsibility for the quality of the products. And not all American made machinery has always been top grade. I used to have an 8” Sprunger table saw…...........
-- JohnnyB - - Sometimes determination can substitute for skill.
Woollymonster
#4 posted 04-08-2012 01:53 PM
RobWoodCutter: I ended up getting a Magnate m160m112V2 M-42 Bi-metal blade (1-1/2” wide, variable 2-3 tpi) only about $90 from Amazon, if I remember correctly and just use the bandsaw for resaw.
Wow Rob! Glad I couldn’t find a 1.5”. The Blade I ordered from Action Industrial was about $100. It only has 1.3 tpi. Hope the cuts are not too rough. More to clean up. I need this machine for re-saw, curves, and things like big tenons and thick dove tails, etc. The factory blade cut some pretty nice dove tails in thin stock using a 7 degree home made guide in practice yesterday. So I will need to be able to change blades periodically.
I am starting a build an a custom Roubo styled workbench. Something I have wanted to build my whole life! Check it out: Benchcrafted
Woolly
View Swede's profile
Swede
191 posts in 3194 days
#5 posted 04-10-2012 07:19 PM
I appreciate your post I had considered purchasing a Powermatic band saw but after reading this I am not so sure anymore. My father told me that Powermatic was overpriced and not made in the USA but I thought…
-- Swede -- time to make some sawdust
View stefang's profile
stefang
16065 posts in 3509 days
#6 posted 04-12-2012 04:37 PM
I am pretty surprised at your experience. I’ve had to clean up the drool after seeing some Powermatic bandsaws in videos, etc. I bought an inexpensive 18” Woodfast bandsaw made in China. It resaws great and does everything I ask of it (except serving cold beer). I am thinking now that I’m even happier with it after reading about your experience so far. I’ve been using mine for a couple of years now and I’m still just as happy with it. Here is a blog I did on it when I got it.
http://lumberjocks.com/stefang/blog/16611
Woollymonster
#7 posted 04-13-2012 01:02 AM
Swede and Stefang,
Your father is right. There are no power tools of any kind made in the USA anymore. All of those jobs have been outsourced long ago. Powermatic over priced? Well so far I would have to agree. There is a lot of steel and iron there but if it can’t do the job then whats the point in spending the extra cash? Conversation piece? I still have not received the 1.25” re-saw blade I ordered from Action Industrial so I can’t’ make any further assessments from my original post. I was considering a Rikon prior to buying the Powermatic. Good reviews from their sponsored sources. But all the “sponsored sources” give good reviews to companies who sponsor them, Powermatic included. I wrote Rikon and asked where their saws were made and got no response.
I would say just get the cheapest tool that will do a satisfactory job and when it craps out, junk it and get another one. What really are your options?
Walter Meier Group is the outsourcing company for Powermatic, Jet, Wilton, and Nortec. So “brand loyalty” and pride don’t exist in my opinion. Stevfang: I too was drooling over those videos too. One of the major factors why I spent over $5K on this saw. But now that I recall there was actually no on in those videos working wood! I will make this saw work one way or the other, even if I have to machine some parts myself and fix some of it’s design flaws. Again, what choice do I have?
Woolly
stefang
#8 posted 04-13-2012 08:38 AM
I remember when the Japanese began selling a lot of stuff to the U.S. not long after the war. It was very poor quality stuff, but they steadily improved, just as Taiwan has done. I think the chinese will do the same if current trends continue. It just takes time. I do think it is a shame that with automation and modern mfg. methods that the U.S. can’t compete. I guess like so many other (European) nations that they have made it too difficult for mfg. firms to survive. That makes me wonder why Germany is the exception to the rule and continues to export high quality goods and still make a profit. Maybe others should take a closer look at their way of doing things. Of course we know one thing, and that is, that quality is still an important factor.
View xylophage's profile
xylophage
70 posts in 2709 days
#9 posted 04-14-2012 04:55 AM
Should have bought a Laguna…..
-- D.A Winograsky
Woollymonster
#10 posted 04-16-2012 12:08 AM
Laguna…. Yeah.
View AHuxley's profile
AHuxley
821 posts in 3497 days
#11 posted 04-16-2012 03:09 AM
First, sorry to hear about your issues, I have been hands on with that saw several times and having not chenged the thrust bearing position left to right I found it a pleasure to use and I am a bandsaw snob.
Second, blade length should NEVER be an issue, if you are buying blades from a source that only sells certain lengths you are almost surely over paying. Find a local (Houston will have a ton) or internet (Spectrum Supply is excellent) industrial supply that welds from bandstock, better bands, cheaper prices and just the length you need.
Third, regarding band choice if you are planning tall resaws and want the best finish possible one of the carbide tipped blades is mandatory. Bimetal blades will have set teeth and though they are one of the most cost effective solutions even compared to the durability of carbide they will not leave the finish non-set carbide teeth will. The very best of the lot is the Laguna Resaw King, think what you want about Laguna this is an area they shine. Second and third on the list would be the Lenox Trimaster and Woodmaster CT. None of these three blades are cheap but they certainly are unmatched at the job of resawing. I have never been put off by crappy stock blades on bandsaws, they ship with them to keep the upper wheel from bouncing around and possibly doing damage. None of the saws come with a good blade (unless you pay extra for it) the high-end Italian, Austrian and US built saws come with junk too but generally when they are sold the vendor gets an order for a good blade and loads that on, or either throws it in as part of the deal. Think about it, most good table saws don’t ship with a blade.
Fourth, sorry to hear you paid so much for the saw, that saw along with most Jet/PM stuff goes on sale several times a year and residential liftgate shipped (which is included in PM prices) usually runs a little less than $3,400.
Finally, if you are totally unhappy and are able to get your money back consider Agazzani or Minimax. Both these saws are built in Italy and have a serious following. My Minimax MM20 20” saw bests the PM in just about every area with even more resaw height and costs less than you spent.
As an aside you can buy most any woodworking machine still made completely here in the US (TS, DP, jointer, planer, bandsaw etc) but they are priced significantly more than your PM1800 and thats the reason they rarely come up in forum discussions. I have several US and Asian made PM machines and have been happy with all of them. I don’t grouse about the fact they are made in Asia now simply because if they were made in the US I wouldn’t be able to afford them and I have a fairly healthy WWing budget. Case in point I own a PM 141, arguably the best cast iron 14” bandsaw ever made. The last time it was listed in the PM catalog was I think 1989 (still US made) at the time the list price was over $1,900 for a fully functional saw (you could still buy it sans motor etc, like the old ala carte days). That saw would easily be over $3,000 now if still built in the US but I doubt very many or any would be sold to hobby woodworkers at that price or even the 1989 price. For the folks that complain about Asian machines I simply say call Northfield make an order for what you want (they have option lists as long as Porsche) and make sure your credit card can handle the shock.
In the end I think you will be happy with the saw, it is the closest the Asians have come to matching the Italian saws but it is indeed not perfect. Getting one of the premier carbide resaw blades will make a boat load of difference!
xylophage
#12 posted 04-16-2012 06:12 PM
I just want to add one more comment….Taiwan is part of China….? I really don’t think it matters weather a machine is made in Taiwan or China proper. What matters is the standards that the parent company holds to their manufactures to.
-- D.A Winograsky
View sawtooth01's profile
sawtooth01
1 post in 2407 days
#13 posted 04-16-2012 08:06 PM
I signed up for lj just so i could respond to your review. I work in a mill shop where among other things, we cut undereds of book matched skins for acoustic guitars. So I know a thing or two about re/sawing. In our shop we have a 24”/24” mini max and a 24”/24” Laguna. The saw of choice is the Laguna, but the Mini max is not a bad machine. They are almost identical machines in every way. I think they might even be made by the same manufacture in Italy. The only reasons i prefer the Laguna is, it has about 1.5 more horse power than the mini max, and it tends to cut smoother with less hesitation and vibrations. I have had experience using Powermatic bandsaw among others. I’m sad to say they dont even come close to machines like Felder, Mini max, and Laguna. I would take AHuxly’s advice and return it. I don’t know what you paid for your’s, it list for $5,000(WOW). For $400 hundred dollars more you could get the 24”/24” Laguna. You would get 6” more re/saw and 1 horsepower more. I hope what ever you do things work out, good luck.
AHuxley
#14 posted 04-16-2012 10:11 PM
@xylophage although the basis of your post is true, in general China handles the lower specced machines and Taiwan handles the higher specced machine, as a broad generalization it works but there are exceptions
@sawtooth Laguna saws are built by ACM and Minimax saws are built by Cantauro they as well as Agazzani are built within a stones throw of each other in Northern Italy. Torbin at Laguna is a big fan of HP and specs the LT 20 and LT24 with 6hp motors the MM come with 4.8hp motors (non-Nema factional size since they are European). The Minimax saws are built significantly heavier and have a triple beam spine my MM20 weighs more than a Laguna LT24/24 and the MM24 weighs about 250 pounds more. I have found the 4.8hp on the MM20 to be fine even with a powerfeeder but would probably want the extra 1.2hp for 23-24” resaws with a feeder. Between the 3 Italians it tends to be a toss up for me, each has its strong points. I bought based on service, support and heavy construction. I also have a LT18 which has been an excellent saw as well.
PM never made a serious bandsaw in the US, PM was really a light weight brand like Walker-Turner and Delta. To best the Euro steel spined saws with a US saw you need to look at Yates-American, Tannywitz, Oliver, Northfield and the like.
Woollymonster
#15 posted 04-18-2012 01:56 PM
Sawtooth01: That is good info. Thanks! What you do really puts a high capacity bandsaw to the test. I don’t see this saw ever being able to cut book matched skins for guitar building (or the like) but hey, I may be surprised when the blade gets here. It has shipped. Action Industrial is slow to fill orders. I have already determined, as others have suggested, that I will return this saw if it will not perform as advertised.
AHuxley: Blade length is NOT an issue. It’s blade width. Anyone that offers high quality blades (carbon steel, bi-metal, etc.), will build you a blade of any length. I had trouble locating one of any kind that was 1.5” in width. I ordered a 1.25” WoodMaster Bi-Metal. But it is of no consequence for the PM1800 because in order to install a 1.5” blade on the saw, you must remove the fence. The opening between the table and fence will take a maximum of 1.25” blade with the fence in place. Another design goof by Water Meier. Houston has pretty much become a Third World Country. If you can’t get it at Home Depot or Lowe’s, you pretty much have to order it. I had Circle Saw (the place I bought the saw) build me a 1.25” blade. It is just plane old spring steel stock because that is all they carry. According to the salesman (who had no woodworking experience), “That is all you need for cutting wood. The others are a waste of money”. Yeah, right! Anyway, the weld on this blade is not square so the blade pulsates fore and aft so badly that it is unusable. The next time I feel like spending all day and $4/gal gas to make the 120 mile round trip into the bowels of Houston, I will go get my $30 back. It is just makes more sense for me to order online.
Thanks for all the good info. Wish I had known this before I bought it!
Woolly
showing 1 through 15 of 24 comments
