Freud Random Orbit Sanding Disks Go the Distance
Review by pintodeluxe posted 04-06-2012 08:32 AM 3830 views 0 times favorited 9 comments Add to Favorites Watch
Freud Random Orbit Sanding Disks Go the Distance Freud Random Orbit Sanding Disks Go the Distance Freud Random Orbit Sanding Disks Go the Distance Click the pictures to enlarge them
Home Depot switched from Norton 3X to Freud abrasive products. I have tried the 120 grit and 150 grit 5” hook and loop disks, and they work very well. The ceramic blend of abrasives keeps cutting upwards of an hour of continuous sanding. I change them out of habbit, but they look like new and are still making sawdust. I didn’t have any disks come loose from either my Bosch or Dewalt sanders. The disks do not load up with dust like some brands. Cost is cheap – a 50 count package is only $20. My only complaint is the “One size fits none” universal hole pattern. They designed it to fit both 5 and 8 hole pattern sanders. I noticed a little more dust in the air, thus the 4 star rating. If they offer this in an 8 hole pattern to fit my sanders, it would be great.
Also tried the freud 36 grit 4”x24” belt on my oscillating spindle sander. It worked well too, and it simply did not load up or clog like the garnet paper does. Very aggressive, which is just what I wanted for rough shaping.
View pintodeluxe's profile
pintodeluxe
5819 posts in 3053 days
9 comments so far
View Lenny's profile
Lenny
1616 posts in 3767 days
#1 posted 04-06-2012 06:53 PM
Thanks for the review Willie. I recently picked up a smaller pack of these (5, I think) in the 150 grit type. I did not use any for an extended period of time so it’s nice to hear that you feel they last well. I am a believer of only having holes that match up to your sander, five in my case. It seems to me that the universal ones give you less sandpaper because of the slots or in Freud’s case, the extra little holes. A friend of mine feels the difference in so minor as to be negligible. I never bothered to do any measuring to see who is right.
-- On the eighth day God was back in His woodworking shop! Lenny, East Providence, RI
View Dusty56's profile
Dusty56
11830 posts in 3928 days
#2 posted 04-06-2012 08:40 PM
Thanks for the review : )
I also prefer the 5 hole that fit my PC sanders , because the 3M ones tend to fill the hook&loop areas with sawdust , and prevent the next disc from holding on as well , and I don’t believe that they collect the dust thru the holes as well as the original style.
View gfadvm's profile
gfadvm
14940 posts in 2930 days
#3 posted 04-07-2012 02:04 AM
Thanks for posting this review. I have been wondering about these but I switched to Abranet and have been VERY impressed (but they are pricier).
View HalDougherty's profile
HalDougherty
1820 posts in 3477 days
#4 posted 04-07-2012 11:00 AM
Thanks for the review. My major woodworking tool is a collection of hand sanders. I have 5 that I use on a regular basis so I don’t change grits, I just pick up another sander. Thanks for letting me know about your find. I’ll give them a try this morning.
-- Hal, Tennessee http://www.first285.com
View rodneyh's profile
rodneyh
147 posts in 2904 days
#5 posted 04-17-2012 09:27 PM
I picked up a 50 pack in 60 and 80 grit (for finer grits, I’m still using my 1/4 sheet sander). Sanded hard with them today using the PC low profile sander on 12 maple clocks I’m building. I used a total of 1 60 grit disk and 1 80 grit disk, and sanded with each of them for a bit over an hour. The disks are still useable. Absolutely amazed at their performance. I had just completed a similar set of clocks using Norton 3X 80 grit (used a different sander for the 60 grit) and went thru 5 disks. Those were completely thrashed when changed. It’s the only thing I’ll buy from now on. Just hope they make it in regular sheets for my other sander.
Yes, the hole pattern is far worse for dust collection. No biggie for me, as I’m using a good downdraft table. Would probably be ok with DC connected directly to sander as well.
Dusty56
#6 posted 04-18-2012 12:49 AM
^rodneyh^ , Was the bark still on that Maple ? : )
What was your need to use such coarse grits ?
rodneyh
#7 posted 04-18-2012 04:08 PM
My 1st time working with figured maple (any maple actually), and had to clean up a lot of tear-out from my planer. I’ll do a better job on that end next time for sure.
Dusty56
#8 posted 04-19-2012 02:04 AM
^rodneyh^
Try lightly dampening the wood with water or mineral spirits and run it at an angle through the planer.
Take light cuts.
The water or mineral spirits will be removed as the wood is sheared off : )
Any questions , pm me .
pintodeluxe
#9 posted 06-04-2013 07:29 PM
I have since switched to Klingspor discs because the abrasives are just as good, and the dust holes align with 8 hole sanders. The VD 900 series were top rated in a magazine test, and I have found they work well. Even with shipping, they are cheaper than what I can buy at a big box store.
http://www.woodworkingshop.com/
