What can you expect from a 120$ table saw?
Review by lumberjoe posted 04-02-2012 09:05 PM 4205 views 0 times favorited 28 comments Add to Favorites Watch
What can you expect from a 120$ table saw? No-picture-s No-picture-s Click the pictures to enlarge them
Some call it cheap crap, I say “challenge accepted”
After many years of refinishing old tag sale furniture, I decided I’d like to do woodworking. I got some books, then got some tools. I wasn’t sold on the idea that I would be good at it or even like it, so I wanted my initial investment to be fairly small. Around Christmas time, Home Depot had this bad larry on sale for a little over 100$. I could have picked up something used and much nicer for short dough, but safety was my primary concern as a beginner. I make money with my fingers (IT Manager) and would like to keep them attached for as long as possible.
So, What can you expect from a 120.00 Table saw?
Setup – Actually pretty smooth. Considering this is more of a toy than a table saw, it should be. The blade was suprisingly square to the mitre gague (more on that later) and only required slight tinkering. The tinfoil coated balsa wood table (“Aluminum”) was surprisingly flat and even. The stand took about 15 minutes to assemble.
Safety – actually a decent amount of it. The riving knife/splitter is very adjustable and moves with the blade. The kickback paws are nice and actually work, and the blade guard, well it guards the s#$t out of that blade. It comes with a decent push stick that mounts to the side of the table, where smart people put it when they are done using it (maybe someday I will be like them).
Power- It has little of it. I’m not sure what the motor does with the electricity it is consuming. My assumption is filtering it off into thin air where my hopes and dreams of good table saws live. It bogs down ripping 3/4” pine, and that’s with a forrest woodworker II. The included blade is better suited for turning lumber into landscaping mulch. However as I mentioned, I am an IT manager, and make a good living turning mediocrity into awesome, so I can cope (feed slower when it bogs, smaller cuts, strong and heartfelt words of encouragement.)
Accuracy – Awesome! and Terrible! Let me clarify. As I said, squaring the blade did not take long at all. Using the saw is a different story
Pros: – The rip fence is actually decent. It’s easy to move and lock, it stays straight.
The measuring guide on the track is actually dead on (by dead I mean within a 1/16”, to some people that is a mile and a half). I was expecting it to be off by inches, but it’s not terrible
Cons: – The mitre gauge is 100% useless. It is a non-standard size and cannot be replaced/upgraded. The problem is there is a lot of play between the gauge and the track. You can actually slide the gauge back and forth about 1/8th inch on either side. Therefore I have never even used it once. – Vibration. Forget about the penny test, this thing can (and has) vibrate a 30’ Stanley PowerLock right on to the floor.
Summary:
Things I don’t like about the saw – It’s small. You’ve got 12” on either side of the blade for ripping – I’d comment on how there is no room in front of the blade for cross cuts, but the mitre gauge is unusable – It’s a little down on power – It makes me use a circular saw a lot. I’d rather hit myself in the groin with a tube sock full of bars of soap repeatedly before I pick up a circular saw. – Cannot use a dado blade – ANYTHING but a rip cut is pointless
Thinks I like about the saw – It makes sawdust. At the end of the day if all I can do is make sawdust, it wasn’t a bad day for me. – It’s blue, yellow, and grey. It looks like a superhero’s cousin who also wants to be a superhero, but doesn’t quite have any skills, just good looking costumes. – Despite being under powered, featureless. inaccurate in any way a table saw could be, and small, I have turned out some good results. – It gave me valuable experience for my next adventure starting soon – what I DO want in a saw.
So why 3 stars for a seemingly 1 star saw? Well, everything is relative. At this price point, there are some much worse saws out there. Also I ended up learning A LOT about woodworking buy having to do so many workarounds. Instead of using a dado stack, I got REAL familiar with my router. Same with finger joints. I take nothing for granted now. Just because I flattened the edge that rode the fence, I don’t assume the other will be straight, because the fence and table are SOOOO SHORT. It also taught me how much more magical my life would be with a decent table saw. More importantly, It taught me that I really do love woodworking. This saw induces feelings of range and frustration like only the worst of bratty children or the horrific singing teen shows on Nickelodeon can (you dads know what I am talking about), yet I keep using it over and over and over. I’ve easily sent 1,000 board feet though it in 3 months.
When it’s time for it to go, there will be no viking funeral, no Office Space style bat-beatdown, no craigslist add. It will come out of the woodshop and go quietly into the basement. When I get nostalgic, I’ll head down with some safety glasses and wood. I’ll rip a more crooked line than I could walk after a dozen frosty beers and whisper “you done good buddy!” before I cover it up for a while again.
View lumberjoe's profile
lumberjoe
2899 posts in 2484 days
28 comments so far
View Dusty56's profile
Dusty56
11830 posts in 3924 days
#1 posted 04-02-2012 10:02 PM
Great story . Have you tried a thin kerf blade yet ? The WWII is probably too heavy to ever get up to speed ! LOL
lumberjoe
#2 posted 04-02-2012 10:26 PM
I have tried a Freud Diablo 60 tooth and 80 tooth as well that I have for my mitre saw. None are any better or worse. I am going a lot slower with that many teeth, but the saw really bogs down about 2/3’s of the way through. If there are knots, forget it
View chodgson's profile
chodgson
29 posts in 2920 days
#3 posted 04-02-2012 10:54 PM
Thanks for sharing. I saw this saw on sale for $99 in home depot the other day and sort of said to myself, boy that could have saved my a lot of money compared to the $599 I spent on the R4511 2 years ago.. how much worse could it really be? Now I know the answer.
I bet it would bog down less with a quality 7 1/4 saw blade…. very thin kerf and the wood has less mechanical advantage on the blade with a shorter radius…should still be able to rip 1-1.5 inches thick material. And you’ll have more effective table space because less is taken up by the blade! Not surprised that you didn’t get any help from the miter saw blades if you’re ripping.
Also I can’t help but be amused by the fact that you put a $100 saw blade on a $100 saw… I love my WWII as well, but lol.
View Jeff's profile
Jeff
500 posts in 3430 days
#4 posted 04-02-2012 11:14 PM
I’ve been looking around for a very small table saw I could use to cut small parts out of thin wood. Maybe this is the answer? Thanks for the review and description.
Dusty56
#5 posted 04-02-2012 11:24 PM
I’ve also used the 7.25” blades on several saws with excellent results : )
View Sawkerf's profile
Sawkerf
1730 posts in 3304 days
#6 posted 04-02-2012 11:27 PM
I’ve had one of these for about five years and like it just fine. I got it for a job where I needed a basic job site saw and wouldn’t have had a problem selling it when the job was finished. I still haul it to job sites and use it for very simple ripping/crosscutting chores. The fence seems to work well, but the miter gauge is a POS (I’m not sure where mine is – lol) I built a sled for crosscutting and it works great.
My biggest complant is the amout of sawdust that gets sprayed into my face when I’m ripping.
Mine has plenty of power and wants to jump when I start it.
16281 posts in 4454 days
#7 posted 04-02-2012 11:47 PM
That was my first saw. Cheap as it was, and with all its shortcomings, it really is what got me hooked on woodworking. For a small investment, and with a lot of patience, you really can do a lot with this little saw.
View mrpedal's profile
mrpedal
30 posts in 2774 days
#8 posted 04-03-2012 12:01 AM
..and like most people in IT the process of turd polishing has given you the power of snarky-funny-haha.
“Forget about the penny test, this thing can (and has) vibrate a 30’ Stanley PowerLock right on to the floor”
woodwork is good therapy. Just pretend it’s a coworker going through the saw instead of a 2×4. :D :D
View Manitario's profile
Manitario
2703 posts in 3119 days
#9 posted 04-03-2012 12:20 AM
This was my first TS. I built my workbench using this saw and reno’d a basement. I can’t say that it was accurate or powerful but it was the gateway into woodworking for me.
View ShaneA's profile
ShaneA
7064 posts in 2834 days
#10 posted 04-03-2012 01:12 AM
Thanks for posting. Pretty funny, all in all. The good news is, when you upgrade you will appreciate all the advantages of a “full size” saw. Benchtop saws are just a challenge…
lumberjoe
#11 posted 04-03-2012 01:26 AM
Woodwork is the best therapy. I love this saw even for all it’s shortcomings. I plan to upgrade in the next few weeks to a full size saw. I’m sure my frustration level will remain the same for a while as I do all the things I can’t do now, like dado’s cutting cheeks and shoulders for tenons, making jigs, etc.
Another huge shortcoming of this saw is that stupid defective mitre slot. There are NO accessories that fit it at all, and there is no room to clamp anything like a feather board.
Now to decide between the Steel City, Griz/Rikon, or spend an extra 250 for the JET
View gfadvm's profile
gfadvm
14940 posts in 2926 days
#12 posted 04-03-2012 01:30 AM
My first saw was a little Ryobi and I got a lot of good milage from it before upgrading to my Grizzly. Put a 24 tooth Diablo blade ($27) and you will be amazed at the difference. I put tape on my miter gauge to shim it and it worked! Enjoy.
View doninvegas's profile
doninvegas
334 posts in 3143 days
#13 posted 04-03-2012 01:40 AM
My first saw was a Tradesman I got from Lowe’s for $99. It was a good saw. The fence was accurate and it had the power to cut what I was using at the time (Red Oak also from Lowe’s). It was a direct drive saw so it finally burned up after about 5 years of weekend work. Now I have a Delta contractors saw. It is a big improvement but I didn’t know it at the time.
-- "Courage is being scared to death -- but saddling up anyway."
View john's profile
john
2376 posts in 4617 days
#14 posted 04-03-2012 01:52 AM
I had this saw along with 3 other tablesaws and after using this saw a few times i gave it to my son . It,s a great beginner saw for small projects
-- John in Belgrave (Website) http://www.extremebirdhouse.com , https://www.facebook.com/groups/extremebirdhouses/
View davidroberts's profile
davidroberts
1027 posts in 3722 days
#15 posted 04-03-2012 02:18 AM
Dusty is right, that TS is made for a small diameter thin kerf blade. In todays market you can buy a pretty good quality Diablo thin kerf rip or combo blade for under $50. I just saw where gfadvm posted $27, so there you go. You will see, feel, hear the difference immediately. It takes at least 2 HP, real not developed, to swing a WWII efficiently. If your fence is reasonable, I didn’t say dead on beismeyer, just good nuff, then you will be able to dimension your material and can tweak with a hand plane or router.
Also, thanks for an honest review and rating. I kinda get tired of reviews that are given five stars to cheap, poorly make, more trouble than it’s worth equipment, or worse, they have never actually used the machine, but just had to let us know what they brought home today. Not to say the Ryobi is any of the above, we all know it is what it is, and can be more if used in the right hands with the right blade.
-- Better woodworking through old hand tools.
showing 1 through 15 of 28 comments
