Great idea - does not execute well
Review by Grandson_Of_Rue posted 03-29-2012 02:30 AM 2976 views 0 times favorited 9 comments Add to Favorites Watch
Great idea - does not execute well No-picture-s No-picture-s Click the pictures to enlarge them
(note: In response to some of the comments….
I do realize that for some these will work quite well. I too have seen reviews of items I was very pleased with though the reviewer was not. For those of you who these work well for, I would love for you to demonstrate because I really hoped they would work. I appreciate your positive findings.
I also want to be clear that I in no way am dissing Rockler. I continue to buy many things from them. My decision not to return them had nothing to do with Rockler and I don’t ding them for my opinions on them. In fact one of the reasons I have no returned them is because I am still trying to prove or disprove user error. If I get these to work I will change the review.
I think the best comments I have gotten thus far is that these are not made for a lot of pressure. If you are just holding the wood together and letting the screws do the work then these would work just fine. I took the word clamp to mean pressure. My experience has been that every so often the wood shifts when you drive the screw if you aren’t clamped tight enough causing slight alignment issues.
I appreciate the feedback.)
I love ..LOVE my Kreg Pocket Hole kit. This is not a review for that kit.
I posted this as a Kreg product but it is actually a Rockler Product. Kreg being the prevailing brand name for this tool I felt it made sense to associate it as such.
I also do not have the quick release although I don’t think it will affect my review. I do wish I had the quick release though.
These are relatively well built.
Overall, I am not pleased with these. I have played with these a lot and cannot get them to clamp any better than using quick clamps.
In the pictures they show them flat against the board, however this does not happen. The tighter you get them the more they want to pull up and out.
They are pretty straight forward and I am really disappointed. If I struggle with anything on using pocket holes it is the clamping. These did not make it any better.
View Grandson_Of_Rue's profile
31 posts in 2992 days
9 comments so far
View cabmaker's profile
1706 posts in 2738 days
#1 posted 03-29-2012 02:38 AM
Never fails does it ? Someone always wants to reinvent the wheel and improve things untill its totally screwed up. Even had that worked for you , seems it would be pretty slow. Maybe youll hit it on the next one. JB
Dick, & Barb Cain
8693 posts in 4229 days
#2 posted 03-29-2012 12:20 PM
I bought two of these, & I’m sorry I did. I tried them on some soft pine, & they were hard to adjust.
Sometimes they would tilt, & pull through the slot, & ruined the piece. They now sit in a junk drawer!
-- -** You are never to old to set another goal or to dream a new dream ****************** Dick, & Barb Cain, Hibbing, MN.
View John's profile
341 posts in 3728 days
#3 posted 03-29-2012 02:49 PM
thanks for the review! I had similar thoughts, here’s the review I wrote on Amazon for these:
this clamp is designed for 3/4 inch stock when making face frames.
that’s it; that’s all; nothing else to see here.
if that’s what you do (make 3/4” face frames) and you’re in no rush, this is awesome!
it does a much better job at this singular activity than the Kreg RAC (right angle clamp) – assuming you define better as less fiddling to get the mating pieces aligned to each other. if you define better as faster, not so much.
this is a well built clamp; it feels solid and is.
in theory this is a nice product, and if you like to take your time and spend minutes on each joint (in 3/4” stock. making face frames, not the rest of your build) then this is a fine tool. in reality, i used it for two joints, then hung it up on the pegboard where it collects dust. the Kreg KHC-RAC Right Angle Clamp is so much more useful.
-- John - Central PA -
View Raspar's profile
246 posts in 3078 days
#4 posted 03-29-2012 03:01 PM
Wow that is funny, I own these as well and have had good luck with them. I use the these with the kreg leveling clamp as well and have put together many face frames with these. I only use these to snug the joint, not to create a pressure. The screw will pull this together. Not to contradict you but I have enjoyed these in my arsenal of clamps.
The only issue I have with these are they are slow.
-- Have thy tools ready. God will find thee work.
117028 posts in 3507 days
#5 posted 03-29-2012 03:11 PM
Thanks for the review,it should save a lot of folks from investing in them.
-- wood crafting & classes
View Cajunrotor's profile
35 posts in 2257 days
#6 posted 03-29-2012 10:28 PM
And I was on the verge of picking up a couple of these when in Rockler recently, but didn’t. Good to know.
But I have to ask of those unhappy purchasers, why not return to Rockler for a refund? They really do stick behind their 90-day “no questions asked” return policy.
-- Earl
View doordude's profile
1085 posts in 2912 days
#7 posted 03-30-2012 05:02 AM
thanks for the heads up on this product. i’ll put the money to something else.
View thedude50's profile
3602 posts in 2407 days
#8 posted 03-30-2012 06:56 AM
I never felt the need for more than one of these. i don’t get the 5 clamp thing i have used mine a few hundred times and they work well for me as long as was stated you don’t use them for too much pressure. These hold the work fine and the quick release made them work a lot faster. iI love mine so i have to agree if you don’t like them return them. rockler will take anything back I will keep mine and will be glad i did.
-- Please check out my new stores and
View noone's profile
583 posts in 2202 days
#9 posted 06-29-2012 07:04 PM
I just finished using the Kreg system on a built-in for our home. It worked out great. However, I do like things PERFECT, and I found out that, with the Kreg system, it was really difficult to get perfectly aligned and flush joints screwed together. It seemed that no matter how hard I clamped the two pieces using either the Kreg right angle clamp or Kreg face clamp, the pieces would shift slightly as the screw made contact with the second piece. This would throw the alignment of the two pieces off up to 1/16″. I ended up usually having to set the pieces a little proud of each other, clamp them real tight, and then screw them together, knowing that the clockwise rotation of the screw would pull the initial proud alignment in.
Would these Rockler Pock-it clamps be the solution I am seeking?
Or would I be better served with using 2 (or 3) of the Kreg right angle clamps when gluing + pocket screwing two pieces of a cabinet together?
Are any of you able to get perfectly flush joints repeatedly?
