Extra hands that work surprisingly well
Review by Grandson_Of_Rue posted 03-29-2012 02:06 AM 7984 views 2 times favorited 10 comments Add to Favorites Watch
Extra hands that work surprisingly well No-picture-s No-picture-s Click the pictures to enlarge them
I saw these some time ago on a show. New Yankee Workshop, I think.
I, like many others, find myself well, by myself in the shop when it is time to cut 4×8 sheets of ply. While I do have an eager 7yr old it is not safe for him nor I.
These work by pulling the board against the fence as it is fed. The angle of the rollers does the work. The set screw with the eyelet allows you to adjust the level of the rollers based on the board thickness you are feeding through it.
The YELLOW rollers only spin to allow the board to move forward. They will not spin backwards and this is an effective anti-kickback. However, I do not believe it is foolproof. The board can be pulled laterally from under the rollers. So there is still a chance of kickback depending on how the blade grabs the stock.
In the picture below GREEN rollers are present and allow for bi-directional feed.
There are also ORANGE rollers which rotate counter clockwise for fence placement on the left side of the blade.
The rollers them selves are replaceable.
I found these to be incredibly helpful when cutting large stock. Small stock too but the real benefit is the bigger the board the more benefit. Typically in the past when trying to saw a 4×8 sheet any movement as you feed will case the cut line to waver as the board pulls from the fence. Even if it is a 16th of an inch. Leaving a less than straight cut. Not to mention the threat of kick back.
I thought that even with the rollers pulling against the fence I would still see shifting as I stood 8ft away pushing the sheet forward. However this does not happen. It has improved my cuts as well as safety.
This works well on smaller stock also. It allows me to focus on the blade and my push and less on watching the fence for shifting.
These work better than a set of extra hands because that set of hands is sometimes doing things that take the board in the wrong direction. Especially if they don’t know what they are doing when using a tables saw (like the wife, shhhhhhh :) )
The roller mechanisms remove easily. They also adjust easily.
If I have any feed back to the manufacturer it would be the track needs mounting holes on both sides of the track. For some reason they only placed them on one side. Which means when the rollers are under tension the track lifts slightly. This is not a huge issue but I find it aggravating. Granted I am nit picking.
Thoughts on use…......
I have found that you want to place the rollers in a manner that no matter where the board is at during a cut it is under the control of a roller. I found that when a board leaves a roller it jumps if not already under the second roller. This is because as the rollers pull the board against the fence and push it down on the table it creates tension. When the board comes from the front roller it will jump due to your pushing against the tension. This does not happen if the board is already engaged by the second roller.
I also would not use the rollers with in 8-10 in of the blade. There simply is not enough room with the two rollers and the blade. Factor in your hands moving around all of that and you got trouble.
Because the rollers hold the stock you could use a push stick when working closer to the blade if you want to use the rollers. I actually prefer this over two push sticks – one pushing forward and one holding against the fence. It always seems like I am reaching over the blade.
Despite the mounting holes issue, I would give these a 5 out 5. I highly recommend them.
View Grandson_Of_Rue's profile
Grandson_Of_Rue
31 posts in 3176 days
10 comments so far
117203 posts in 3691 days
#1 posted 03-29-2012 02:15 AM
Thanks for the review ,I have some and I have never in stalled them.
View Grandpa's profile
Grandpa
3261 posts in 2790 days
#2 posted 03-29-2012 02:36 AM
I have seen these advertised and always wondered if they were a gimmick. Thanks for sharing
View eddie's profile
eddie
8565 posts in 2728 days
#3 posted 03-29-2012 05:53 AM
i got them but the aluminium track i had to get cut to fit my old jet .should have them on one day next week nice review. i got mine at peach tree that was the cheapest place i found
-- Jesus Is Alright with me
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3400 days
#4 posted 03-29-2012 05:01 PM
Great review!
I used mine just a few days ago. I was pleased with them and thought I should do a review.
You covered it much better than I would have
Thanks
-- http://shepherdtoolandsupply.com/
View Don Niermann  's profile
Don Niermann
219 posts in 4087 days
#5 posted 03-29-2012 06:39 PM
I have been using them for 15+ years on table saw and router table. Love them
-- WOOD/DON (...one has the right to ones opinion but not the right to ones own facts...)
View Milo's profile
Milo
869 posts in 3433 days
#6 posted 03-29-2012 09:49 PM
So you can’t use a push stick with those, or utilize any kind of push block with your fence with those. How do you push your wood past the blade? A board flat on the table? I guess that would work fine since you shouldn’t have to worry about the wood lifting off the table with those rollers.
-- Beer, Beer, Thank God for Beer. It's my way of keeping my mind fresh and clear...
View Builder_Bob's profile
Builder_Bob
161 posts in 3174 days
#7 posted 03-30-2012 04:51 PM
Some time ago I put the yellow ones on my old Craftmans saw as a safety aide, and loved them.
I bought a SawStop a year ago and hung up the board buddies since I now had a safe saw with a riving knife and precise alignment.
Last week I put the board buddies on the SawStop and love them again! As you say, it’s much easier to make safe and accurate cuts with the board buddies pulling the stock against the fence. I’m so glad I didn’t get rid of those yellow wheels!
-- "The unexpected, when it happens, generally happens when you least expect it."
View MJCD's profile
MJCD
543 posts in 2485 days
#8 posted 04-05-2012 01:12 PM
Thanks for the information – I too was wondering if these were a gimmick.
A Question – how do these attach to an existing Fence – either TS or Router Table? I have an alll aluminum Incra system, and am not sure how these would attach – any thoughts?
Thanks
-- Lead By Example; Make a Difference
View Garbanzolasvegas's profile
Garbanzolasvegas
356 posts in 1341 days
#9 posted 03-16-2015 01:40 AM
I ordered these friday cant wait to use them
-- If you don't Play, you can't win
View Picklehead's profile
Picklehead
1043 posts in 2044 days
#10 posted 03-16-2015 02:54 AM
I sure hope they’re five stars, then, or we’ll be hearing about it!
-- You've got to be smarter than the tree.
