Makita 18v Li-Ion Cordless Blower(BUB182Z)
Review by rance posted 03-27-2012 04:19 AM 10877 views 0 times favorited 10 comments Add to Favorites Watch
Makita 18v Li-Ion Cordless Blower(BUB182Z) Makita 18v Li-Ion Cordless Blower(BUB182Z) Makita 18v Li-Ion Cordless Blower(BUB182Z) Click the pictures to enlarge them
How to clean your shop(and other places too)
I have the blessed opportunity to use a very good friend’s shop whenever I want. There are two really good things about working there:
1) He has sattellite radio piped in. That means I can listen to 50’s music all day long. He was listening to it before I got there so there’s no battle on what station to set it on. He also likes gospel music from time to time which I also enjoy. A great environment, and a very gracious friend to allow me to use his shop.
2) At the end of most days he likes to make a pass at cleaning up a lot of the dust that often accumulates. He introduced me to his cleaning aparatus. It is a Makita BUB182Z 18-Volt LXT Lithium-Ion Cordless Blower.
Note the added cord for hanging it on a hook.
Just open the big door, start from the opposite end and start blowing all the dust out the door. At first I thought it was only good for the floor and the machines. However, I have recently discovered that it is actually a variable speed unit. Not only that, it has 3 speed settings if you are trigger-challenged.
Even with it on high though, I can gingerly pull the trigger and get a very light breeze that will not disturb the lightest of scraps lying on the bench. Here’s a before shot of a mess I made:
And after gingerly blowing the dust away:
The first thing you think of when you hear of using a cordless blower(or a leaf blower) is that you are working with 100mph capability. Actually, you are, but with this variable speed unit, you can control it to just a whisper. With that, its usability goes WAY up. You can swap the nozzle to the side port and put a bag on the output if you wanted to suck up the dust and capture it in a bag, but I can’t see that as very useful. Someone might need that feature though.
With the Lithum Ion batteries, you get a loooooong life from each charge. I currently don’t have any Makita cordless tools, but my next cordless just might be Makita so I can also double duty the batteries with one of these blowers. I highly recommend it to make cleaning your shop a breeze. (Sorry Steve, I just can’t help myself. I just kill me.)
Actually, I have another good friend that does a very similar thing with his shop. He added an attic fan to one corner of his shop(opposite corner of an outside door). He opens the outside door, turns on the attic fan, and uses a small corded vacuum cleaner with it set to blow, and does basically the same thing. The bestest and quickest way to clean the dust in your shop(variable speed or not).
PS: Hey Rod, you should see this thing…
View rance's profile
rance
4266 posts in 3360 days
10 comments so far
View redryder's profile
redryder
2393 posts in 3302 days
#1 posted 03-27-2012 04:25 AM
I can see the safety committee showing up for this but I can see what your doing and if it works for you, great. Dust does go on forever…..................
-- mike...............
6866 posts in 4179 days
#2 posted 03-27-2012 11:09 AM
Hi Rance,
We use a similar method to clena up in the shop. Before leaving for lunch we’ll use a long nozzel on or air compressor, blow the dust off every surface. Between the dust collectors we have on the ceiling, and the open doors, it’s amazingly clean we we get back.
Of course, the guy doing this is wearing a dust mask.
Makita is a brand I stopped using about 20 years ago. I did buy their 18 volt screw gun kits a couple years ago, due to the size of them. They’re fantastic! They’ve been through the ringer at a couple construction projects and handled it quite well. To the point others working at the job would go buy them!
View Roger's profile
Roger
20952 posts in 3004 days
#3 posted 03-27-2012 01:09 PM
brings a whole new meaning to getting blown away by the pull of a trigger.
View ChuckC's profile
ChuckC
843 posts in 3135 days
#4 posted 03-27-2012 01:15 PM
I do the same thing with a backpack leaf blower. On idle i can clean the tops of tools and then i crank it for everything else. It’s an added benefit of having your shop outside.
View jaydubya's profile
jaydubya
183 posts in 3012 days
#5 posted 03-27-2012 08:13 PM
Great idea, And I already have the drill and impact that uses those batteries
View OnlyJustME's profile
OnlyJustME
1562 posts in 2577 days
#6 posted 03-28-2012 12:46 PM
I like everything about the makita 18v lxt line except the drill chucks are horrible. trying to get them to hold onto a round drill bit while drilling through hard material is tricky. i’ve actually broken gear teeth trying to tighten the chuck enough to no avail. i switched my drill to a milwaukee and have almost no trouble with that.
-- In the end, when your life flashes before your eyes, will you like what you see?
View Gene Howe's profile
Gene Howe
11063 posts in 3628 days
#7 posted 03-28-2012 01:20 PM
The variable speed and the mobility of a non-corded unit is fantastic. I use the head off my Craftsman wet dry vac and it’s not VS and it’s corded. I’ll seriously look into the Makita blower.
OnlyJustME wroteI like everything about the makita 18v lxt line except the drill chucks are horrible. trying to get them to hold onto a round drill bit while drilling through hard material is tricky. i’ve actually broken gear teeth trying to tighten the chuck enough to no avail. i switched my drill to a milwaukee and have almost no trouble with that.
That’s strange. I have 3 of them and have had no problems with them holding bits. Even in metal.
OnlyJustME
#8 posted 04-05-2012 12:37 AM
You must be one lucky guy because i’ve had several and guys that i work with that have them have the same problem with it. When it comes to smaller round bits it just doesn’t hold strong enough.
View gonzales's profile
gonzales
2 posts in 1192 days
#9 posted 09-08-2015 10:04 AM
This blower is great for small lightweight jobs. Blow off your front steps, cleanup in your garage, this lightweight tool is a keeper!
-- Gonzalo, Chicago. Solar LED Flood Lights ==> http://www.bestsolarledfloodlightscenter.com Best Leaf Blower ==> http://leafblowerhq.com
View devann's profile
devann
2246 posts in 2892 days
#10 posted 01-10-2016 03:47 AM
Hello Rance, I was going to write a tool review about one of these blowers but decided to see if there was already one written. I love the little blower. I’ve had one for a little over a year now. I scoffed at the product when I first saw one. I was in a store and the Makita salesman was showing it to me. I thought okay, that’s nice, he said they’re only $99.00, I told him to take a hike. I waited until that time of the year, you know, after Thanksgiving, before Christmas when prices on battery powered tools are at their best. I paid $49.00.
It’s been a good tool choice. I like to blow off my miter saw setup daily before loading up & putting it away. This used to be done with a blower nozzle from my air compressor. But, in recent years my compressor,(if I even have one out being used) has been used further & further from my saw.
I have also found it useful when I need to get down on my knees or lay somewhere to get access to what I need to work on. I grab the blower. Blow me off a clean spot first. That nasty pickup truck floorboards, open the doors and let it rip. The hunting blind getting a dirty floor, grab the blower. It’s been a great little tool for keeping the sawdust blown out of many power tool uses when an outdoor environment allows for such a tool.
