Insulfoam Garage Door Insulation Kit
Review by David Grimes posted 02-09-2012 05:34 AM 43679 views 8 times favorited 13 comments Add to Favorites Watch
Insulfoam Garage Door Insulation Kit Insulfoam Garage Door Insulation Kit Insulfoam Garage Door Insulation Kit Click the pictures to enlarge them
My three garage doors were not insulated. Never a problem until last year when I converted bay 3 into the Man Cave wood shop and started spending much time out here. I don’t even remember what the back porch looks like. My dogs miss me terribly. They bark at me before they remember me.
I went to the BORG and the BBRG looking for garage door insulation whatever. They had some Owens Corning bag of flimsy, etc. No thanks. I called my garage door supplier/installer to see how much the real insulated panels cost. Answer: They are so proud of them that I better let them keep them.
So I get on the internet and find the Insulfoam site. Made in the USA. Looks great. But WAIT ! They say they are available at Lowe’s and Home Depot. I call both stores and they’ve never heard of them. I call the company and talk with the lady. She tells me they will be less expensive from Lowe’s than directly from them. Okay, so I go back online and find them at Lowe’s website. 4.6 stars !? 103 reviews !? 94 would recommend to a friend !? SOLD to the man with a card in his hand. I buy one door’s worth (a single kit). I got it in three days.
I install it in less than 30 minutes. Super. Just what it needs to be. And I’d pay more for the same thing if I had to. I love the harder textured laminated surface on the exposed side. It looks almost “factory”.
I ordered the other two kits.
Some specifics: I used the table saw to make perfect cuts. Turn the laminate side down and it is perfect. Save the extra slices to back fill the edges. No tape or adhesive required.
A wonderful product. Nearly no weight added to the garage door. Maybe 10 pounds (total per door) is a good guess. Cost is $54.97 per kit (8 sheets) that will cover up to a 9’ wide by 7’ tall single garage door.
I do recommend this product. I will be installing these for customers now that I know about it. This is right there with water softeners, pool ionizers and UVC light in the HVAC A-frame. Just plain a good idea.
Thanks for stopping in.
-- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia
View David Grimes's profile
David Grimes
2078 posts in 2838 days
13 comments so far
View Fallon's profile
Fallon
92 posts in 3327 days
#1 posted 02-09-2012 06:17 AM
I got some blue 1/2” sheets of the fine grain foam from Lowes and did a similar job myself. Cut the foam in to the size of 1 of the panels on the garage door. The doors I have form a C channel on the inside the way the aluminum is curled in on the inside. Just right for putting a pair of 1/2” thick panels in. Bend the foam a little bit and they snapped right into place without any adhesive or fasteners. As it turns out the 2 sheets of half inch (all they had in stock) worked better than 1” thick, as it was easier to bend.
Hard to tell for sure from the pictures, but it might be the same C type channels as in the photos of your door.
Makes a huge difference when working in the garage, stays much more comfortable & uses less juice to keep it warm.
View Ben's profile
Ben
302 posts in 2529 days
#2 posted 02-09-2012 07:04 AM
I had a friend that worked at lowes for a while and something most people don’t know… If you can get it from a catalog or a website, you can order it, have it shipped and pick it up at Lowes! Doesn’t matter if they carry the product or not. Also, that is the same stuff I have on the garage door in my shop. Seems to do what it’s supposed to.
-- Welcome to downtown Coolsville, Population: US! --Hogarth Hughes
View schuft's profile
schuft
123 posts in 2806 days
#3 posted 02-09-2012 11:25 PM
That’s good info, thanks for sharing.
View popsshop's profile
popsshop
42 posts in 3174 days
#4 posted 02-10-2012 03:52 AM
David, Sounds like a good plan . . . and affordable. Thanks.
-- Drilling holes in wood is a boring job
View ShaneA's profile
ShaneA
7052 posts in 2797 days
#5 posted 02-10-2012 04:01 AM
Sweet, thanks for posting.
View Sarit's profile
Sarit
550 posts in 3338 days
#6 posted 02-13-2012 09:06 AM
Thanks for the review. Insulating the garage door is on my long list of todo’s.
View Peter's profile
Peter
4 posts in 3283 days
#7 posted 04-12-2012 09:27 PM
Thanks! That’s pretty cool. We use insulfoam in our insulated sectional overhead door panels, so it’s cool to know you can add it to plain panels. Thanks for sharing!
-- Peter
David Grimes
#8 posted 04-12-2012 11:13 PM
I have now done all three of mine and loving it. REALLY a huge difference whether hot or cold outside.
View RandyH's profile
RandyH
18 posts in 2557 days
#9 posted 08-27-2015 03:58 AM
I ended up not using this product because I needed a bit more insulation up here in cold Indiana ! The R-factor of those panels just did not seem to be enough. I ended up purchasing 2” thick foam board insulation (http://www.lowes.com/pd_304090-210-304090.0___?productId=3122447&pl=1&Ntt=foam+board+insulation) with an R-value of 10. I think the panels in that kit give an R-value of 4 or 5. I covered the door for my 2-car garage with it, using my table saw to shape it to fit. I am happy so far – it has kept the garage cooler this summer. We’ll see how it does in the cold in a few months ! (The green-blue color isn’t as attractive as the white, I must admit)
-- There is no greater love than this, that a man lay down his life for his friends.
View Jordan834's profile
Jordan834
1 post in 409 days
#10 posted 10-28-2017 09:25 AM
Authorities tutorial on Musically Online Login with musicallylogin Well, there is an on-line website for the customers to handle their.
View Joe Lyddon's profile
Joe Lyddon
10320 posts in 4251 days
#11 posted 10-29-2017 08:54 PM
... Bad post…
Joe Lyddon
#12 posted 10-29-2017 09:01 PM
I ended up not using this product because I needed a bit more insulation up here in cold Indiana ! The R-factor of those panels just did not seem to be enough. I ended up purchasing 2” thick foam board insulation (http://www.lowes.com/pd_304090-210-304090.0___?productId=3122447&pl=1&Ntt=foam+board+insulation) with an R-value of 10. I think the panels in that kit give an R-value of 4 or 5. I covered the door for my 2-car garage with it, using my table saw to shape it to fit. I am happy so far – it has kept the garage cooler this summer. We ll see how it does in the cold in a few months ! (The green-blue color isn t as attractive as the white, I must admit)
- RandyH
This item is no longer available at Lowes”.
View Garagedoorkit's profile
Garagedoorkit
1 post in 376 days
#13 posted 11-30-2017 10:26 AM
Door Brake solution is only Insulation at your Garage door which helps a person to secure a door from such Cracks. In summer direct sunlight at your door makes the insulation loose while melting. To cover the same door use Garage door insulation to avoid such parameters.
-- https://garagedoorinsulationhq.com/
