Another Jet 10" jointer/planer combo review
Review by Eric posted 02-08-2012 12:35 AM 15163 views 0 times favorited 11 comments Add to Favorites Watch
Another Jet 10" jointer/planer combo review No-picture-s No-picture-s Click the pictures to enlarge them
Having a large hunk of white oak cut up roughly (chainsaw!) and dried, and beaten up by taking a good hour on one piece jointing with hand planes, I finally took the plunge with the Jet 10” combo. I have a small non-garage shop, so both space and charge card were important! Since others have reviewed the machine here and on other sites, I just want to add my thoughts if you are considering the purchase.
First, as others have said, set up is a snap, tables well-enough co-planer out of the box for me. The supplied stand is cheap and probably a danger if you actually plan on using the tool. I made a low box-type stand on rollers out of 3/4” plywood, wide and long enough to be stable, but not too big for my shop.
Second, when setting up as a jointer be careful with the dust collecting hood. It triggers a dead man switch under the front housing; if you’re not careful enough with placing and securing the hood (and I speak from experience here!) the plastic of the hood will jam the rollers of the planer (which doesn’t affect the jointer’s operation)—the foul odor you smell shortly thereafter is the roller drive-belt frying. Since I already have an old and well-beaten up DeWalt planer, I didn’t really care; but if you need the planer be careful. As you’re installing the dust hood and raising the planer table into the “dust collection position” for the jointer, have the front cover off to make sure that the dead man switch is pushed in (its on the left), and then make sure the large white plastic gear driving the rollers moves freely BEFORE you turn the gizmo on.
Third, if you aren’t a believer in hearing protection become one before turning the machine on. I really think the passenger jet pilots flying over our house at 30,000 ft were wondering where that noise was coming from!
Fourth, induction motor and all, edge jointing with 1/8” remove works fine with little bogging-down; on face much over 1/16” made the neighborhood lights dim. It joints well enough, but it will definitely teach patience.
Fifth, since this my first experience with a jointer, all I can say is that dust & chip collection is OK—bits still fly everywhere.
Sixth, the biggest weakness in the machine I’ve found is the spring-loaded jointer blade guard. The spring really was installed upside down out of the box, and it secures weakly when placed properly. If you inadvertently over-rotate the guard away from the fence (again speaking from experience, as I was paste-waxing the table) it pops loose, and you have to disassemble/reassemble again. If you’re like me on this, a pair of those fancy pliers that help remove and replace spring clips comes in handy (I work on my own motorcycle, too….).
Last, my white oak is up to 53” long; much over that and outfeed support (roller stand, whatever) would be a great help.
Overall, it does a passable job (recall, my first experience with a power jointer), and is a whole lot quicker than hand planes. For what you get it seems a good value, and solid enough to do hobbyist work.
View Eric's profile
Eric
2 posts in 2591 days
11 comments so far
View Todd's profile
Todd
10 posts in 2565 days
#1 posted 02-08-2012 05:42 AM
Thanks for the review. Your statements are right on track. I have one of these myself. Got it about a year ago at Woodcraft. Actually, I bought the floor model and about three days later one of the main bearings froze up on me. I called Woodcraft, and the Jet rep, and the replacement was quickly at my door. So, I had a bad taste in my mouth right out of the chute. The noise is an issue, and GOOD hearing protection is a must. I also find that dust and chips quickly collect directly below the infeed table. But, for the most part, the vacuum port is fairly effective.
The biggest problem I had with my Jet combo machine is keeping the tables coplanar. After I bought the machine I started looking at some reviews, and the biggest complaint that most had about the machine was keeping the infeed and outfeed tables coplanar. Jet supposedly had a fix, which didn’t work as well as I wanted it to. There simply wasn’t enough adjustment potential with their engineering. Therefore, I re-tapped some machine screw holes and the machine is now flat from stem to stern. :)
Overall, as you stated it does a passable job. For the money, and a shop with limited space, it’s about the best “bang for the buck” on the market. I am very much a Grizzly and Porter Cable man, with more of an emphasis on Grizzly, so I had to dig deep to stray from my biased brands.
Again, thanks for the review. Hope my 10 cents worth made sense?
-- Anybody can become a woodworker, but only a Craftsman can hide his mistakes! - Walter Blodget
View dbol's profile
dbol
136 posts in 3234 days
#2 posted 02-08-2012 12:11 PM
Mine is at the service center right now getting new belts put on. I would not bother buying this machine. Do some more homework and upgrade to something else.
View mtnjak's profile
mtnjak
52 posts in 3289 days
#3 posted 02-08-2012 05:14 PM
I’ve owned the Jet 10” jointer/planer now for about two years. I’m a hobbyist woodworker and would say it works well overall and I haven’t had any serious problem with it. I haven’t had the co-planer table issues that others have spoken of. I did have the blade guard problem right out of the box and fixed it. I used the mounting base that came with it which I have sitting on a Jet mobile base and this setup works fine. I’ve used commercial jointers before and while I can say that it’s nothing like those, the $400 price tag is much more appealing than spending 2 grand on something for my occasional use and the fact that the bed is 10” in width is a plus. If you’re cranking out cabinets for a living you’ll most likely want to spend the money on a better machine but for any hobby woodworkers out there, I think it’s worth a shot. Too bad they are now $100 more than they were 2 years ago.
View Builder_Bob's profile
Builder_Bob
161 posts in 3296 days
#4 posted 02-08-2012 05:50 PM
I have the coplanarity problem on this machine. With the clamping knobs loose, the infeed table just wallows around with a lot of slop. Now I carefully measure each setting before clamping in place. Thickness planing is hard to measure with everything hidden from sight.
I used to plane and joint every board in a project, now I evaluate each case carefully. My table saw is good enough for jointing most of the time.
-- "The unexpected, when it happens, generally happens when you least expect it."
View Twigger's profile
Twigger
26 posts in 3242 days
#5 posted 02-09-2012 07:16 PM
My only complaint with the 8” version of this machine is the noise level, as noted. I find it frightening – protection is a must – it could double as a tornado siren.
-- When can we go fishing, err woodworking?!
View Chris Birge's profile
Chris Birge
5 posts in 2524 days
#6 posted 02-21-2012 07:06 PM
I’m looking at getting one in the next 2 to 3 weeks.. The price tag and space saver is what i’m looking at for the Garage workshop..Its all about space when you don’t have enough.. lol
-- The quality of a person's life is in direct proportion to their commitment to excellence, regardless of their chosen field of endeavor.
mtnjak
#7 posted 02-21-2012 07:32 PM
I’m in the same boat with shop space. My shop is an extra 225 square foot “nook” at the back of my 2 car garage. For hobbyist, the price is great.
View Chairmaker14's profile
Chairmaker14
2 posts in 757 days
#8 posted 12-22-2016 12:41 AM
Thanks for the honest review. I think for the price it should be what I need.
View GusGia's profile
GusGia
7 posts in 728 days
#9 posted 01-20-2017 02:20 PM
Hi I`m a hobbiest, and I leave overseas, I plan to visit USA on february and I want to buy and JPP planer jointer. and I know that the measurements of the machine exceed the 62 inches (L+W+H) that you can send in the airplane..
So I want to know if I can take the table the jointer infeed and jointer outfeed (To reduce the volume) so it is not so bulky and be able to dispatch it in the hold of the plane.
Hope somebody could help me with suggestion or pictures of the planner where I could disambled and I need to buy tools as will be a tourist (with all my tools at home)
Regards Gustavo
mtnjak
#10 posted 01-20-2017 07:35 PM
Gustavo,
From what you are trying to do probably the best thing to do is detach the machine from the base. If I measure the machine only it measures 18×19x38 inches. The stand measures 19×21x26 assembled. If you don’t assemble the base it will take up very little space as it’s only a series of L shaped channels, the longest being 25 inches in length. If you need to meet exactly the 62 inch requirement then you would need to further remove the fence and/or the two bed pieces as well. However, I don’t not know how to do that as the machine comes pre-assembled. Hope that helps you out.
GusGia
7 posts in 728 days
#11 posted 01-21-2017 03:19 PM
Thanks but 18+19+38 inches = 75 and I must reduce to 62 inches that the AA could dispach, thats why y want to take off the the jointer infeed and jointer outfeed
Regards Gustavo
