Carter Magfence
Review by richgreer posted 507 days ago 2933 views 1 time favorited 11 comments Add to Favorites Watch
Carter Magfence Carter Magfence No-picture-s Click the pictures to enlarge them
My 18” bandsaw is, essentially, dedicated to resawing and other straight cuts. I was not happy with the original fence and I looked to upgrade. I did not find many options for an 18” bandsaw and finally purchased this Carter magnet based fence. I’ve worked with it some and now I offer a mixed review with both the positives and the negatives as I see them.
(As an FYI – I have a second, smaller, band saw that I use for the curvy stuff.)
As I would expect from Carter, the workmanship is excellent. This simple tool is well made. The fence is held very securely with the 2 included MagSwitchs. There are also 2 places to add additional MagSwitches. I doubt that will ever be needed, but it is nice to know the option exists.
Since a primary purpose of this bandsaw is resawing, I consider the fence too short (3”). You will see in the picture that I added a face board which, effectively, raises the fence to 6”. There are 4 slots that run the length of the Carter fence that will accept the nut of a 1/4” bolt making it relatively easy to add (and remove) the face board. However, I doubt that I will remove the face board very often due to the shims discussed in the next paragraph.
After adding the face board, I checked it for square to the table. It was off by a hair. I inserted some shins between the Carter fence and the face board at the top and that solved the problem. I cannot be 100% certain that the problem is the Carter fence (it could, in theory, be the face board), However, I think it is the Carter fence. Reinserting those shims every time I put the face board back on is a good reason not to take it off. Getting those shims in just the right position was a PITA.
With a magnetic fence you have no way to automatically get the fence perpendicular to the edge of the table. You will see in the second picture that I put an adhesive tape measure on the far side of the bandsaw table. It is not a coincidence that the face board is long enough to reach from the tape measure on one side of the tape measure on the other side. In theory, if I align the face board on each side to the same measuring mark, the fence will be perpendicular to the edge of the table. The face board is 22” long. The Carter fence is 15” long.
This fence is basically a good, well made, tool. But, for me, I wish it were longer, taller and perfectly square. I wish my added on face board was not necessary. Also, including an adhesive tape measure with the fence would be a nice idea. Fortunately, I had one in the shop that I had not used previously.
To be fair, this fence is probably built primarily for 14” bandsaws and it probably fits the needs for a 14” bandsaw better.
Suggestion for Carter – Make a second model that is taller and longer for people like me.
View richgreer's profile
richgreer
4472 posts in 1272 days
11 comments so far
View buffalosean's profile
buffalosean
174 posts in 1585 days
#1 posted 507 days ago
3” is a pretty short fence for re-sawing. I’m surprised Carter hasn’t come out with an larger version. You should e-mail them the suggestion. You never know.
-- There are many ways to skin a cat...... but, the butter knife is not recommended
View rodneyh's profile
rodneyh
105 posts in 862 days
#2 posted 507 days ago
Did you also look at the magswitch base system? I’m trying to decide between these two fences, or possibly just buying the magnets and building my own. Any thoughts on their comparison?
richgreer
#3 posted 507 days ago
I did not consider the magswitch base system. I wish I had.
I’m sort of a fan of Carter. IMO, their stabilizer is amazing. I use on on my smaller bandsaw for the curvy stuff.
In my mind, there was a little confusion about the Carter magfence. I’d seen videos on Carter’s guide system for bigger bandsaws. They do some pretty impressive resawing. In that video they use the original magfence. I thought that fence was impressive. I’m not sure of the height but it was probably about 4-5”. All the magnets switched on and off with one switch. I wanted that fence but could not find where to buy one. When I called Carter they assured me that their new fence was “new and improved” and advised me that they had discontinued their original product.
View NBeener's profile
NBeener
4805 posts in 1371 days
#4 posted 507 days ago
Rodney:
My brother WAS the product rep for MagSwitch for years (not any more), and gave me one of their mag-based resaw fences. I’d guess it IS six inches tall, and … I flat love it.
Lower the upper guide, position the board to be resawn, slide the fence against it, just ahead of the blade, twist the two magnets into the on position, and go. It’s a single roller fence (they may have a double roller, too), and I think it’s great. I’ve found no downsides, in using it.
-- -- Neil
View Dusty56's profile
Dusty56
10727 posts in 1886 days
#5 posted 507 days ago
Hi Rich , try getting hold of Ellen35 or Moonls .
They might have a couple of the older style fences for you. : )
-- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did.
View ellen35's profile
ellen35
2453 posts in 1630 days
#6 posted 507 days ago
Rich,
moonls and I both bought the first generation Mag-fence. The second generation came out because of the poor design of the first one. This does look like an improvement with the knobs instead of end bars but, when I asked them about the problem at the Woodworking Show, they really did not want to discuss it. I was not happy.
Thanks Len… I’d get rid of my MagFence I in a heartbeat!
richgreer
#7 posted 507 days ago
ellen -
As I said before – - Based on my viewing of the video I saw, the magfence I looked like a good design. Indeed, I was looking to buy that model.
I don’t want to bug you, but can you comment on the deficiencies of the Magfence I design?
Dusty56
#8 posted 507 days ago
I thought as much , Ellen : ) You’re welcome !
ellen35
#9 posted 507 days ago
Rich,
The first iteration of the Mag Fence had handles on each end to unlock it from the table. You pushed down on the handle and it acted as a lever to lift the end of the fence. This was fine for a larger table… say a table saw. But, for a bandsaw table, it hung over the edge on one or both ends depending on if you centered it (both ends) or offset it (one end). So… the real problem lies with taking the fence off the table or moving it more than a poke. Both Lorna (moons) and I have jammed fingers pushing down on the unlock handle and, with it hanging off the table, the lever on one end really did not work correctly. I saw the new Mag Fence II and the design is soooo much better. The use of knobs to lock and unlock it is a great improvement. My original thought was to talk with them about possibly getting a break on the cost of the Mag II because the design of the Mag I was so poor. The just kept insisting that the Mag I design was fine (so why is there a Mag II????). I know Lorna called Carter and spoke with someone who was distinctly unhelpful. I expect more from Carter as they are a very reputable company and I really like their bandsaw guide systems. I think you will be happy with the Mag II if it is high enough for your re-sawing.
Ellen
richgreer
#10 posted 507 days ago
Thank you Ellen.
I think I will be happy with the Magfence II, now that I have added the face board. With that face board I have a 6” high fence and I believe it will serve me well. Nonetheless, I will argue that I should not have to make some significant modifications to the fence for it to be usable for my purposes. Within a few days I will be resawing an 8-10” wide board of walnut. That will be the real test. I’m holding off until a new band saw blade arrives.
View Gerry's profile
Gerry
228 posts in 1438 days
#11 posted 377 days ago
Rich,
Thank you for the great review, and the limitations you have found. Ellen, thank you so much for the history, the clarity, and a current users’ perspective of what works and what does not. This is VERY helpful!
I’ve been looking at the Carter Magfence II with great interest…. Currently am using a Wood slicer blade with the existing fence on my Rikon, with an 8” extension for wide board re-sawing. Once I set the drift angle, I have had good and consistent results with boards up to 11”.
Rich, please let us know how the mag fence 2 works with your walnut cuts. Thanks!
-- -Gerry, Hereford, AZ ” A really good woodworker knows how the hide his / her mistakes.”
