| Review by Sawdust2 | posted 479 days ago | 1971 views | 0 times favorited | 7 comments | ![]() |
- M K Morse bandsaw blades
- Brand: M K Morse | Category: Bandsaw Accessories
This is a 3 TPI blade from M K Morse. It is a carbide tipped blade and is used in industry for cutting aluminum castings.
This review won’t let me post all the photos but I first used a bi-metal blade from a vendor I really like. I could not get it to track straight. (I set my saw up using Michael Fortune’s method so I don’t get any drift.)
I installed this blade according to Fortune’s method.
This is a 1/2” blade but I was advised to only tension it to a 3/8” blade.
I took a hunk of red oak about 5” wide and 2.5” thick and planed one side smooth.
I wanted to check how much wood would be lost in the cut.
You can see that the cut was almost perfectly straight and the photo of the two pieces of the wood show that the
saw marks are negligible. The top piece was the planed side.
If I were to plane the raw cuts I would lose less than 1/32”, maybe less than 1/64th. Truly, I could feel where the blade sliced but I could only see three or four marks in the 2’ length.
Last year I urban harvested some local wood downed due to a storm. It had been drying in my basement for a year.
So I next resawed some black walnut, maple, oak, cherry and sycamore. Like a knife through warm butter.
Some of you may remember my posts about losing the smoke in my motor a few weeks ago. Motor bogged down while resawing using the bi-metal blade. Not this time. (But the replacement motor is 5 HP, not the measly 1 HP Jet uses.)
I had a Morse blade before and used it for more than 2 years (on that 1 HP motor) until the weld gave out.
I also have a Morse bi-metal blade and will test that out soon and give a report on how that compares.
7 comments so far
home | projects | blog
34370 posts in 2570 days
#1 posted 479 days ago
I picked up 4 Independence III MK Morse blades on ebay. I’m going to have to shorten them for my bandsaw. They are bi-metal blades. I’ve also got some carbide tipped blades that I need to weld up.
I’ve used Laguna Resaw King blades and they are great and give a nice smooth surface. I had one that they wouldn’t sharpen because the blade had so many cracks in the blade. I’ve got another one that is fractured. So for the price I’m not very happy with their blades. The cut quality is great but the blade life sucks. For $175.00 a blade I would have expected more.
Good luck on your conversion from logs to planks.
b2rtch
2955 posts in 1218 days
#2 posted 479 days ago
Sawdust2; what is ” Fortune’s method”?
Thanks
-- Bert
Charles Maxwell
826 posts in 1977 days
#3 posted 479 days ago
What was the cost of your MK Morse blade?
-- Max the "night janitor" at www.hardwoodclocks.com
b2rtch
#4 posted 479 days ago
Sawdust2, I found the answer to my question.
-- Bert
Sawdust2
1467 posts in 2257 days
#5 posted 479 days ago
Fortune has condensed the “How to” on the bandsaw in an easy to follow 8 page article in an old FWW, I refer to it more often than any other article. Our guild once had a seminar and the instructor actually showed how to compensate for drift by running a board partway up the blade to determine the drift then scribing a line that paralleled the board and then adjusting the fence to match that line. That was way too time consuming.
Following Fortune’s method I’ve never taken more than 3 minutes to properly align the blade and get perfectly repeatable cuts every time.
buffalosean
174 posts in 1557 days
#6 posted 479 days ago
I’ve never used these blades. So the review was most helpful. thank you
-- There are many ways to skin a cat...... but, the butter knife is not recommended
Brian Scott
7 posts in 436 days
#7 posted 435 days ago
I never tried using these blades. I am using a HaltBar Sagen Blade. Same thing, I am using a carbide tipped blades. I am going to try that blade to compare. Thank you for the review.
-- No one is old enough to learn new things.
