| Review by GaryK | posted 626 days ago | 1724 views | 0 times favorited | 19 comments | ![]() |
- Steel City 50400 Height Attachment for 14-Inch Band Saw
- Brand: Steel City | Category: Bandsaw Accessories
Here is the 6” riser kit parts for the bandsaw. The installation is fairly simple.
This is a “must have” addition if you plan on doing any resawing.
It gives you an additional 6” height for resawing extra wide boards. It works great!
It increases the length of blade needed from 93 1/2” to 105”. The same as a Delta Bandsaw.
First remove one big bolt with w 30mm socket wrench. and set the top half aside.
Then install the riser block and the two dowel pins.
Now don’t forget to install the longer rack while it’s apart. If you didn’t you would have to remove the table to get it in.
Then just put it back together again and tighten the bolt.
You have to drill two small holes in the upper door to attach a small guard witch you can see in the last picture.
And here it is completed.
19 comments so far
Dominic Vanacora
home | projects | blog
504 posts in 763 days
posted 626 days ago
Your presentation make’s it look easy. Thanks for taking the time to show how its done.
-- Dominic, Trinity, Florida...Lets be safe out there.
John Gray
1753 posts in 779 days
posted 626 days ago
GREAT post. You’ve got me thinking about a riser for my bandsaw.
14156 posts in 1054 days
posted 626 days ago
well that looked simple!!
TomFran
2513 posts in 888 days
posted 626 days ago
Yep, I need to get that 6” riser for my bandsaw. I new I should have got it when I ordered my new saw. Thanks for the post, Garyl
GaryK
9521 posts in 882 days
posted 626 days ago
Tom – Don’t forget longer blades.
Greg3G
770 posts in 979 days
posted 626 days ago
Sweet!...Now you have added this to my tool wish list. How do you like the finish on the granite table? It looks solid enough to take the normal abuse from regular shop use. Looks like a great machine.
-- Greg - Charles Town, WV
grovemadman
558 posts in 665 days
posted 626 days ago
Wow, that looks really nice, what is the challenge and how do you get involved?
-- --Chuck
CutNRun
122 posts in 740 days
posted 626 days ago
Gary, I enjoyed your review and the details provided so far. I look forward to your assessment of the operation as well.
I have a couple of questions for you:
1. Do you see any real advantage with the granite table?
2. How much was the riser kit? The Steel City web site doesn’t list a price.
-- CutNRun - So much wood, so many trails, so little time
GaryK
posted 626 days ago
CutNRun – First of all I got the Riser from ToolKing an advertiser on Lumberjocks for $69. Which is a lot better than the $95 price I have seen other places.
Real advantages of the granite top. It won’t rust. It won’t warp. The bottom surface is flat allowing you to
use any type of clamps. Try putting a clamp on a cast iron top with all the webs and ribs under it and you will know what I mean. You can also use it for anything that requires a dead flat surface. That’s all that I can think of for now.
teenagewoodworker
2481 posts in 662 days
posted 626 days ago
wow that is good. it looks easy. thanks for showing us how to do it. very detailed too.
CutNRun
posted 626 days ago
Thanks for the feedback. I expected the comments about not rusting and dead flat, but hadn’t thought about the bottom surface. I absolutely know what you mean, having “been there and done that” before with other equipment.
Chris
1469 posts in 885 days
posted 626 days ago
Thanks Gary!
-- Chris
woodup
145 posts in 837 days
posted 626 days ago
Great Details! Thanks for sharing!
-- Michael, Fort Worth, TX. "I wood if I could!"
tenontim
1319 posts in 638 days
posted 626 days ago
Gary, what is the HP rating of the Steel City saw. I have a Jet with a 3/4 HP motor and have heard that it can bog down when resawing at max capacity. Have you had any power problems with your saw after installing this riser?
-- Tim -- http://tmuli.com
14920 posts in 745 days
posted 625 days ago
Gary, I have had a similar riser kit on my bandsaw for a couple of years. I works fine, the only thing I found was you need good quality low TPI blades to cut the thicker pieces. I notice you have your on/off switches nice & high, thats a problem I had to overcome by modifying my bandsaw.
Brad_Nailor
1214 posts in 851 days
posted 625 days ago
Again, thanks for the extra effort making these great reviews.
cajunpen
5968 posts in 959 days
posted 625 days ago
Thanks Gary, I’ve been thinking about adding the riser block to my Grizzly – but have been apprehensive about it – you just make it sound so easy, think I’ll go for it.
25793 posts in 1294 days
posted 625 days ago
Great addition Gary. Looks great.
motthunter
2079 posts in 693 days
posted 625 days ago
looks great.. kind of strange that you have to drill.
I worry about the t track int he granite. I would think that with wear it will deform a bit and you wont have a straight or even track. They should have included a metal insert in the groove so that the track will never wear.
Granite can change over time with abrasive friction like sanding, polishing, etc. I am sure it is a great surface. Just keep an eye on it so that it doesn’t wear funny over time.
This does look like a great saw. I hope that you get many years of great projects on it.
-- making sawdust....
