Best Jigsaw I've used
Review by Eric_S posted 12-31-2011 11:56 PM 13553 views 0 times favorited 11 comments Add to Favorites Watch
Best Jigsaw I've used No-picture-s No-picture-s Click the pictures to enlarge them
I’ve used 4 different jigsaws over the last few years, most recently though a $30 black and decker one that had lots of vibration and couldn’t cut a straight line for the life of it. I got tired of that and decided with my L-shaped closet shelfing I would use a jigsaw to cut it, so I’d need a quality one. I purchased this from Home depot for $130. It includes one blade that looks like 8 tpi or so, a case, and an allen wrench for adjusting the angle. I picked up some 10 tpi ones though which work well for the plywood.
The saw does have a dust port but in order to attach a vacuum you need to buy a separate dust kit which I think is $30 or so. However, it does have a built in blower you can turn on when a vacuum isn’t connected to blow dust out of the way to see the line and works very well, although it does end up blowing dust all over the place instead of it just falling around the saw.
It also comes with an anti-splinter piece that I’ve been using on plywood and it worked very well. Its basically a zero-clearance insert for a jigsaw. It takes t-shank type blades, and has an interesting and easy to use blade locking mechanism that I haven’t seen on other brands. Seems very reliable for locking the blade.
The saw has very little vibration and is a breeze to use. It has 6 variable speeds setting for the maximum speed and a variable trigger to adjust that. It also has 4 settings for orbital action for woods, metals, plastics, etc and an On lock for long cutting periods which came in very handy when doing my shelves.
I was impressed how well it cut a straight line without an edge guide, my previous jigsaws couldn’t even do that :( Even when plunge cutting it was straight.
All in all, very impressed with this one and I hope it lasts for a long time.
-- - Eric Noblesville, IN
View Eric_S's profile
Eric_S
1565 posts in 3436 days
11 comments so far
Beginningwoodworker
13345 posts in 3913 days
#1 posted 01-01-2012 12:55 AM
Thanks for the review.
View mondak's profile
mondak
71 posts in 2641 days
#2 posted 01-01-2012 04:16 AM
I don’t own the bosch jig saw, but have heard that it is a top rated tool.
Eric_S
#3 posted 01-01-2012 04:47 AM
The only negative is the angle adjuster. It has set angle locks that can’t be adjusted but since Im mainly using it for 90 degree cuts its not a big deal to me.
View jim C's profile
jim C
1472 posts in 3339 days
#4 posted 01-01-2012 03:05 PM
I bought the palm version rather than the handle one and I would give it 5 stars also.
When you set it with wide open orbiting, it cross cuts thru a 2×6 of pine in seconds. When you need a precision cut, with no orbiting, it’s very controllable and a nice smooth cut.
Thanks
View kizerpea's profile
kizerpea
775 posts in 2608 days
#5 posted 01-01-2012 04:18 PM
I have the bosch 584vs barrel grip..had it for 10 ys worth the little extra u pay.. most of my hand tools are bosch. i like to buy tools one time.
-- IF YOUR NOT MAKING DUST...YOU ARE COLLECTING IT! SOUTH CAROLINA.
View lew's profile
lew
12512 posts in 3996 days
#6 posted 01-01-2012 06:01 PM
Thanks for the review, Eric.
Looks like the design makes it very comfortable to use.
Lew
View RogerBean's profile
RogerBean
1605 posts in 3194 days
#7 posted 01-01-2012 06:51 PM
I’ve had one of these for a year or so, and while it’s not a tool that I use a lot, I’ve been very satisfied with it. Smooth operation and the Bosch blades cut very well. In fact, I’ve become quite a fan of Bosch routers, drills, screwdrivers, etc. Quiet, smooth, precise, and reliable. Thanks for the review.
Roger
-- "Everybody makes mistakes. A craftsman always fixes them." (Monty Kennedy, "The Checkering and Carving of Gunstocks", 1952)
jim C
#8 posted 01-01-2012 07:01 PM
I have to agree on Bosch tools.
I’ve never encountered a bad product. Jigsaw blades are second to none.
View Chipy's profile
Chipy
374 posts in 2834 days
#9 posted 01-03-2012 11:41 PM
Bosch is the king of Jig saws but the Dewalt is a close second.Nice review!
View isptpr's profile
isptpr
12 posts in 2600 days
#10 posted 01-05-2012 05:28 PM
Agree 100% Eric. Bosch makes a great jig saw.
View roofner's profile
roofner
130 posts in 2523 days
#11 posted 03-06-2015 12:22 AM
Question I had a bandsaw but did not have room enough in my small shop.
Im thinking for the few times I used my bandsaw this bosch 365 would work to substitue
for the bandsaw and would get more use and solve my problem.
