Save your money
Review by rrdesigns posted 12-27-2011 04:49 PM 4339 views 0 times favorited 17 comments Add to Favorites Watch
Save your money No-picture-s No-picture-s Click the pictures to enlarge them
This jig is worthless and is being returned to the seller. The index pin is too short making registration with your workpiece difficult.The knob controlling the index pin is too close to the bottom of the jig and is difficult to set because of its small size and location. More importantly, it does not maintain its setting. It loosens slightly as you progress through your joints ruining the spacing in your workpiece. The workpiece likes to pull away from the fence (when used on a router table) when cutting a partial joint on the outside edge and must be clamped to the fence for safety. You must use your own clamps. There are better jigs out there. This is not one of them.
-- Beth, Oklahoma, Rambling Road Designs
View rrdesigns's profile
rrdesigns
532 posts in 3424 days
17 comments so far
View Bertha's profile
Bertha
13551 posts in 2931 days
#1 posted 12-27-2011 04:51 PM
I’m the type who will buy a jig rather than making it. Not very galootish but it is what it is;) As a consequence, I get burnt like this pretty often. Sorry to hear this but you saved me from buying it.
rrdesigns
#2 posted 12-27-2011 04:56 PM
Glad to be of service. Lumberjocks united.
View helluvawreck's profile
helluvawreck
32086 posts in 3105 days
#3 posted 12-27-2011 05:20 PM
I’m sort of coming to think that the best way to go about building sliding jigs is to go with a professional sliding base such as those you can build with Incra's build it system and then build the rest of the components that ride on these bases. I got a starter system over the weekend and it looks pretty good. I’m going to experiment with it and see if it’s worth it or better to start from scratch. One of the things I intend to build is a box joint jig. I don’t have room for a lot of jigs in my shop so if I have a couple of bases and the special built components to ride on them I will save a lot of room. There’s lots of plans floating around for a good box joint jig that could be incorporated into these Incra bases so you might want to take a look at going this rout.
helluvawreck
https://woodworkingexpo.wordpress.com
Bertha
#4 posted 12-27-2011 05:39 PM
^Wreck, I ordered an Incra setup to make my bandsaw fence a couple of weeks ago. I don’t know if they’re any better than homebrewed, but that anodized aluminum sure looks cool:) Did you see the sliding router table jig that a fellow LJ just posted? (Sorry, I can’t find the post).
View richgreer's profile
richgreer
4541 posts in 3312 days
#5 posted 12-27-2011 06:49 PM
If anyone is interested in this type of jig, I have been pretty happy with this one – -
http://www.rockler.com/product.cfm?page=21338&filter=box%20joint%20jig
It does not have a registration pin. It has a registration track. Actually it has 3 interchangeable registration tracks for 3 different sizes of opening and it works as good as they say it does.
They recommend a spiral cut router bit. In my experience, that is not necessary. A simple (and cheaper) straight bit works fine.
helluvawreck
#6 posted 12-27-2011 07:57 PM
Al, the sliders seem to have a good adjustment to get the fit just right and those aluminum extrusions seem to give a lot of advantages. The sliders can’t be to tight nor too loose. Wood sliders swell and all you can do is take them down a little. Anyways with the limited time to do woodworking that I have (only weekends) I had rather woodwork than build jigs. It’s not that I haven’t built jigs before. Jig building was a big part of my job for 40 years.
Rich, that looks like a nice jig.
helluvawreck
16281 posts in 4456 days
#7 posted 12-27-2011 08:19 PM
Beth, I have this jig. Once I figured out the setup I had no complaints and it does what it is supposed to do. Maybe you got a lemon.
View DaytonHM's profile
DaytonHM
129 posts in 2580 days
#8 posted 12-27-2011 09:14 PM
Thank you from a newbie member, had my eye on this jig just a few days ago! I am new to the community here at lumber jocks and you folks are an awesome bunch!
Thank you!
-- DaytonHM Dayton Va.
richgreer
#9 posted 12-27-2011 09:20 PM
Helluvawreck and all – -
I agree that any sloppiness in the track is a problem.
You will note that with the Rockler jig, there is no sliding in the track in the router table. The track in the table is only used to stabilize the jig. The sliding takes place in 2 tracks in the jig itself. There is no noticeable slop. I think that is a key way this jig differs from the rest.
View gfadvm's profile
gfadvm
14940 posts in 2928 days
#10 posted 12-28-2011 04:30 AM
Beth, These things are REALLY simple to build if you are so inclined. I built 2 on Christmas day from a jointed/squared 2×6 with a jatoba pin for durability. Routed a T slot in the back side to attach it to my miter gauge and make it adjustable. I built a 1/4 and 3/8 to go with my Freud box cutter blades. I’ll be happy to p ost pics somewhere if you need them.
View smitty22's profile
smitty22
714 posts in 3185 days
#11 posted 12-28-2011 06:15 AM
Sorry to hear about the disappointing product, we all run into those now and then.
For either the table saw or router boxjoint application, I found that the Woodcraft tutorial “Box-Joint
Basics” is excellent and covers all the little ‘gotchas’ very well. here’s my version built from that:
Basically just a good hardwood fence attached to the miter gauge. Downside is that you have to build a new one for every thickness of wood, ie, not adjustable.
-- Smitty
gfadvm
#12 posted 12-28-2011 06:24 AM
Smitty, Does yours have a T track on the back or ??? so you can tweak it to get the perfect pin width? Or is it screwed to the miter gauge?
rrdesigns
#13 posted 12-28-2011 07:28 AM
gfadvm: I would love to see some pics. I’m leaning toward a router table system instead of a dado blade for now. I have a dado blade for my sawstop but it isn’t very sharp and leaves some tracks. And changing the brake cartridge while fairly simpler can be a nuisance.
I’m willing to try building one if I can achieve the precision and repeatability that I want. I am trying to make wooden piano style hinges with a 3/4” hinge pin for tortilla presses.
I’m leaning toward scaring up the cash for an Incra LS positioner for the router table. That looks like a pretty good and precise product that can easily handle box joints (among others) repeatedly.
Do you (or anyone else) have any opinions about router table cut box joints versus dado blade?
117417 posts in 3815 days
#14 posted 12-28-2011 08:26 AM
Thanks for the review Beth.
smitty22
#15 posted 12-28-2011 05:31 PM
Beth, & gfa, My version is screwed to a positionable fence/face on the miter guage, project is posted here, more pics: http://lumberjocks.com/projects/40370
The key to this is that there are actually 3 fences involved, the wooden face fence which holds the index block, the extruded aluminum middle fence with T-slots on both front and back, and the face/fence of the miter gauge itself. The wooden fence and the extruded fence are secured together with T-bolts and remain together for all box joint operations. They move laterally on the face of the miter gauge to adjust the position of the index block with respect to the blade and thus the position of the initial ‘slot’ that is cut. That’s what the adjustment mechanism does.
The slot width and depth are of course determined by the dado/blade stack width and height. Spacing of the second and subsequent slots is determined by the width of the index block (hopefully identical to the first cut).
Unfortunately it’s not the ultimate fully adjustable jig!
the Incra sure sounds great, maybe one of these days I can catch up enough on other stuff to afford one.
Thanks for posting a review,
Dale
-- Smitty
