MLCS Jointer knife setter - easy cheezy
Review by Bertha posted 12-26-2011 06:44 PM 5027 views 0 times favorited 9 comments Add to Favorites Watch
MLCS Jointer knife setter - easy cheezy MLCS Jointer knife setter - easy cheezy No-picture-s Click the pictures to enlarge them
I didn’t really want to spend $80 on this but I did it anyway.
List Price: $89.95
Price: $70.69
http://www.amazon.com/MLCS-9397-Jointer-Planer-Setting/dp/B001NXC6YQ
NOTE: The way the jigs are setup in the picture above is incorrect! The magnets register directly onto the cutter head; they never attach to the table surface!
The reviews were pretty bad, actually, but it works as advertised. It’s made of some heavy duty type plastic with really hard-tugging rare Earth magnets. The way it works on my PM54a:
1) you have to lower the infeed table to get access to the cutter head
2) you first register the tool on the cutter surface with the blades out. There are little articulating arms with magnets on the outside; a center post with magnet that advances with the thumbscrew
3) advance the center plunger until it touches the head surface and tighten the thumbscrew. I’m not sure that the graduated scale improves this tool and I have my doubts about the accuray (but in fairness, they did both register the same reading)
4) insert your knives and gibs and flank your blade with the magnet. The center post will touch your knife edge, bringing it to the precise level of the cutter head (established earlier)
5) these little magnets are STRONG and they’ll tug your gibs up. I used a popsicle stick to keep them down beneath the cutter edge while I tightened the gibs down.
So, all in all, it works. Would I buy it again? No way. Not that it’s a bad device, it’s just that I never need to adjust my cutters more proudly (where the graduated scale excels). I let the infeed table handle the depth of cut. I subtracted a point for the plastic housing. That’s all I got, guys and girls.
View Bertha's profile
Bertha
13551 posts in 2891 days
9 comments so far
View lanwater's profile
lanwater
3111 posts in 3132 days
#1 posted 12-26-2011 08:22 PM
Thanks for the review Al.
It’s quite detailed. I am getting to the point where I will need to change my knives.
-- Abbas, Castro Valley, CA
View Dusty56's profile
Dusty56
11822 posts in 3885 days
#2 posted 12-26-2011 09:25 PM
I guess I lucked out with my old Delta Rockwell 6” jointer. The slots in its head were all perfectly machined so all I have to do is bottom the knives in the slots and then adjust the outfeed table to the proper level with the blades : )
Of course , the knives all need to be the same exact height after sharpening for this to work. It pays to have a machinist friend to sharpen them : )
Too bad you can’t return them , Bertha.
Did the ad say that they were made from plastic ?
View Brad_Nailor's profile
Brad_Nailor
2539 posts in 4155 days
#3 posted 12-26-2011 09:30 PM
Good review..now i know to skip this one.
View AttainableApex's profile
AttainableApex
347 posts in 3030 days
#4 posted 12-26-2011 10:52 PM
what is a good way to do this then?
-- Ben L
Dusty56
#5 posted 12-26-2011 11:22 PM
AA , Go to GarageWoodWorks.com and see Brians how-to on setting jointer knives : )
http://www.garagewoodworks.com/video.php?video=v1
scroll down to video number 10
View Sodabowski's profile
Sodabowski
2382 posts in 3030 days
#6 posted 12-26-2011 11:26 PM
I’d go with a shop-made solution instead… Thanks for the review Al, another item not to spend money on.
-- Thomas - Pondering the inclusion of woodworking into physics and chemistry classes...
View grizzman's profile
grizzman
7836 posts in 3501 days
#7 posted 12-27-2011 01:21 AM
hey al, i did the same thing with a sheet of glass, with 2 earth magnets on it, it does the same thing, raises the blades to the right high…tighten the set screws and wella…saved me 70 bucks…grizz
-- GRIZZMAN ...[''''']
View mafe's profile
mafe
11741 posts in 3287 days
#8 posted 12-27-2011 03:38 PM
Thank you for a fine review Al.
I have been looking at these.
Best thoughs my friend,
Mads
Bertha
#9 posted 12-27-2011 03:56 PM
^There you go, lol. That’s what I should have done. I think it’s designed to do something more than just set the knives. Possibly make them more proud of the cutterhead? I’m not entirely sure. Ah what the heck, it worked.
