Ridgid R4512 Table Saw Review
Review by TheRookieJer posted 516 days ago 12300 views 3 times favorited 24 comments Add to Favorites Watch
Ridgid R4512 Table Saw Review No-picture-s No-picture-s Click the pictures to enlarge them
3 Stars
-- Jeremy, Kingwood, Texas
View TheRookieJer's profile
TheRookieJer
8 posts in 543 days
24 comments so far
View knotscott's profile
knotscott
4194 posts in 1545 days
#1 posted 516 days ago
Congrats on the new saw. Excellent job with the review. I’d bet with the blade spinning at full speed that runout wouldn’t have been a concern during cuts, but your improvement method is pretty straight forward and certainly doesn’t hurt anything. Glad to see you’ve upgraded the blade. If you ever get to the point where you think you might want a new fence, the Delta T2 is ~ $150 and is pretty well regarded….offset that with $75-$100 you might get for your stock fence, and it’s a fairly inexpensive upgrade.
Enjoy!
View gko's profile
gko
70 posts in 1413 days
#2 posted 516 days ago
Great review Jeremy. Most of what I like to know about before buying stuff. After reading it I might have gone to 3 stars because some of the problems are so important to a good ts. But its your call. Btw, when adjusting the fence either make sure its totally dead on or bowing out at the far end a thousandth or two. Had a few scary kick backs when I got my first ts and the fence had about 10 thousandths bow in. Did you adjust the trunnions to be aligned with the miter slots? Another real pain in the neck but should be the first adjustment before doing anything else. Again, thanks for the review.
-- Wood Menehune, Honolulu
View jim C's profile
jim C
1400 posts in 1267 days
#3 posted 516 days ago
That blade runout is due to the shoulder of the arbor not perfectly ground perpendicular to the shaft.
I becomes a real issue when using a set of Dado blades. They will cut oversize.
gko is right on when aligning the fence. Make sure it moves away from the blade at the back by .002/.005. Kickback is a terrible, dangerous thing.
-- Government does not solve problems; it subsidizes them.
View dustyal's profile
dustyal
1125 posts in 1644 days
#4 posted 516 days ago
well done. much appreciated. I have been looking at this saw for the same reasons you mention. I can’t justify the big boy saws on my hobbyist budget. But we do need tools that cut true. This R4512 seems to be a good compromise. My friend, a serious 30 year woodworker, has one and has never complained about his.
-- Al H. - small shop, small projects...
View jeff's profile
jeff
422 posts in 1634 days
#5 posted 516 days ago
nice review.i have this saw.its been accurate for several months now.a good choice for the hobbyist.jeff.
-- Jeff,Tucson,Az.
View Ken90712's profile
Ken90712
12662 posts in 1358 days
#6 posted 516 days ago
Nice review.
View firehouse's profile
firehouse
44 posts in 960 days
#7 posted 516 days ago
I HAVE THE TS3650 RIDGID THE OLDER MODEL WITH CAST IRON WINGS WHAT A GREAT SAW YOU WILL LOVE IT. MERRYCHRISTMAS——- FIREHOUSE
-- duke 66 ocala fl.
jim C
#8 posted 516 days ago
I have the 3650 also.
Out of the box perfect.
Never looked back.
View Paul Stoops's profile
Paul Stoops
275 posts in 730 days
#9 posted 515 days ago
Good review. However, I have a question regarding the casters. I have the Model 4511 with the Herculift mobile base. It is designed with a cam lock mechanism that locks the casters down when you depress the lift pedal.
I have looked at the Model 4512 and it looks like it has a much simpler cam lift/ locking mechanism. I have read on the Ridgid forum that it is possible to install the pedal linkage on your saw backwards, such that it won’t adequately lift the saw or lock it in place. You might take a look at your installation. I think there is information about this on the Ridgid forum. I can’t believe they wouldn’t have a feature to lock the casters in the lifted position. This review seems to confirm this: http://lumberjocks.com/reviews/2020
-- Paul, Auburn, WA
View Jim Bertelson's profile
Jim Bertelson
3337 posts in 1334 days
#10 posted 514 days ago
I am looking at this saw very seriously for a second shop at a vacation house. Thanks ever so much for the review. It is still top in the running, since the second shop won’t get as much use. At home I have…....an ancient, 20 year old Delta Contractors saw which has never…...meaning never…..needed alignment with the slots. It is still in perfect alignment as purchased. I have a Vega fence on it which has been great.
But now, I think this saw is probably my best bet for the vacation house….....
Thanks.
-- Jim, Anchorage Alaska
View hafassartist's profile
hafassartist
41 posts in 556 days
#11 posted 514 days ago
Same as firehouse and Jim C said.
View anothernomad's profile
anothernomad
2 posts in 513 days
#12 posted 513 days ago
I have the craftsman version of this saw. For me it is my first real ts. So far I love it. My complaint is the fence. I am always taking the fence off the saw, so I have to readjust when i put it back on. Something else that I ran into was trying to make a zero clearance throat plate to fit flush and stay down. It has a recess about 3/16 which is a pain. I am only a beginner woodworker so it may be my lack of skill. But I am to the point that i am just going to buy the throat plate. I am very happy with the saw though and would recommend it to anyone who is learning.
View JaceAlan's profile
JaceAlan
6 posts in 530 days
#13 posted 512 days ago
I agree with Paul about the Casters. I bought this saw a few weeks ago (and am very pleased with it). The casters lock in the up position for me which makes for very easy maneuvering. Hopefully he’s right and you just have it backwards. Very good review and I completely agree with your major points. Thanks for the review!
By the way, I made a flip-up out-feed table for mine and posted it here: http://lumberjocks.com/projects/57764
-- Jace, Arlington, TX, www.jacealanyeats.blogspot.com
View 6744's profile
6744
4 posts in 984 days
#14 posted 510 days ago
I just started to assemble my R4512 last night after bringing it home on Monday. I found, after struggling for an hour by trying to follow the instructions, that it was easier to mount the two axles in the base, and then mount the casters and tie bar. Much easier to handle and the casters go on easily after the axles are mounted.
View jrickard's profile
jrickard
4 posts in 512 days
#15 posted 509 days ago
Thanks for the review. I was looking at this saw for the last two weeks. I am a really really new at wood working and wanted to start a shop. I like how this saw is not super big. I am still debating on this table saw or a table top saw. I have the room for it. I am kind of going into this whole wood working blind I never grew up with it or spent time with it. If any of you guys would tell a new comer to get a saw would you guys say the table saw or table top saw. I plan on doing shelves and stuff around the house. Let me know what you guys think.
showing 1 through 15 of 24 comments
