| Review by David Grimes | posted 526 days ago | 1716 views | 2 times favorited | 5 comments | ![]() |
- PREVAL Spray Gun #267
- Brand: PREVAL | Category: Spray Guns
These sprayers are great. And inexpensive. The $6 spray gun comes with a glass jar and the power unit. They can spray paints including latex, auto paints, lacquers, acrylics, primers, etc. One power unit ($4 for extras) will easily spray 16 oz. of material… quite a bit for small and medium sized projects. The glass jar cleans easily for re-use.
I’ve been using one of mine for lacquer and find the atomization just fine for dry or wet coats. I even thinned some brush on lacquer with lacquer thinner (from a tip on another forum) and that sprayed well, too. And dried hard faster and smelled much better, too.
The only possible cons I see (but neither are a problem for me) is the glass container (somebody will drop / break it and whine about it)... and the fact that you can’t tilt past 45 degrees.
I also like that in between coats (even a day or two) I just leave it ready to go for the next series. This is so much better than all the cleaning work, time and use of solvents to clean up.
Highly recommended. They are at both the BORG and Lowe’s. Walmart even has them with plastic containers, but they are a couple of dollars more. I guess the cost cutter hasn’t found them yet.
Give them a try.
-- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia
5 comments so far
home | projects | blog
14865 posts in 2390 days
#1 posted 526 days ago
Pretty cool… I’ve never seen those before. I love the no-cleanup aspect. Definitely want to give this a try.
ajosephg
1723 posts in 1733 days
#2 posted 526 days ago
Thanks, I’ve also wondered about these.
-- Joe
JoeyG
1161 posts in 797 days
#3 posted 526 days ago
I had forgotten about these. I worked for a cabinet shop in Richmond, VA. It was a small, high end custom shop and we did a lot of custom lacquer colors and used these for touch up. That is until our supplier began putting it into spray paint cans. We could get a 5 gallon mix with a couple of spray cans from the mix so the color matched. Now that I don’t have access to that resource, I will look into these again. I have a feeling they just might reopen some finishing doors that have been closed since leaving my old shop.
I see color lacquers making a appearance in my shop before long. Thanks for the review, I completely agree with you. a great product, and I thank you for the reminder.
-- JoeyG ~~~ http://www.facebook.com/JHGWoodWorks
Jim Crockett (USN Retired)
852 posts in 1905 days
#4 posted 524 days ago
Ditto for the reminder!! I had one of these when I had my ‘57 Chevy and have been thinking of getting one for spraying shellac. I’m glad to see that someone has had the same idea and that it works well. Since almost all of my projects are 2 cu ft or smaller, this should be ideal. Maybe get a couple – that way I can remove the fluid container, cap it, and keep the shellac that way.
-- A veteran is someone who, at one point in his/her life, wrote a blank check made payable to "The United States of America," for an amount of "up to and including his/her life".
w8n4simplertimes
37 posts in 1562 days
#5 posted 521 days ago
Thanks for the review.
I looked at my Lowes and Home Depot here and could not find this item. ...maybe due to holiday items taking space??
It does look worthy of a try on a project.
Safe holidays to all.
