User friendly, entry level spray system
Review by Vrtigo1 posted 528 days ago 2522 views 0 times favorited 11 comments Add to Favorites Watch
User friendly, entry level spray system No-picture-s No-picture-s Click the pictures to enlarge them
Let me start out by saying that I am a complete newbie when it comes to spraying finishes, and to finishing in general. I have never used any type of spray system before purchasing the Earlex, but after finishing projects by hand for a while I was looking for a faster and easier solution. The Earlex 5500 has met my needs and I’ve been happy with it.
The unit itself seems to be very well constructed, the turbine housing is fairly rugged, enough so that I get the impression that if it fell off a workbench it probably wouldn’t be any worse for wear. The onboard storage for the hose, electric cord and gun is handy, although it does take a bit of coaxing to get all of the hose back in after you take it out. Although I don’t have any basis for comparison, the gun seems to be very high quality. Everything functions well, I haven’t found anything I don’t like about it yet. The cup has a teflon lining which helps when it comes time to clean it out as whatever you’re spraying has less to stick to.
I purchased it when it was on sale at woodcraft for $320, and it included both the 1.5mm and 2.0mm needles. I’ve used both and would say that these are probably the two you will need the most right out of the gate. Changing needles is simple, Earlex includes a wrench to loosen/tighten the spray nozzle. After you’ve done it once or twice, the process of changing needles takes about 60 seconds.
I’ve sprayed poly and latex paint. The two types of poly I’ve sprayed are minwax polyshades (stain + poly in one) and general finishes high performance. These both sprayed fine. I think water based finishes may spray better with the smaller 1.0mm needle which I don’t have as I couldn’t get the mist quite as fine as I would have liked, but this didn’t prevent me from getting the job done.
I recently needed to touch up some small spots on the outside of my house, so I used the 2.0mm needle and gave it a go. When I poured the paint in the bucket, it looked so thick I didn’t think there was any way it was going to work. I added some floetrol, mixed it up and started spraying and was surprised at how well it worked. I only needed to touch up a few small spots and for that it worked very well. I wouldn’t recommend making an hvlp setup your first choice for spraying paint, but it will work if it’s all you have.
Cleanup takes a little time but is straightforward. I clean it in the kitchen sink because that’s what’s easiest for me. I use warm soapy water and rinse everything off until I think all of the finish is gone, then I run a cup or two of warm water through it. Finally, I take the needle out and run water through the whole gun until everything comes out clear. Total cleanup time is probably about 10 minutes.
The unit is fairly loud. I would say it’s about on par with a shop vac, give or take a bit. If I were using it for an extended period of time, I would probably wear hearing protection. The hose is nice and long so you don’t have to worry about dragging the turbine around with you, and it’s also long enough to allow you to work from a ladder with the turbine on the ground. The hose for the most part doesn’t get tangled too much, but that’s not to say that it never does. I didn’t realize this until I actually went to use it, but you can’t just take some of the hose out and leave the rest in. The hose has to come all the way out, and then it has to be connected to the air port on the front of the turbine unit. I thought the hose was always connected, but that’s not the case. When the hose if in the storage position, it is disconnected from the air supply.
The needles are fairly expensive for what they are, and you’ll probably eventually want to get all of the different sizes, so that could add another $100 to the cost.
Overall, I feel it represents a great value that allows someone that has never used hvlp before to try it out. Obviously, if you’re running a production shop then this probably isn’t the right unit for you, but for a weekend warrior this is a great unit.
View Vrtigo1's profile
Vrtigo1
420 posts in 1163 days
11 comments so far
View Ken Fitzpatrick's profile
Ken Fitzpatrick
365 posts in 2195 days
#1 posted 528 days ago
Thanks, I was looking at this one at Woodcraft to buy. Answered most all of my questions.
-- • "I have noticed that nothing I have never said ever did me any harm."....... Calvin Coolidge
View Tomj's profile
Tomj
197 posts in 553 days
#2 posted 528 days ago
Thanks, I have been looking into this also. Good to know it performs well.
View Chipy's profile
Chipy
378 posts in 764 days
#3 posted 528 days ago
Good review and Timely for me, I think its going to my Christmas gift? The Wood whisperer has a good video on this same Earlax model.
Vrtigo1
#4 posted 528 days ago
Chipy, I believe Marc’s video is actually the previous model but most of the features are still the same. Watching his video is one of the factors that led me to purchase it. It’s what I told my wife I wanted for Christmas, then a month or two ago woodcraft put it on sale so I bought it for myself and told my wife her shopping for me was done, lol.
Chipy
#5 posted 526 days ago
Vrtigo1 do you know what the improvements are?
View Luke's profile
Luke
202 posts in 858 days
#6 posted 526 days ago
I too have the 5500, and used it to spray stain, toner and finish on a built in entertainment center. I believe the improvements from the 5000 to the 5500 is a stronger motor that gives you the ability to actually spray paint.
I can attest to its ruggedness, as when we built my neighbors entertainment center I let him help me spray and on more than one occasion, he dropped the gun on the cement. Yes its aluminum so there are some dents, but thats all that came from it, purely cosmetic, and a bit of hurt pride for the shellacing he got for it.
I can say it took some tweaking to get things right, and we never went completely away from the air compressor and for the matter of connivence it is sometimes easier to use the gravity fed gun from an air compressor than the siphon fed Earlex, but I do love My Earlex!
View hianupam's profile
hianupam
20 posts in 854 days
#7 posted 524 days ago
very nice review. I got one and am very pleased with the result so far. The only thing I found useless was the handle. You can’t really lift the unit by the handle. What do you use it for?
-- Measure Twice, Cut Once
View Ken90712's profile
Ken90712
12676 posts in 1360 days
#8 posted 521 days ago
5500 I have this one and Love it. As mentioned the motor did get stronger. Enjoy.
View Carpintonto's profile
Carpintonto
53 posts in 1212 days
#9 posted 495 days ago
One good adjective for this spray system would be AWESOME!.
87305 posts in 1748 days
#10 posted 495 days ago
thanks for the review , I have the cheapest earlex they make and to my surprise it worked great too.
View metprof's profile
metprof
1 post in 521 days
#11 posted 444 days ago
Just used this for the first time on a bed just built. Was tickled with the results. Started with a little too much volume but was easily turned down. Love the air gap “click” adjustment between horiz/vert/spot patterns. No drips, no spots, no errors!
Happy furniture maker here.
Thanks Earlex.
