| Review by Tedstor | posted 560 days ago | 1889 views | 1 time favorited | 10 comments | ![]() |
- General 30ft Cord Reel
- Brand: General | Category: Shop Gear
Easily accessible power is priceless in the shop. While installing new outlets would have been the preferable remedy, it wasn’t particularly practical in my case.
This cord reel has solved a lot of problems for me. At 30 ft, its long enough to reach any point in my workshop/garage, and can even reach onto my driveway if necessary. And being mounted on the ceiling makes it easy to manage the cord, keeping it off the floor and away from my feet. The reel includes all the needed hardware to mount from the ceiling OR from the wall. I’ve actually meant to install one of these in my shop for quite a while now. But finding an affordable product that didn’t look like junk took a while.
I found this one in Amazon’s “warehouse deals” for $25. Color aside, it appears to be identical to the reel that Lee Valley sells for $70. In any case, it seems to be as well built as any I’ve used in the past. A great product at a great price. I’ve checked Amazon’s site a few times since my purchase. It appears Amazon’s warehouse keeps these in stock on a regular basis. But even if you can’t grab one of these particular gems; I can’t encourage you enough to find an alternate reel to buy. A definite upgrade to any shop.
10 comments so far
muleskinner
home | projects | blog
580 posts in 633 days
#1 posted 560 days ago
I bought essentially the same reel from Costco at least ten years ago. Apart from soldering a slip ring pickup a couple years ago, it’s still working great and getting constant use. Most convenient convenience outlet in the shop.
-- Visualize whirled peas
woodjunkie
31 posts in 865 days
#2 posted 560 days ago
10 amp 16-3 Wire. You must be running light duty tools on it or resetting the breaker alot. I would recommend 12-3 cord with 15 amp minimum rating.
-- He: Can I get the plans for that? Me: Plans???
Tedstor
947 posts in 829 days
#3 posted 560 days ago
Hand drills, dremel, sanders, work lights, etc. No breaker issues yet.
Larger machines are positioned next to wall outlets.
ChuckC
569 posts in 1131 days
#4 posted 559 days ago
I use something similar too. It is very handy to have.
baldeaglebaby
35 posts in 1199 days
#5 posted 559 days ago
I have one similiar also and I love it. Ranks right up there in most used tool rankings. You got a great price on this!
Fallon
79 posts in 1324 days
#6 posted 559 days ago
I have a Harbor Freight one that looks pretty similar. Had it jam on me once or twice & you need to manually make sure the cord wraps evenly to both sides of the reel or it stops retracting. Really convenient. I have a Kobalt (Lowes) retractable air hose that has an open reel that has jammed & tangled about as much, but is not as susceptible to the lopsided winding creating the trivially easily fixed jam.
I’d recommend either style over all I think. They are way handy keeping cords properly wrangled.
Chipy
374 posts in 790 days
#7 posted 559 days ago
We had 10 of this same model at work in a commercial application they work well for 3 years but in a home shop situation I am sure your cord real will last a life time.At the cabinet shop I worked at thees cord reals were beat on bad and operated in a highly humid environment.If it stops working take it apart and clean the segmented copper contact wheel, dust collects around the wheel and breaks the contact between the brush and the wheel.
Also like muleskinner mentioned the solder joint between the feed wire and the brush contact can come loose over time so if it stops working check inside befor throwing it in the trash can.
dustyal
1128 posts in 1671 days
#8 posted 559 days ago
Have one of these from Craftsman in garage for years. Real handy. But, you may want to watch. Less expensive are usually 16 gauge wire. More expensive is 12 gauge while 14 gauge is in between price. So, know what loads you want to plug into it.
-- Al H. - small shop, small projects...
Roco54
18 posts in 564 days
#9 posted 559 days ago
The cable reel is a great thing, specialy for uses in the midle of the shop, and I agree with woodjunkie – #12-3 conductors with 30ft supplies 20 Amps safely, but one has to consider also the wiring from the panel, or sub-panel, to the plug, that probably is #14.
When the benches are against the walls, I like to run wire mold raceway along the walls. Working with power tools like drills, sanders, hand routing etc. the power cord run is allways from the back. The location of plugs is a very personal thing and some people locate them above the work benches and some in front just below the work surface.
For power supply to stationary machinery in clusters, like table saw+thikness planer+ jointer the ideal is to have plugs on the floor but that needs carefull planing and running conduit below the floor. If one is building a new shop or installling a wooden subfloor on sleepers, it is an excelent opportunity to do that. FWW magazine , issue No 223, winter 2011-2012, has a very interesting shop layout, where the owner of the shop runs some power supply to machinery, and even dust ducting under the floor. But this is utopian, since most of us adapt existing spaces to woodworking shops.
In any case, power is a very much negleted safety hazard in the shop and one should pay a bit more attention to it.
Just my 2 cents…:-))
-- Life is what we make of it
WoodenSoldier
146 posts in 1141 days
#10 posted 558 days ago
I’ve got one of these also. I hung a 12 foot piece of strut along the ceiling of the garage and put this cable reel on a small trolley. It works great! Not only can I pull the cord out the reach anywhere in the shop, but I can actually move the reel around the shop as well.
-- I wish wood grew on trees so that this was a cheaper hobby.
