| Review by 000 | posted 541 days ago | 2083 views | 0 times favorited | 17 comments | ![]() |
- MLCS Box Joint Cutter #7860
- Brand: MLCS | Category: Router Accessories
blank
-- When the moderator chooses sides, his site sucks.
blank -- When the moderator chooses sides, his site sucks. | ||||||||
17 comments so far
ChuckC
home | projects | blog
548 posts in 1106 days
#1 posted 541 days ago
Is it worth 5 stars then?
If the fit is snug is that good enough? Did you try gluing a sample with yellow wood glue to see if that would be enough? I think epoxy in a finger joint will leave a lot of cleaning after it dries. You get a mess with yellow glue too but it’s easy to clean.
I’m guessing there’s a picture in the review but it’s not coming through so I can’t tell how bad the joint is.
PurpLev
7759 posts in 1819 days
#2 posted 541 days ago
sounds like you are having some issues with this cutter how come it’s rated as 5 stars? I’m confused.
000
3352 posts in 787 days
#3 posted 541 days ago
I didn’t even think about the stars
I’m more interested in what other people think. It’d be really cool to hear from people who have faced this issue.
I sort of wonder how many people just glue ‘em together and take the fit on faith.
jim C
1400 posts in 1269 days
#4 posted 541 days ago
Leave it be unless you want to drive yourself crazy with playing checkers with the shims.
I would assemble with the glue and wipe the excess off wit a damp rag and call it good.
I assume there is a small amount of wobble between all those pieces stacked up and that compounds the size errors.
-- Government does not solve problems; it subsidizes them.
jim C
#5 posted 541 days ago
Or P.M. me, I’ll give you my address, rnail me the tool and I’ll grind everything to the right dimensions and you’ll be good to go. No shims
Gene Howe
3198 posts in 1599 days
#6 posted 541 days ago
CR1…I have that set and, with poplar and oak anyway, the glue seems to swell the joint.
I’ve called them on other issues and they’ve always either gave me a fix on the phone or sent me a new cutter.
87305 posts in 1748 days
#7 posted 541 days ago
Cr MLCS has always been good to me if you don’t like the bit they will give you another one or refund your money .
WoodSpanker
517 posts in 1563 days
#8 posted 541 days ago
My Grandfather was a master Cabinet builder. Always told me never to trust anything that came out of China. Now I know why. Thanks for the heads up. (P.S. The Chinese killed my dog with their poisoned dog food, so I MAY be biased against them)
-- Adventure? Heh! Excitement? Heh! A Woodworker craves not these things!
000
#9 posted 540 days ago
What I dood wid it wuz dis:
I made a pass in some hard wood. Measured each finger and each slot.
Made a drawing posted here: http://store.gardentenders.com/topics/32249
Figured which fingers could use some changes and added shims accordingly.
I have a pretty workable box joint cutter now.
I wouldn’t say it is perfect like some thing I’d expect from Amana or Whiteside but it’s serviceable.
There’s another “ISSUE” It tends to Burn. Brand friggin new and it burns? Yah. I’m dealing with that by running the router at it’s slowest speed and feeding very carefully.
Well I only paid $50.00 for it so I suppose I got what I paid for – - – ( How many times have I warned people that you get what you pay for?)
Another “ISSUE” It grabs. The cutter cuts most smoothly and with the least grab when the individual cutters are staggered. Aligned as they are from the factory, it tends to grab the work and suck it into the cutter. Takes a hell of a Armstrong Forged C clamp to clamp it tight enough to resist the grab.
Rick Dennington
2889 posts in 1365 days
#10 posted 540 days ago
If you have speed control on the router, and it sounds like you do, then SPEED UP the router a little. If you run it too slow, it’s gonna burn. Getting the speed and the rate of feed just right together hopefully wil take care of the burning….
-- " Don't ever wrestle a pig in a mudhole....he'll be having more fun than you..!!
Bertha
13111 posts in 864 days
#11 posted 540 days ago
Spanker, sorry about your dog. If my dog were poisoned, I’d be ready to make someone pay with their head. I’m sincerely sorry to hear this.
Cr1, just wet the damn joints and let them swell;)
dbray45
2018 posts in 948 days
#12 posted 540 days ago
If you want really consistant box joints, make a jig for the table saw and a dado blade. This you have control of the cuts. Once everything is aligned, takes a little time, you can cut box joints all day long with a high degree of accuracy.
Just a thought
-- David in Damascus, MD
Rick Dennington
#13 posted 540 days ago
GGEEEZZZ AL, I wish I had thought of that….give them a bath in hot water…..when they cool down….swelled up….sometimes my thumb swells up when I drink too much coffee…..lol.
Actually…..David has the right idea….I made a few box joint jigs for the saw a long time ago..in fact I have about 3….one for 1/4”, 1/2”, and 3/4” b.j.s. I use the dado blades also to make mine, as a lot of folks do…much easier, safer, and quicker….I’ve heard tell of some folks using a single saw blade…...takes too long, and too slow…..yea dados…..Where would we be without them? That’s all, folks….!!!!
Bertha
#14 posted 540 days ago
^Rick, sometimes my whole body does that after too much coffee, lol. I suspect Cr1 was more curious about this bit than anything, given that the ts method is the most common. Fingerjoints for end-to-end stuff on the router table, I can see; but I never held out much hope for this bit.
Someone makes a really expensive 1/4” dedicated boxjoint blade, maybe Forrest? I imagine that would be the best of all Worlds. With a good jig and a proper register pin, I think you could blaze through these pretty quickly. However, Cr1 is taking it to a new level with the sheer number of boxes he builds at one time.
Rick Dennington
#15 posted 540 days ago
Al,
So your whole body swells, huh? Sounds like a bloating problem to me….lol…I usually have about 2 pots a day…drinking some now as we talk…..I’ll have to go have a nap in a few to let it wear off…..!!!!!
Yea, I’ve never cut much of any kind of joints on the router table….finger, box, all, on the table saw….I do have a setup I made from watching the Router Workshop using the dovetail bit and a rig they invented.
You got it…...Forrest makes that boxjoint blade, and that mutha is high….there may be other mfgs., but don’t know of any right off….I don’t build boxes….I use mine mainly for drawers, small cabinets, etc….easy peasy…..
View all comments »
