| Review by danielt | posted 585 days ago | 1637 views | 1 time favorited | 13 comments | ![]() |
- Crown 20260 burnisher
- Brand: Crown | Category: Sharpening Accessories
I bought a cabinet scraper a few years ago and have really enjoyed using it. I was able to make small shavings with it right out of the box, but of course it dulled after a while. I looked at various tutorials online to learn how to sharpen it and tried to use the same techniques. I didn’t have a burnisher so I tried a variety of stand-ins: screw driver, drill bit, router bit.
I was able to sharpen my scraper enough to still use it, but I could never get a good burr on it. I could only make very small shavings and most of the time it only produced saw dust.
I knew I wanted to get a real burnisher but it was never a high priority. Well, recently I put the Crown 20260 burnisher along with some other woodworking items on my Amazon wish list and wouldn’t you know some one bought it for me.
I tried it out the same day I got it and was amazed at the results. After flattening the scraper and giving it a few swipes with the burnisher, I was getting nice shavings. No more saw dust!
I am definitely glad I finally got a real burnisher and would recommend this to anyone that is having problems sharpening their cabinet scraper.
13 comments so far
schuft
home | projects | blog
104 posts in 804 days
#1 posted 585 days ago
Helpful review. Welcome to LJ’s!
doordude
857 posts in 1179 days
#2 posted 585 days ago
just got mine too, but won’t try it out till saturday.i’m glad to hear it is a good tool to have.
ratchet
1202 posts in 1983 days
#3 posted 585 days ago
Yep; I’ve tried scredirver shafts, old drill bits etc.
I was never really successful until I got a real burnisher.
Jimi_C
506 posts in 1431 days
#4 posted 585 days ago
I got the same one after watching the William Ng sharpening demo on the Woodwhisperer’s site. It’s an excellent video if you haven’t seen it. I’d tried Todd Clippinger’s mill file technique, and while it worked to a degree I always still had to sand the surface a lot to get it finish-ready. Now I just knock the burr down with a few rubs across the edge and then two quick swipes and the burr is ready to go again. The hard part is the original cleaning up of the edge on your stones.
-- The difference between being defeated and admitting defeat is what makes all the difference in the world - Upton Sinclair, "The Jungle"
helluvawreck
10904 posts in 1063 days
#5 posted 585 days ago
Thanks for the info and welcome to Lumberjocks.
Dennisgrosen
10851 posts in 1311 days
#6 posted 583 days ago
thank“s for the rewiew
and welcome to L J enjoy and have fun :-)
Dennis
bobasaurus
697 posts in 1380 days
#7 posted 583 days ago
I have the same burnisher and really like it (tried unsuccessfully to use a hex wrench before buying it). The sharpening process for card scrapers has a lot of confusion and voodoo surrounding it, I’ve found. My current process is kind of lengthy, but seems to work:
1. Use the mill file (freehand) on the faces and edge of the scraper
2. Use my soft oil stone on both faces
3. Stone the edge, either by holding it freehand or pressing against a square block while moving
4. Draw out the burr on the face side with the burnisher
5. Curl over the burr on the edge side
6. Repeat 4 and 5 for the opposite burr on the same edge
I typically square up two sides of the scraper and only draw/curl the burr on one side. When it dulls, I’ll use the other side. When both dull, I’ll just burnish-out the burr without re-squaring a few times until it really needs squaring again.
Do you use a similar process? I’m curious what works best for people.
danielt
7 posts in 585 days
#8 posted 582 days ago
Thanks bobasaurus for sharing the process you use. I use a similar process but use a cheap set of diamond plates for the initial grind followed by the stone. I don’t draw out the burr though, just use the burnisher at an angle. Now that you said it though, I think I remember seeing that in some of tutorials. I will give it a try next time and see if I notice a difference. Also, I do all four edges at once.
doncutlip
2808 posts in 1752 days
#9 posted 582 days ago
I stink at burnishing. Can you describe how much downward pressure you put on the tool?
-- Don, Royersford, PA
Jimi_C
#10 posted 582 days ago
@doncutlip: I don’t use very much. I knock the burr down, then just two quick swipes. If I put too much pressure on it (ie. I have to tip the scraper way forward to cut), I start over and use a little less pressure. If I don’t get enough burr, I just give it another quick swipe and that’s usually all it takes. Really, watch the William Ng video on the Wood Whisperer’s site, it’s an eye opener.
crabbieabbie
6 posts in 852 days
#11 posted 582 days ago
i am sorry it dulled
-- God is great.
crabbieabbie
6 posts in 852 days
#12 posted 582 days ago
i can see you are new to lumber jock’s so welcome.
-- God is great.
danielt
7 posts in 585 days
#13 posted 582 days ago
@Jimi_C: I saw you mentioned that video before. I’ll have to take a look at it. I love all the great info on the Wood Whisper.
@doncutlip: It’s kind of hard to describe the amount of pressure. I’m not sure what to compare it to. You don’t have to use as much as you might think. I like to hold the burnisher with two hands with one hand touching the scraper to help keep a steady angle. Not sure if this is the best way, but I saw someone do it that way and it felt comfortable to me.
